Pages: [1]   Go Down
  Print
Author Topic: Festool Boom Arm rig for CT 26  (Read 2825 times)
dennylj
Offline Offline
I can resist everything except temptation
« on: February 07, 2012, 04:22 PM »
Hi Guys,
I'm considering buying the Boom Arm for the CT 26.  I have a basement shop where head room is an issue if the boom arm is 7' high from floor level.  I have only 80 inches clearance under two steel beams in my basement so that moving the CT with boom arm around the basement would be problematic.  If the boom arm would be 4 inches shorter, i.e., instead of 7' high it could be reduced to 6'8", problem would be solved.  I had a look at the boom arm assembly at Lee Valley here in Ottawa and it appears feasible to cut 4" from the vertical tube where it meets the base of the CT.  Anyone have/had a similar problem?  Is it possible to do as I suggest?
Cheers,
Denny
Denny
Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
DKurzweil
Offline Offline
« Reply #1 on: February 07, 2012, 04:38 PM »
I had a similar problem a few weeks ago when I got the boom arm.  I measured my ceiling but forgot the drop down of the beam that runs right through the middle of my shop.
The boom arm was only about 1/4" too high so I cut off a full inch from the bottom.  I used a heavy duty tubing cutter to get a clean burr free cut.  The only other modification I made was to drill a hole through the bottom of the tube, and the plastic holder it rests in. I stuck a 3/16" bolt through.  This prevents the tube from rotating freely and seems more secure to me than the little tab that festool originally had on the bottom.
Hope this helps,
Daniel
Addiction includes TS75, OF1010, Domino 500, RO150, T-18 set, CSX, LR-32 set, CT48 and CTMidi
dennylj
Offline Offline
« Reply #2 on: February 08, 2012, 10:01 AM »
Thanks Daniel.  Comforting to know that cutting the tube doesn't compromise the integrity of the boom arm.
Cheers
Denny
Denny
DKurzweil
Offline Offline
« Reply #3 on: February 08, 2012, 02:53 PM »
Not a problem.  Just be sure to prevent free rotation of the tube by either through bolting as I explained or by some other method.  If you need any help or a better explanation of what I mean by that just let me know.
Best,
Daniel
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #4 on: February 08, 2012, 03:00 PM »
I had the same problem with a low central structural support member in my basement shop and had to cut 5" out of the top of the lower tube to get things to fit under that member.  A Sawzall with a hacksaw blade, followed by a 4 1/2" grinder, took care of the removal necessitating only the re-drilling of the lower tube to accommodate the through bolt.  It worked fine.  Now if I ever move from here, I can replace the lower tube if I feel like it and be back to standard height.
 Smile
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
festoolviking
Offline Offline
« Reply #5 on: February 08, 2012, 04:13 PM »
The other day I made a cheap mock up boom-arm for my MIDI. I had some scrap alloy profile lying around, some plywood, a 50mm PVC pipe and two joints for the pipe. One joint fits perfect in the vac and the other one fits the hose. I've got a small shop with a low ceiling, just short of 2 meters. Luckily I'm not a basketball-player Smile. This works fine for me.
Mock up Boom-Arm
Close Up
Festoolviking
TS55, C12, PS300, ETS 125 EQ, CTL MIDI, OF1010, EHL65, DOMINO DF500, OFK 700 EQ, RO 90 DX FEQ, MFT/3, CTL26E, BS75E
I'm not young enough to know everything!
It's good when it's better but it's better when it's good!
GPowers
Offline Offline
Metric convert
WWW
« Reply #6 on: February 08, 2012, 05:19 PM »
Nice home made boom for limited head room.
Greg Powers
dennylj
Offline Offline
« Reply #7 on: February 08, 2012, 05:23 PM »
Clever piece of work, Festoolviking!  Thanks for posting the pictures.
Denny
Denny
dennylj
Offline Offline
« Reply #8 on: February 08, 2012, 05:26 PM »
Thanks for the post, Sparktrician.  I'll give  your method a try.
Daniel, I understand your point about drilling a hole through the tube and seat to accommodate a bolt to prevent the boom arm from swinging unrestricted.
Cheers,
Denny
Denny
GreenGA
Offline Offline
JR
« Reply #9 on: February 08, 2012, 09:05 PM »
That is one nice, well laid out shop, FestoolViking.  You take excellent advantage of what little space you have.
I am impressed. Thumbs Up
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Mock up Boom-Arm
Close Up
Festoolviking
Never use a 2x4 when a 2x6 will do just as well
SYS-Lite, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, TI 15 Set, C12 Set, CT48 w/Boom Arm, HL850, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino Classic, OF1010 EQ, OF2000E+, OF1400, MFS700, LR 32-SYS+97" rail, 2011 Centrotec, Zobo Forstner Bit Set, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sorts, Attics, Classic, New and Blue).
Coming Attractions: MFK700 Kit, Workcenter, Domino XL Kit, Carvex 420 & Accessory Kit
Dave Reinhold
Festool Dealer Affiliate
Offline Offline
« Reply #10 on: February 08, 2012, 09:25 PM »
Nice tips on cutting one of the poles to lower the boom arm height. I'm planning on picking up the boom arm ant ct26 before the price increase.  I was hoping to be able to fit it in my work truck which has a 6' stand up height inside. How easy is the boom arm set up to take apart?
Dave
check out www.youtube.com/user/DaveReinholdTV for new tool demos every week
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #11 on: February 08, 2012, 09:29 PM »
Dave
Dave, don't cut it.  You can pop the upper section of the boom off super easy for transport.
Dave Reinhold
Offline Offline
« Reply #12 on: February 08, 2012, 11:24 PM »
Thanks Brice. I'd rather not cut it at all.
Dave
Pages: [1]   Go Up
  Print
Jump to:
