simon-burrows
Offline
« on: May 17, 2010, 08:39 AM » |
Hi thinking of buying the festool MFT with saw etc, only a bit concerned about the crosscutting capabilities, we produce mainly oak veneered MDF cabinets and I need to accurately cut the board material square, boards are only usually around 600x700mm. Can anyone confirm the accuracy of the squareness using the MFT.
Many thanks
Simon
jonny round boy
Online
« Reply #1 on: May 17, 2010, 08:42 AM » |
Simon, First of all, welcome to the FOG! The MFT is more than capable of producing square panels - there have been a couple of threads on this recently. I'll track down some links & post back, but in the meantime you could try using the search feature to find relevant posts. JRB EDIT: Here's the main thread I was thinking of - it's definitely worth reading through, and in particular watching the videos: http://festoolownersgroup.com/festool-tool-reviews/novice-hates-parallel-guides-mft-and-ts55!/
« Last Edit: May 17, 2010, 08:44 AM by jonny round boy »
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - T12 drill - PS420 jigsaw - OFK500 trimmer
Festoolfootstool
Online
The trouble with Bob is its all about Bob
« Reply #2 on: May 17, 2010, 08:44 AM » |
Hi Simon if you use the search facility you will see load of threads on the mft. its on my list of festools to buy.......  to the fog
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Peter Halle
Global Moderator
Online
« Reply #3 on: May 17, 2010, 09:02 AM » |
Simon,
The MFT/3 can absolutely be used to cut squarely on panels. The size you mentioned - 700 mm - is about the maximum that can be cut on the table according to Festool literature.
Welcome to the FOG and we look forward to your future visits.
Michael Kellough
Offline
Southern New York
« Reply #4 on: May 17, 2010, 09:26 AM » |
700 mm is the maximum cross-cutting capacity of the stock MFT-3 but you can mount a longer guide rail (1400) across the longer side of the table and increase cross-cutting capacity to over 1050 mm. With the long arm of the fence you can get extremely accurate square cuts but it's easier to adjust in the stock configuration because the outboard fence clamp block is farther out than if you change around for maximum cross-cutting.
Wood_Junkie
Offline
Location: Madison, Wisconsin - USA Member Since: Dec 2009
« Reply #5 on: May 17, 2010, 01:12 PM » |
Really the best solution is to buy two and connect them together.
WarnerConstCo.
Offline
« Reply #6 on: May 17, 2010, 01:16 PM » |
Really the best solution is to buy two and connect them together.  I am beginning to think that is a good option plus, I would be even cooler if I had 2.
Jonhilgen
Offline
« Reply #7 on: May 17, 2010, 05:35 PM » |
Check out this great little jig for guide rails for cutting dead-square parts. http://festoolownersgroup.com/festool-sales-dealer-area/re-guide-rail-speed-square-dedicated-90-for-crosscutting-and-shelf-dad-9288/I have cut up quite a few jobs with this jig and can attest to it's accuracy. Just do your rip cuts first (gang rip two sheets of like-width material) , then cross-cut (gang cross-cut similar heights)with this bad-boy and you'll be laughing at how quickly you can cut up a job. You might not need that second MFT... Jon
The more Festools I buy, the more money I earn. The more money I earn, the more Festools I buy. The more... TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
paul_david_thomas
Offline
Location: Winchester, Hampshire, United Kingdom Member Since: Aug 2008
« Reply #8 on: May 17, 2010, 06:12 PM » |
Simon,
I've PM'ed you with some pictures. If you want to know more we can chat. I'm in Hampshire.
Paul.
TS55, MFT/3x2, Domino, CMS, C12, RO150, RTS400, Kapex 120, CTL26, OF1400 & Two German Wirehaired Pointers :-) They really help !
simon-burrows
Offline
« Reply #9 on: May 18, 2010, 04:54 AM » |
Well many thanks chaps it looks like I'm going shopping, and thank you for the warm welcome.
Simon
paul_david_thomas
Offline
« Reply #10 on: May 18, 2010, 05:03 AM » |
If your going shopping and you in the hampshire area, the southern tool fair is coming up next month. I am pretty sure you will get a good deal their - or try toolsave ( http://www.toolsave-direct.co.uk/festool/), Dave their is pretty good for deals. I have never (yet) bought any festool stuff without getting something thrown in for free or getting some form of discount - they all want your money... As with most things, investigate, then CALL don't email - a bit of face to face is the best move. Let me know if your interested in an edgebander as I might be selling mine soon... Not cheap, but if your doing cabinates... They do the trick ! Paul. p.s. Put something more specific on your location - you'd get more help from people in your local area. I know I've a few guys near me and we swap tools - it's frowned on, but if you both trust each other and work on the your break it, you pay for it rule, it's fine...
paul_david_thomas
Offline
« Reply #11 on: May 18, 2010, 05:05 AM » |
This is a better link for buying... http://www.toolfair.uk.com/Have to say, I've not been to this. Equally, not sure how good a deal you will get as some people are tempted into the I can see it, buy it... But it's prob. good to get your hands on lot's of things, then go away and figure out the best prices... Take an iPhone or something with you, you can check web prices and email things whilst you are their to drive a bargin.
