Pages: [1]   Go Down
  Print
Author Topic: Festool Addiction  (Read 1702 times)
Danny E
Offline Offline
« on: June 20, 2012, 03:25 AM »
Here you go! Got my domino 500 today for my garage cabinet project and more & more projects that are going to be on the way.
Now, for 19 mm melamine sheets, wht tenons to be used 5mm/6 mm. Any advise pls...
TS55, CT26, ETS 150/3, LR32 System, OF1400, Domino 500, MFT3, D36, 1400 Holy Rail x2, Parallel Guides, MFK700 Set, Clamps
Kev
Online Online
« Reply #1 on: June 20, 2012, 03:31 AM »
6mm meets the "one third" guideline ...
Congrats on your new toy tool  Smile
Timtool
Retailer
Online Online
WWW
« Reply #2 on: June 20, 2012, 06:34 AM »
Yes, but i think that goes when the woods are of equal strength, it's been discussed before and some, including me, prefer the 5mm ones because those 5mm of beech are allot stronger than the remaining 14mm of chipboard. The panel will split or break less fast if it has a bit more material around the tenon!
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #3 on: June 20, 2012, 07:52 AM »
I completely agree.  Another advantage is the length of the 5mm tenons.  At 30mm you get 15mm in each, you aren't going to accidentally plunge all the way through 18 or 19mm material when mortising in the face.  If you use the 6mm tenons you'll have to remember to offset the mortises.
davee
Offline Offline
« Reply #4 on: June 20, 2012, 08:03 AM »
I also agree with the 5mm for stregth, and also Brice's comment about 15mm plunge depth is right on.  It only required a few missed depth settings to make me look at each setting closely before plunging.  It also makes interesting patterns in your work bench or MFT.
ScotF
Offline Offline
WWW
« Reply #5 on: June 20, 2012, 10:23 AM »
I also agree with 5mm and I think that this is one of the reasons Festool provides the 500 with a 5mm cutter -- one of the most useful sizes for 19mm sheet goods.
Scot
Kev
Online Online
« Reply #6 on: June 20, 2012, 12:02 PM »
... or 5mm  Embarassed
Pages: [1]   Go Up
  Print
Jump to:
