Author Topic: Is there a paint stripping brush for Rotex RO 125?  (Read 2475 times)
Offline PaulH99
« on: July 16, 2017, 08:48 AM »
The paint is flaking off of my old shed. I'd like to "finish the job" by mounting a brush to my Rotex instead of sandpaper. I haven't seen anything like this on the Festool USA web site. Does this exist? Or should I get brush/disc for my old angle grinder instead?
-Paul
CT 26 • DF 500 • ETS 125 • KS 120 • OF 1400 • PS 420 • RO 125 • TS 55 R
Offline antss
Re: Is there a paint stripping brush for Rotex RO 125?
« Reply #1 on: July 16, 2017, 12:57 PM »
No 'brush" that I know of, but Saphir discs were tailor made for this type of thing.
Problem is, it has been discontinued.  You can still find some stock online though.  Uncle Bob might still have some too.
Offline PaulH99
« Reply #2 on: July 16, 2017, 05:27 PM »
Good to know, thanks. I'll probably go with something like this on my old angle grinder to get the job done. Vacuuming up the mess will be a pain though!
-Paul
Offline leakyroof
« Reply #3 on: July 16, 2017, 05:44 PM »
. Saphir has been discontinued in 125mm size?
Offline antss
« Reply #4 on: July 16, 2017, 08:39 PM »
Sorry - it's Cristal that's been axed.  It was good at removing paint too.
Offline leakyroof
« Reply #5 on: July 17, 2017, 10:17 AM »
  Right, that, I knew about.....  Saphir being lost would have been a bad surprise. [eek]
Offline Pnw painter
« Reply #6 on: July 18, 2017, 12:38 AM »
I've had excellent luck using 36 grit Sapphire on my RO125.
Although I haven't tried it, I think the Diambrush for Wood Deck and Siding would work very well when attached to an angle grinder. I've used their concrete version and I was very impressed.
http://www.homedepot.com/p/Diamabrush-4-5-in-50-Grit-Wood-Deck-Tool-9304501240-50/206926302
Offline PaulH99
« Reply #7 on: July 18, 2017, 05:50 AM »
That Diamabrush looks serious! I'll check it out in our local Orange Borg. I may end up doing this in two stages: The brush on an angle grinder to clean up the worst of the mess, then the Sappire 36 on my RO 125 to finish the job.
-Paul
Offline The.Handyman
« Reply #8 on: July 18, 2017, 09:28 AM »
I suggest the Metabo LF724S 3-1/7-Inch 11,000 RPM 6.4-Amp Paint Stripper. Works excellent.
