Author Topic: How to work with sheet goods when you're space constrained  (Read 6093 times)
Offline Naildrivingman
Re: How to work with sheet goods when you're space constrained
« Reply #30 on: October 12, 2017, 06:05 AM »
@jobsworth @Naildrivingman @ear3
I think I was afraid not having a cutting surface would cause splintering in the bottom of the cut. If I'm outside maximum dust collection isn't as much of an issue. Thank you for sharing I think I'll give it a go with the sawhorses I have and some 2x etc on top.
@jobsworth I just watched the video you posted. That's probably the most helpful to me because. .that guy is basically me. Same size garage, Harley parked in the corner, mechanics tools. Thank you for sharing.
@DynaGlide
Theoretically you should not have tearout on the bottom of the sheet if your blade is sharp and the saw runs straight.  Tearout occurs when the teeth exit the surface rather than enter.  the purpose of the splinter guard on the track is to "compress" the wood fibers and minimize the uplift.  Ultimate tearout control can be achieved by running a sharp utility knife on the cut line.
I personally have not had any significant problems with tearout using the track saw.  I support the material, set the track and cut.  No tape, no razor knife, no sacrificial surface.
Dance with who brung ya...
Offline Sanderxpander
« Reply #31 on: October 13, 2017, 04:34 PM »
My sheet goods are usually not the finishing layer so I usually lay them on top of each other. I might get a minor scratch but you can get pretty accurate with the saw and stacking them that way is super stable which helps a lot with accuracy of cut. When I get to the last one I usually have enough scraps to make a decent base. Doing it that way means working on the floor a lot though.
Offline Holmz
« Reply #32 on: October 13, 2017, 07:22 PM »
Well I was cutting two pieces of melamine a while back.
One was older and heavier duty stuff, and responded to theory.
The newer stuff had a thin layer of brittle melamine and chipped out like mad.
Wood also can vary in its sheer strength versus some other deal... Basically some can be easy to cut and some can like to chip out.
Then you combine that with the saw's tracking etc.
« Reply #33 on: October 14, 2017, 12:46 AM »
Good points @Holmz
I intended to edit my comments to exclude melamine, but forgot to do so.  Melamine is a special beast in and of itself.  The best way to deal with melamine is to establish a 1 mm scoring cut followed by a finishing cut.  Still not a guaranteed chip free cut, but better than without.  The trick with a scoring cut method is to EXACTLY follow the scoring cut with the finish cut. A slight variance from the scoring cut line can result in tearout.
Thin box store veneers can behave similar to melamine and may respond well to scoring cuts, but I can't definitively comment because I don't use these materials.
Offline Holmz
« Reply #34 on: October 14, 2017, 01:30 AM »
I guess my point was that. Even with the good stuff I could not chip it.
With the crap stuff, even using the MT55's exclusive scoring cut... it was chipping like mad everywhere else.
Then with wood it can vary as well.
It is like a post complaining about X, and everyone else says I have no problem with X.
It does not identify anything helpful to the user other than maybe (s)he is the problem... When it could just be the material.
But I like theories in general... (More than specifics) So I liked your post that I responded to.
Offline Holmz
« Reply #35 on: October 14, 2017, 05:37 AM »
Well 2 sheets of MDF and > a sheet of offcuts worked this afternoon.
https://flic.kr/p/Znsgsm
(Then took to the area with the leaf blower)
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #36 on: October 14, 2017, 08:49 AM »
At the risk of having this post deleted;
Set rail
Clamp in place (I use Geckos on melamine)
Set saw to 0.5-1mm depth of cut
Run saw backwards on rail to score cut
Adjust to proper depth
Finish cut
Offline demographic
« Reply #37 on: October 16, 2017, 02:42 PM »
Whilst a Paulk style tracksaw table would be a very nice thing to have much of the time its just not needed.
I usually setup with two sawstools set about five feet apart.
Two lengths of 2x timber (can be 2x2, 2x3 or 2x4, it doesn't really matter and make them at least 1800 mm long but 2400 is better set as wide apart on the sawhorses as I can which on mine is mebbe 800mm apart.
Then across the 2x timber I have four or five bits of either timber, plywood or even MDF about 1200 long.
All that ^ setup allows me to fit my CTM 26 extractor between the sawhorses and under the top without any risk of the blade cutting so deep as to cut into my extractor.
That all supports the stuff I'm cutting as well as I need it.
I hardly ever bother with the clamps when I'm cutting as the track grips well enough for almost any cutting I do, the exception to this is when I'm cutting faced bathroom boards which cost eighty or so quid and it would be embarrassing if I knackered one.
Offline J0hn
« Reply #38 on: October 16, 2017, 10:39 PM »
Dewalt makes these saw horses.  They have adjustable legs, but more importantly, they have a couple of notches at the top that will firmly hold a couple of 2x4's on edge
http://www.homedepot.com/p/DEWALT-33-in-Folding-Sawhorse-with-Adjustable-Metal-Legs-DWST11031/203040645
A couple of 90" 2x4s to fit into the notches and to act as the main support and then several 30" 2x4's as evenly spaced cross pieces.  All the 2x4's are simply notched so they fit together without any hardware
