Pages: [1]   Go Down
  Print
Author Topic: Dominoes and glue squeeze out  (Read 4649 times)
Jason Kehl
Offline Offline
« on: February 17, 2012, 07:35 PM »
Hey all; what are your preferred methods for applying glue to Dominoes? I find it difficult to get what seems to me to be an adequate amount of glue and yet avoid sqeeze out.  I have been brushing a small amount on the dominoe, inserting it and brushing the excess up onto the other half of the Dominoe before installing the other part to be joined. I want a strong joint but chasing glue is getting tiresome.
Any tips out there?
jas
VictorL
Online Online
« Reply #1 on: February 17, 2012, 08:03 PM »
I'm usually applying glue along cut line on one piece, then small drop inside mortise. Using small brush covering mortise inside. small drop on each side of domino, then brushing glue. Insert Dominoes, then brush squeezed glue. Then small amount of glue inside opposite mortise and opposite part.
It's not so bad as it seems
VictorL
John Stevens
Offline Offline
Ardmore, PA
« Reply #2 on: February 17, 2012, 11:47 PM »
I've seen this question asked a few times, but I don't remember it having it been asked in the "ask Festool" sub-forum.  I'd be curious to read what the official recommendation is.
Regards,
John
What this world needs is a good retreat.
--Captain Beefheart
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #3 on: February 18, 2012, 12:49 AM »
Light coat both sides of mortise.  Light coat both sides of tenon.  Push together until about 1/4 inch apart, brush excess glue off the assembly, bring tight.  Shouldn't have to, but if there is squeeze out, clean up with a scraper, chisel, any flat edge.
Jason Kehl
Offline Offline
« Reply #4 on: February 18, 2012, 08:26 AM »
Thanks guys.
I would also like to know what the official Festool stance is on this. It seems as though Shane and others moderate all the discussions, any input on this from the experts?
I have been tempted to just put a bit of glue along the rim of the mortise and push the dominoes in, it would eliminate any squeeze out and be very fast but I quesion how strong the joints would be. I can't see an adequate bond with this technique, so I have avoided it so far.  Brushing the glue creates a strong joint, but is time consuming. Cleaning up the squeeze out is also time consuming and it is so easy to miss some and not realize it until the finish is being applied. Some projects require many dominoes, so to have a fast and effective method could significantly impact the overall constrcution time.
j
RL
Offline Offline
« Reply #5 on: February 18, 2012, 08:49 AM »
I don't think there's a particular rule, but at 6.40 into this Festool video, you can see he puts glue in the mortise and not on the domino. I tend to do the same, then stick in the dominoes, and then put a good amount of glue on the exposed half of the dominoes. Usually I don't put glue in the second set of mortises.
Festool Domino Joiner
I like green.
Kevin D.
Offline Offline
« Reply #6 on: February 18, 2012, 04:52 PM »
I never put glue on the Domino itself, only inside the mortise.  I use these little plastic thingies from Lee Valley to spread it on the two inside walls of the mortise.
http://www.leevalley.com/en/wood/page.aspx?p=48479&cat=1,110,42967
TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Hat, Festool T-Shirt (2), Festool Floor Mat, Festool Stein.
Wish List:  Kapex, and more sanders.
Captainwrinkles
Offline Offline
« Reply #7 on: February 18, 2012, 04:55 PM »
Well, Lamello have a quite a well designed gluing system seen here,
http://www.lamello.com/en/downloads/application-videos/gluing-system/various-nozzle-types.html
I was hoping Festool might design their own kind of system with different sized nozzles to suit the varying size of domino joints  Poke
However, an old school worker that taught me as i was a young apprentice, used short lengths of Cane (reed spline ) seen here - http://www.rockler.com/product.cfm?page=1701&filter=reed%20spline
He would cut them about 200mm long (8 inches) and bang one end on the bench to splay
the end out. Then by dipping that end into a pot of glue, he could then apply glue to dowel holes (or in this case Domino joints).
So far this is the beth method I've used to get glue into dowel holes, domino joints with a good coverage inside the holes
Try it for yourself.