jonny round boy
Online
« Reply #12 on: May 18, 2010, 05:12 AM » |
If your going shopping and you in the hampshire area, the southern tool fair is coming up next month. I am pretty sure you will get a good deal their - or try toolsave ( http://www.toolsave-direct.co.uk/festool/), Dave their is pretty good for deals. I have never (yet) bought any festool stuff without getting something thrown in for free or getting some form of discount - they all want your money... As with most things, investigate, then CALL don't email - a bit of face to face is the best move. Let me know if your interested in an edgebander as I might be selling mine soon... Not cheap, but if your doing cabinates... They do the trick ! Paul. p.s. Put something more specific on your location - you'd get more help from people in your local area. I know I've a few guys near me and we swap tools - it's frowned on, but if you both trust each other and work on the your break it, you pay for it rule, it's fine... FYI the OP is in Lincolnshire.
paul_david_thomas
Offline
« Reply #13 on: May 18, 2010, 05:31 AM » |
Sorry, brain failure...
FYI - no problem OP - absolutely no idea what so ever
Please enlighten my failing brain :-)
CJ'60
Offline
« Reply #14 on: May 18, 2010, 05:46 AM » |
OP: Original Poster
AT-65 EB/1 Plus, CTL Mini, PS 300 EQ, OF1010 EBQ, Domino Set
paul_david_thomas
Offline
« Reply #15 on: May 18, 2010, 05:56 AM » |
Ah!! Stored
MTFYH
paul_david_thomas
Offline
« Reply #16 on: May 18, 2010, 05:58 AM » |
Many Thanks For Your Help... Of course !
I did a stint in the Netherlands (1 Year), Dan Haag, doing some work for the Patents Office !!
Very much enjoyed the relaxed caffee's - no, not tourist ones... The ones where you could have a nice coffee, read the paper and watch the world go by !
Wim
Offline
« Reply #17 on: May 18, 2010, 06:13 AM » |
Our coffe-shops are very relaxing.  And semi-legal. But for coffee and a newspaper without tourists you should look for a "bruin caf?", a brown bar, where you can meet the locals, shady types included.
paul_david_thomas
Offline
« Reply #18 on: May 18, 2010, 06:31 AM » |
I had an enjoyable time whilst their I have to admit. My best Dutch friend (Chris) shamed me in correcting my english. His sense of humour was the oddest I've met - he learn't his (well, improved it) by watching Black Adder videos. After I got chucked out of a place I rented (and quite rightly so) for having an Animal party - which included straw and animals, he put me up for a few months. We didn't get many early nights and samples most beers and wines...
My other Dutch friend (Jeron Van De Horn - or something similar) we managed to get banned from a local Hilton Hotel (near Baisingstoke) after we held a surprise party in his hotel room - it took 3 days to dry out, our employer at the time (IBM) got the bill, we, of course had to pay it !!
Ah... The joys of computer contracting...
Paul
p.s. I quit computer contracting 5 years ago...
mattfc
Offline
« Reply #19 on: May 18, 2010, 06:45 AM » |
Patents Office !!
The very same concrete monstrosity in Rijswijk.. by the no 17 tram?
paul_david_thomas
Offline
« Reply #20 on: May 18, 2010, 06:56 AM » |
Nooooo.... Don't say you've worked their ?
Yes, Rijswijk !! I used to drive in from where I was staying - where ever that might have been.
This was some 20 years ago however, working on the OS/2 Servers they had in the computer department. They must be Windoze or Linux now.
Do they still have the naked pool parties ? Or have times changed at the Patents office ... If you don't work their, that will certainly give you an incentive to go for an interview !
I have to say, anyone looking into this thread is REALLY going to think we have gone off subject :-)
I had some very funny times. Actually, I think it might be a bit more than 20 years. I'm 43 and I remember getting the ferry back on my 21st birthday.
jo041326
Offline
Czech republic
« Reply #21 on: May 18, 2010, 07:11 AM » |
Hi, I think you will quickly realise you need two MFTs. I went the same way. Bought TS55 with MFT and later added the second one. Unlike others here I had still some squarness problems. Tuned up the rail and after some time it was slightly off. I had to check the squarness before every batch of cutting. At the end I was so tired I have bought Hammer B3 Winner Comfort saw. Man! Why was I so fool and didn't spend the money into Hammer instead of all that MFT stuff! If I will be in your position with my current experience I'd buy some Hammer saw (for the stuff you mentioned probably Hammer B3 winner). Josef
« Last Edit: May 18, 2010, 07:12 AM by jo041326 »
mattfc
Offline
« Reply #22 on: May 18, 2010, 07:12 AM » |
I have worked in the data centre in the basement back in 1999 (a large oil company used to use it), and frequently still go past it, although I have never seen any naked pool parties there, that said my dutch collegues are pretty liberal
CJ'60
Offline
« Reply #23 on: May 18, 2010, 07:25 AM » |
MTFYH
MTFYH  Even www.acronymfinder.com doesn't know that one...
paul_david_thomas
Offline
« Reply #24 on: May 18, 2010, 09:32 AM » |
Matfc,
Would that have been to the Shell offices ? Been drunk in that place too !! Did they not have a cracking bar on the top floor or something ?
