Author Topic: Help finding Kapex Armature Replacement Guide  (Read 1879 times)
Offline glass1
Re: Help finding Kapex Armature Replacement Guide
« Reply #30 on: February 12, 2019, 06:12 AM »
Interesting. Different service for different folks.
Offline Peter Halle
« Reply #31 on: February 12, 2019, 06:56 AM »
Here is information I received in response to a question I sent to Festool:
“The two part numbers that you referenced are:
A)   The individual armature only (203553)
B)   the end shield (203552) which has the armature noted above and all associated components assembled into one assembly
The Difference:
One might purchase the end shield if they do not have the appropriate fixture, tools, and test gauges to remove as well as press bearings and the other components included.”
The current US cost for the armature is $162.04.  For the complete assembly - $167.64.
Offline Peter Halle
« Reply #32 on: February 12, 2019, 07:01 AM »
Perhaps at the time Tom ordered his there was only an assembly.  Or perhaps there was a back order and there was a part substitution.  Or someone accidentally sent the wrong part whereas the part numbers are so close.
But here is one certainty:  Tom would not have asked for preferential treatment.  Tom does favors for people and does not expect anyone to do anything special for him.
Offline Gregor
« Reply #33 on: February 12, 2019, 08:14 AM »
The $5 difference should be a no-brainer.
Offline RKA
« Reply #34 on: February 12, 2019, 09:10 AM »
Thanks Peter!!!  That’s incredibly helpful!  I’m putting the extra $5 in the cookie jar, seems worth it!  [smile]
-Raj
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #35 on: February 12, 2019, 09:23 AM »
I'll explain how this went about;
We burnt up 2 MFK-700's (definite router abuse). Sent them in to be rebuilt (love those routers).
Service called with quote. I said fine, fix them, while we're at it send me an armature for a Kapex, gave him one of the serial numbers, his response was, brings the total to $xxx.xx. At no point did I know what was chosen at the other end, all I know is I was getting an armature. I doubt the person the other end of the line had any clue who I was.
As you can see from the previously posted pictures, the armature is still in the box. Since I got the armature---of course a control board went out, had to order one replace that on one of the Kapex(s).
As I said previously, I'm the guy with the knowledge, tools and equipment to change the armature out. Go figure....
« Last Edit: February 12, 2019, 09:25 AM by tjbnwi »
« Reply #36 on: February 12, 2019, 09:53 AM »
Hey Tom, I'm curious what properties the Kapex displayed when the control board went south? Thanks...
Offline JimH2
« Reply #37 on: February 12, 2019, 10:06 AM »
The Difference:
It is quite the savings to purchase it that way. I missed out on that. The diagrams I was looking at showed the individual parts only, so I was looking at the other drawings.
« Last Edit: February 12, 2019, 10:12 AM by JimH2 »
Offline tjbnwi
« Reply #38 on: February 12, 2019, 10:38 AM »
A cut was made, returned to saw to make next cut nothing. No lasers, nothing. Checked circuit by switching the CT from auto to manual. CT turned on. Maybe bad CT board?????, grabbed another CT, nothing.
When I had time, pulled cover, checked power in, good there, checked power at the brush holders—-nothing.
Offline JimH2
« Reply #39 on: February 12, 2019, 11:11 AM »
I'm calling today to see if I can swap out instead of buying more parts. I'll post if I am successful. I am hoping TylerC will see this and give me a hand if need be.
Offline SRSemenza
« Reply #40 on: February 12, 2019, 11:24 AM »
   @TylerC
Offline TylerC
  • Festool USA Employee
    FOG Administrator
« Reply #41 on: February 12, 2019, 12:32 PM »
@JimH2 I received your message and will respond ASAP.