Benn
Captainwrinkles
Offline Offline
« Reply #8 on: February 18, 2012, 05:05 PM »
Oh i forgot to mention. He also had the glue in a little plastic container with a lid on the top. a hole slightly
larger than the cane was cut into the top of it, so that every time you dip your cane into the glue then pull it back out through the hole,
you get enough glue on the end of the splayed cane stick without having to wipe it on the side of a container to get the excess off  Smile
Worked every time
Jerome
Offline Offline
WWW
« Reply #9 on: February 19, 2012, 01:29 AM »
Regards,
John
Jesse gives the best advice. One of the Mags did a test with a glass plate
Glue on tennon only
Glue in mortice only
Glue on both
The result was very clear that glue on both was the best way. Neither of the first 2 gave an even coating.
Glue on tennon only: = joint glue starved at the bottom, glue scraped off by mortice, lots of squeeze out.
Glue in mortice only: = joint glue starved at the top, glue scraped off by tennon, no squeeze out.
Glue on both: = good glue coverage, little to no squeeze out.
Jerome
TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone.
Wish list WoodRat, Workshop supplies drum sander
http://www.flickr.com/photos/nui-jerome/
Jason Kehl
Offline Offline
« Reply #10 on: February 19, 2012, 08:39 AM »
Thanks guys, I will experiment some. A little surprised that putting glue on the mortise and dommino would result in no squeeze out though. I can't see how that would work when coating either surface results in excess glue.
j
Jerome
Offline Offline
WWW
« Reply #11 on: February 19, 2012, 09:24 AM »
j
Because when coating the tennon only people use a lot to, try to use enough. Sure if you do that you will get squeeze out. However I didn't say "no squeeze out" I said little to no squeeze out. I don't remember exactly where I saw the video, it may have been fine woodworking magazine. However if you can find it they had 3 mortices with a glass plate forming 1 face the Results were as I said.
If you use enough in the mortice to get squeeze out, with a tight fitting tennon you can get a hydrolic lock that can split you wood or force the joint apart.
Jerome
Trosey
Offline Offline
« Reply #12 on: February 19, 2012, 01:59 PM »
I use a glue/acid brush and apply glue to both the mortise and the tenon/domino. I give the brush a hair cut before using...i.e cut off about half the bristles. I find that this reduces the amount of glue that the brush will hold. I squeeze a big glob of glue on a piece of cardboard and then dip the brush into the glue as needed.
I make my parts appear as if they were integral tenons.  When gluing the domino in these parts, I can use a "damp" rag to remove any excess glue from the shoulder of the tenon and can get into the corners with a dry brush.  In other words, I glue the domino into the slats, aprons, stretchers, and etc. and lay those parts aside.
This method makes dry fitting easier for me. Only one part is moving instead of multi-parts. And only half as many joints to apply glue during glue up and clamping. This probably takes longer but it reduces stress for me and most of the excess glue is on rags and cardboard in the trash can.
HTH
Trosey
jacko9
Offline Offline
« Reply #13 on: February 19, 2012, 02:16 PM »
I agree with Trosey.
"I make my parts appear as if they were integral tenons.  When gluing the domino in these parts, I can use a "damp" rag to remove any excess glue from the shoulder of the tenon and can get into the corners with a dry brush.  In other words, I glue the domino into the slats, aprons, stretchers, and etc. and lay those parts aside."
I add glue to the slot area using a this piece of wood that allows me to spread the glue to the mortise side walls and then I "lightly" add glue to the tenon sides. I do the same as Trosey and assemble one half of the joint and clean off the excess glue.  I find that this process allows me a much easier final glue up of multiple joint assemblies.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #14 on: February 19, 2012, 04:40 PM »
Any tips out there?
jas
I see this discussion coming up frequently, and not just for Domino. My strong recommendation is to stop trying to prevent squeeze out. The thinner you apply your glue to the surfaces, especially when you coat both pieces with a very thin coat, the faster that glue will skin over before mating the pieces. This is the number one reason why so many woodworkers complain about not having enough open time to assemble a series of joints.
Be liberal with your glue application and clean it up afterward. If it is a flat joint, then wait about 30-45 minutes and scrape it clean. If it is a corner or tight area, then wipe it with a clean wet rag (constantly rolling the rag to a clean area).
