Van G
Online
« on: May 07, 2012, 10:36 PM » |
FesNewb! Building a torsion box portable workbench and wanted to use the Dominos instead of dado's.
Trying to figure out how to accurately make my Domino cuts in the face of the plywood so they secure the spreaders.
Using the 4x20 Dominos on 1/2 BB Ply.
Also, I assume I only want to go into the face of the ply 12mm and the balance into the spreader?
Van G
Online
« Reply #2 on: May 07, 2012, 10:58 PM » |
Perfect. Thank you.
TomGadwa1
Offline
« Reply #3 on: May 08, 2012, 03:42 AM » |
It is real simple. Draw reference lines on the face of the plywood where you are placing your cross members. Do not reference off of the domino fence. Instead reference from the BASE of the domino. This will give accurate alignment to your cross members. Reason is the distance between the bottom of the domino plate and the cutter is constant. Just bear in mind the side from which you are referencing the plunges and your cross members will be in perfect alignment. It helps to clamp something for the base rest on as the domino shakes somewhat. I use this method with much success and come away with very accurate results. Enjoy the domino as it is a wonderful tool to use!
TS55 EQ OF1400 EQ DFQ 500 Q RO 125 LR32 SET Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Kevin Stricker
Offline
« Reply #4 on: May 08, 2012, 07:08 PM » |
That does not work well with 1/2" ply Tom as the base to cutter distance is 10mm. Nominal 1/2" ply is 12mm. If you want to reference off the base you need to use a shim or compensate to center the mortice.
Michael Garrett
Online
« Reply #5 on: May 08, 2012, 07:35 PM » |
Domniplate
CT 26 HEPA, MFT/3, TS 75 EQ, OF 1400 EQ, DF 500 SET, CXS SET, CENTROTEC INSTALLER SET 98-PC, TRADESMAN/INSTALLER CLEANING SET, DOMINO ASSORTMENT SYSTEM, LR 32 HOLE DRILLING SET, GUIDE RAIL ACCESSORY KIT, GUIDE RAIL FS 1400/2 (2), GUIDE RAIL FS 1900/2 (2), GUIDE RAIL FS 1400/2 LR 32 (1), Veritas MFT Clamping Kit, Zorbo Forstner Bit Set
Van G
Online
« Reply #6 on: May 09, 2012, 08:48 PM » |
Little confused. I think the reference video that Shane gave works in my situation.
I'm plunging into the face of 1/2" plywood and going into the edges of 3/4" sides and 1/2" spreaders.
For the sides, am I not simply setting depth to 20mm, fence to 90, and board thickness to 10mm (3/4" ply). Mark the boards, make my cuts into the 3/4, attach the base support bracket and make my cuts (vertical) with the fence against the edge of the 1/2" ply?
For the spreaders, I'm setting the board thickness to 6mm and when making my vertical cuts into the ply, use the tabs and middle line on the base on my marked line.
Sound right?
PaulMarcel
Offline
« Reply #7 on: May 10, 2012, 03:17 AM » |
Since you're using the 4x20 Dominos, you'll set your plunge depth to 20mm though it will only plunge 10mm. 4mm Dominos are awkward to offset (putting more in one side than the other).
You can use the video's technique (thanks, Shane!) to place a mortise in the side of the ply. It'll be 10mm up from your reference line if you put the base on the reference line. If you use the marks on the base that indicate the center of the mortise, you can place the Domino face down with that line through those fence marks to center the Domino. I think the latter is what you want for the mortises into the face of the sides where the 1/2" stock will be joining it.
For mortising into the middle of the edge of the 1/2" spreaders, you'll need to set the fence height to 6mm, which works on paddle fences. If you have pins, you'll need to grind a bit of the fence or put an offsetting shim under the fence.
For joining the 3/4" sides to the 1/2" ply, the best thing is to use the fence in both cases. Tip down the fence and set the thickness to 20mm; the mortise wil be 10mm down from the fence. Mortise the edge of the 3/4" sides as you usually would. To make the matching mortises in the 1/2" face, put the Domino face down with the fence registered to the edge of the 1/2" ply so the mortise is 10mm from that edge. When you join, they should be flush.
Hopefully I didn't misunderstand what you're creating...
Visit my blog for Festool adventures Shirt size: L  Twitter: @HalfInchShy
TomGadwa1
Offline
« Reply #8 on: May 10, 2012, 03:57 AM » |
Referencing off of the base of the domino does work best with 3/4 inch plywood. Why are you using a mixture of sheet goods for this project. It seems to me that using the same thickness of materials would simplify the construction process and also have a more uniform appearance.
RonWen
Retailer
Online
« Reply #9 on: May 10, 2012, 07:58 AM » |
If we work at it we should be able to totally confuse you. If you use the Domiplate set for 1/2" ply to do the edge mortises on the 1/2" ply and then same 1/2" setting for the 3/4" faces you'll have perfectly flush joints. Because the 4mm cutters are 1/2 the length of the other cutters the mortise depths are also 1/2 the setting. I could be missing what you are doing though.
