Author Topic: Kapex blade help  (Read 2556 times)
Offline Trevin
Kapex blade help
« on: May 02, 2017, 07:35 PM »
Looking for a blade to cut a few pieces of 80/20. Any recommendations?  I use my dewalt miter saw for some previous cuts but no longer have it.
Thanks,
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline rst
Re: Kapex blade help
« Reply #1 on: May 03, 2017, 10:04 AM »
Amana/AGE sell aluminum blades that will fit the Kapex.  I do not have a kapex but I buy blades for my 55,75 ,HKC, and Makita sliders from... toolstoday.com/p-6095-festool-and-other-track-saw-machine-compatible-saw-blades.aspx
Offline Mrpilfup
« Reply #2 on: May 04, 2017, 07:13 AM »
I cut a reasonable amount of Aluminium on my Kapex. Dont forget to use a wax stick on the blade with the 80/20 and adjust the blade speed. An aluminium blade (Negative Rake)  is a must to reduce the chance of catching the extrusion and destroying the material, the saw and more importantly body parts.
Offline tdc
« Reply #3 on: May 04, 2017, 10:24 AM »
Could you elaborate a little more on the wax stick? I have waxed hand saw blade in the old days - but never heard of it for aluminium.
Offline rst
« Reply #4 on: May 04, 2017, 10:35 AM »
I do contract glazing, have literally cut miles of aluminum for the last 37 years.  We buy WD-40 by the gallon and use it in cheap plastic spray bottles.  Start your blade running and sparingly squirt some on the spinning blade.  When I started, a long, long, time ago   we used wax sticks and Craftsman crosscut carbide blades.  Now I buy Amana Blue aluminum/plastic blades and unless I'm cutting 3/8" or more I don't even bother with the WD-40.  You can really use any high tooth count carbide blade, but negative tooth rake is the best...the aluminum/plastic blades have a higher rake angle than even the melamine blades.