One tool that you will never find in my workshop is a glue brush. It creates too thin of a layer of glue. When I wish to spread the glue, I either use my finger for a small joint, or a plastic card scraper for larger ones. When I am gluing panels, I just lay a bead of glue toward the top corner (so gravity lets is spread some) and let the positioning and compression of the workpieces spread the rest.
Oh, P.S., The only issue with tenons is using too much glue and getting hydraulic lock, where the glue in the bottom of the mortise cannot escape past the tenon. There is plenty of room at the bottom of a Domino mortise, though, so you really have to flood the mortise for this to be an issue.
« Last Edit: February 19, 2012, 04:43 PM by Rick Christopherson » Logged
Jason Kehl
Offline Offline
« Reply #15 on: February 19, 2012, 09:11 PM »
All good info guys, thanks. It is squeeze out in corners that I find most irritating, flat surface clean-up is usually fast and easy.
Rick; after cleaning up the fresh glue with a wet rag do you end up having any issues at all when applying a finish? I am thinking of slight discoloration or any other anomalies when staining or clear coating. If the wet rag cleanup has no real drawbacks then I would likely use this approach as I don't have to be too stingy with the glue, get a strong joint, and not take too long doing it. A win-win situation in my mind.
j
jacko9
Offline Offline
« Reply #16 on: February 19, 2012, 09:39 PM »
j
Jason, While I use the wet rag method myself, there are others like the folks at Fine Woodworking.Com that caution against using a wet rag that might dilute the glue in the joint.  I'm not sure that I agree with this but, it is some "experts" opinion.  I haven't had any issues with clear finishes if I'm careful with wiping the glue away with a wet rag and like Rick suggests keep a fresh edge doing the wiping.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #17 on: February 19, 2012, 10:35 PM »
j
No, as long as you are not smearing a big puddle of wet glue with a dry rag, there is no issue with discoloration. As I wipe forward, I will roll the rag backward so fresh rag is always acting on the surface. After one short swipe, I find a new clean area of the rag to use.
As for FWW saying it could weaken a joint, I have never read the article, but I would personally whack the author with the stupid stick for such an ill thought out comment.  Big Grin Even if you poured a bucket of water over the workpiece, the water couldn't penetrate deep enough into the wood to hamper the joint.
I use both scraping and wiping methods equally, depending on the conditions. For panel glue-ups, I tend to favor scraping. However, I have an old wooden handle Stanley scraper that you just can't find any more. (Oh....I just remembered I have a picture...I'll go find it.) This scraper will actually flush the joint at the same time as it scrapes glue. I have enough control that I can perfectly flush a solid-to-plywood joint without fear of ever blowing through the ultra-thin veneer of exotic plywoods.
The pictures below are from a 2-1/2" thick work bench joint, where we had 100 year old 16" wide planks to work with.
Trosey
Offline Offline
« Reply #18 on: February 19, 2012, 10:56 PM »
I must have made a mistake about what the OP asked about. Embarassed
I thought the question was "Dominoes and glue squeeze out"!
If the concern was about edge gluing a bench/table top, then I agree with Rick. Let the glue go wild and grab the ole paint scraper and get after it.
I still use a "damp" rag instead of a "wet" rag.
YMMV
Trosey
wood pulp
Offline Offline
Each another's audience...
« Reply #19 on: February 19, 2012, 11:00 PM »
I don't mean to hijack this thread and go off on a tangent but I am looking to purchase a Domino and have really just started to familiarize myself.  This is a question I myself would have asked so here is another...  Are clamps not necessary with the Domino?  Not to sound stupid but do the Dominos just fit that tight??
Thank you,
Marc
Jason Kehl
Offline Offline
« Reply #20 on: February 19, 2012, 11:23 PM »
Thanks Rick.
I will try gluing as I have been, and dealing with the excess as you suggest.  The end goal was/is to quickly obtain a strong joint (maximizing the usefullness of the Dominoe) that is ready for finish, with no surprises. It seems as though my initial goal of avoiding squeeze out may not have been as good an approach as simply finding a better way of dealing with it when it happens.
Marc;
The Domino is an excellent tool, I would not want to do without it after getting used to the speed, accuracy and convenience of it. It was my first Festool and it has been a very slippery slope ever since. You still need to clamp the joint to have everything pulled tightly until the glue sets up.
j
Jesse Cloud
Offline Offline
« Reply #21 on: February 20, 2012, 01:04 AM »
Marc,
The Domino fit is very tight, and yeah you could probably get by without clamping, but I always clamp.  By the time I get to glue up, I have put a lot of effort into a piece and its just not worth the risk to do without clamps.
I can say for sure that you can dry fit a piece with dominoes and it will hold together indefinitely while you pick it up, turn it over, etc.  No need for clamps there and that's huge for me.
Curious to hear if others have the same view.  Anyone out there routinely do domino glue ups without clamps?
Rembo
Offline Offline
« Reply #22 on: February 20, 2012, 02:00 AM »
Here, I suggest to the option as to avoid extrusion of the adhesive http://festoolownersgroup.com/festool-tool-reviews/domino-xl-hits-the-us/90/
ScotF
Offline Offline
WWW
« Reply #23 on: February 22, 2012, 12:37 AM »
I agree that you do not want to starve the joint and use an adequate amount of glue...I spread all side of the Domino and on the inside of the mortise walls...if you put glue on the lower half to 1/3rd of the Domino, it will spread itself nicely when you insert it into the mortise and limit the amount of squeeze out.  I then usually take any excessive squeeze out and apply it to the expose Domino, add more if needed, apply glue to the mating mortises and assemble.  I always use clamps -- sometimes you need them just to squeeze the assembly together and it is cheap insurance.  A razor blade works great to get any squeeze out our of corners and tight areas and follow with a damp cloth.  This can raise the grain so you may have to go over the piece with your finish sander to smooth everything out -- my tool of choice here is the DTS400.  This is what works for me.
Scot
USNavyChiefRet
Offline Offline
« Reply #24 on: March 16, 2012, 05:09 PM »
I just did a glue up of 3 boards for a table top using the Domino joiner. I spread glue along each joint face with a little inside the mortise on each board. Then I inserted the dominoes into the mortises on the first board and utilizing the same glue brush I spread the excess that squeezed out on the protruding dominoes then fit the two boards together. I had some squeeze out but not anymore than if I was using biscuits. I try to get the majority of the glue from the squeeze outs off both sides of the boards using a rag before it has a chance to dry. Once dry, what remains is normally quite easy to remove with sandpaper. Then once I'm done sanding, or so I think. I wet the surface with either water (if using a water based stain) or mineral spirits (if oil based), looking at the surface with a light on it. This usually allows me to detect any leftover glue so I can sand it off prior to staining. Hope this helps.
Captainwrinkles
Offline Offline
« Reply #25 on: March 17, 2012, 09:24 AM »
Just curious if Festool would ever offer a pre-glued line of dominos as is already available in dowel form.
http://www.wood-dowel.com/store/10645-6mmx30mmpre-glued-dowel-pins.html
Could make it faster, easier and smarter, And in relation to glue squeeze out, cleaner too  Wink
Zacharytanner
Offline Offline
« Reply #26 on: March 18, 2012, 12:57 PM »
Captainwrinkles ...I followed the link but how do you get the glue to activate??
Thanks,
Frank
Festool Kapex KS 120EB w/ 4 Blades
Domino DF500 Set
Domino DS Systainer 4,5,6,8,10
TS55 w/ FS1400 and FS2700 Rails
MFT/3 with Accessories
CT33E
D36 Tradesman
Trion PS300 Jigsaw
RTS 400 EQ Orbital Sander
RO 125
125  Abrasive Systainer with , 60,80,100,120,220 Grit Festool paper
2 Systainer Carts
Festool T18+3 Kit
CXS Kit with Centrotec Wood Bits
ETS 150/3
150 Abrasive Systainer
Festool Toolie
RO 90
RO 90 Abrasive Systainer
OF 1010 Router
Frank
Captainwrinkles
Offline Offline
« Reply #27 on: March 18, 2012, 03:30 PM »
Thanks,
Frank
Its set by wetting it. so a spray or couple of drops of water in each hole is all thats needed.
jacko9
Offline Offline
« Reply #28 on: March 18, 2012, 04:05 PM »
Glue up is greatly simplified if you use the medium setting for most of your joints and carefully glue the tenon in the middle of one half of the joint.  You can clean up and glue around the tenon right away and you have half as much glue to deal with during final assembly.
Pages: [1]   Go Up
  Print
Jump to:
