Author Topic: Max thickness of material to cut with Kapex aluminum blade  (Read 5595 times)
Offline ear3
Been looking for an excuse to get the aluminum blade for the Kapex, since I don't do a lot of metal cutting in my work:
http://festoolusa.com/power-tool-accessories/miter-saws/blades/aluminum-plastic-68-tooth-saw-blade-495385
I might have one now.  I got from McMaster Carr some 14mm (9/16) hexagonal shafts to make extended versions of the LR32 stops, as discussed in this post:
http://festoolownersgroup.com/festool-jigs-tool-enhancements/lr-32-extensions/
So the question is what is the max thickness of solid aluminum I can cut with the Kapex aluminum blade, and whether  the 14mm shafts are under that limit
Offline TOOLTOWN
  • Festool Dealer
    • tooltown.com
Re: Max thickness of material to cut with Kapex aluminum blade
« Reply #1 on: April 03, 2016, 05:38 PM »
Go slow and you should be fine.  I've cut 1 or 1.25 inch solid bar stock with the Kapex and an aluminum blade.  I'm not sure an exact limit.
Don't forget to debur / knock down the sharp corners after.
Ken
Offline rst
« Reply #2 on: April 03, 2016, 06:46 PM »
I also cut very thick aluminum frequently, I use WD-40 sparingly as a lube and am careful not to force the cut.
Offline Svar
« Reply #3 on: April 03, 2016, 06:59 PM »
There is no max thickness. You can cut through anything blade size allows. It'll be just slow.
Offline ear3
« Reply #4 on: April 03, 2016, 07:36 PM »
Good to know. Thanks.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #5 on: April 03, 2016, 07:38 PM »
Festool sells a spark arrestor, or maybe not, so be careful with hot metal in a saw dust bag.
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #6 on: April 03, 2016, 08:28 PM »
Edward, since you don't cut metal often you might want to look at a cheaper blade, Oshlun SBFT-260068A 260mm 68 Tooth FesPro Non Ferrous TCG Saw Blade with 30mm Arbor for Festool Kapex KS 120, Amazon.  I have no experience with this blade so I can't comment on the quality.
Offline rst
« Reply #7 on: April 03, 2016, 09:03 PM »
Aluminum is non sparking as it is a non ferrous metal, along with brass and copper.  I use an Amana aluminum/plastics industrial blade that cuts so clean I usually do not need to file the cut edge.
Offline #Tee
« Reply #8 on: April 04, 2016, 01:22 AM »
Ive cut titanium which is a non ferrous metal and it throws white sparks. Ive also cut mild steel tube and alum as well. make sure the stock is clamped on good and turn the speed to 1-2 and go slow.
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline Holmz
« Reply #9 on: April 04, 2016, 04:16 AM »
I thought I was the only one cutting Titanium.
Used a jig saw, and it was jumpin and a dancin.
Aluminium is a lot easier. I cut the Ikea curtain stuff like butter with the jig saw.
Should be easier with a Kapex (??).
Offline ear3
« Reply #10 on: April 04, 2016, 06:55 AM »
Good idea.  I think I'll go that route.
Online Bohdan
« Reply #11 on: April 04, 2016, 07:21 AM »
The spark arrestor is really required if you sand some rust which gives you iron oxide and then add aluminium dust. The resultant mixture is known as thermite and burns at over 4000°F.
Offline ear3
« Reply #12 on: April 04, 2016, 07:53 AM »
Festool discontinued the spark arrestor in the States.
Offline GarryMartin
« Reply #13 on: April 04, 2016, 07:58 AM »
I've bought a £40 ($57) mitre saw specifically for cutting metals. The TCT multipurpose blade makes clean cuts through steel, aluminium, plastics and even nail-embedded wood, and the whole unit is cheaper than a Kapex blade. It retails at £70 normally, but frequently drops to £50 and I grabbed one in a Amazon 20% off deal.
http://www.amazon.co.uk/Evolution-Rage3-B-Multipurpose-Mitre-Saw/
I don't think I'll ever cut anything that will take advantage of the precision of the Kapex, so it's an easy call for me. It also means I don't have to clean the aluminium or plastic off the Kapex as it's somewhat more difficult to do than dust!  [wink]
Just thought I'd mention it as another potential option, i.e. a dedicated saw.
Offline ear3
« Reply #14 on: April 04, 2016, 08:02 AM »
Oh well -- I gave my old Ridgid mitre saw to my neighbor (along with some older Dewalt tools).  At least I never have to feel guilty about asking him to water my garden when I go on vacation.
Online Bohdan
« Reply #15 on: April 04, 2016, 08:07 AM »
Probably not a big seller.
Offline waho6o9
« Reply #16 on: April 04, 2016, 10:32 AM »
That's what I did and the Evolution saw works well and sometimes it's called a cold saw.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #17 on: December 01, 2017, 12:31 PM »
I am about to do some metal cutting with the Kapex. Can anyone advise me what lubricant I might use? I am in the UK and so some branded products may not be available but a general description like "light oil" or "old wax candles" would be helpful.
I understand the risk of either sparks or hot chippings and have a strategy to deal with that.
Many thanks.
« Reply #18 on: December 01, 2017, 12:47 PM »
I've used different forms of wax in the past. Others on the FOG have used WD 40.
Offline aloysius
« Reply #19 on: December 01, 2017, 04:41 PM »
An ordinary household bar of soap also works well as a lube.  The higher tallow content of laundry varieties (Velvet, Sunight etc). seems to last well on the cutting edges.  It also works with bimetallic holesaws, HSS drillbits & even hammer-driven framing nails & lag screws too.  Lower rotation & feed speeds will assist progress.
« Last Edit: December 01, 2017, 07:20 PM by aloysius »
FOG-wit since '95:  Some say since birth...
Offline sospan
« Reply #20 on: December 01, 2017, 05:35 PM »
You need to exercise a bit of caution when using WD40 as a lubricant when cutting metals. WD40 has a flash point of around 122 F (49°C)  :)
Offline Svar
« Reply #21 on: December 01, 2017, 06:03 PM »
I thought of that too, yet metal shops use it routinely to cut aluminum with no ill effects. I used it myself a lot and I'm sure the temperature in the cut well acceded 49°C. I don't have an explanation for this. Not sure if the same is true for ferrous metals.
Offline skinee
« Reply #22 on: December 01, 2017, 06:34 PM »
trend have a lubricant especially designed for this in stick form,i have used it,it works well, but centrifugal force tends to spit quite a lot of it away from the blade,may stick better than fluid anyhow.
https://www.trenddirectuk.com/trendiwax
« Reply #23 on: December 01, 2017, 09:08 PM »
That’s the reason I prefer the waxes, a small amount of wax is manually deposited on the blade and as the blade heats up and the object to be cut heats up, the wax melts and deposits itself on both items and provides lubrication. It’s a pretty clean operation with minimal mess.
Offline bwehman
« Reply #24 on: February 13, 2018, 09:54 AM »
Is the aluminum blade for the Kapex no longer available in NA?
Offline rst
« Reply #25 on: February 13, 2018, 10:05 AM »
I've cut literally miles and miles of storefront aluminum in the last 38 years with WD-40 and buy it by the gallon.  As far as flash point...aluminum is non-ferrous, therefore, no sparking.  That being said, the aluminum I'm cutting is generally anodized, which can give minute sparks but again has never been an issue.  Does make the guy that welds for us crazy though.
In regard to thickness, as a general rule, aluminum blades for cutting over 1/8" are generally thicker.  I use 80 tooth blades for everything and really only lube for 3/16" and up.  Don't cut without a backer board, aluminum and plastics will really screw a blade if one of the teeth gums.  Take light cuts so as not to fill the gullet.  Toolstoday sells Amana and AGE (German) blades for aluminum, including all Festool sizes includng the Kapex.
« Last Edit: February 13, 2018, 10:12 AM by rst »
Offline Peter Halle
« Reply #26 on: February 13, 2018, 10:08 AM »
I believe so.
« Reply #27 on: February 13, 2018, 10:18 AM »
The aluminum blade for the Kapex and track saws was taken off the US market last summer. The blades are still available in other countries.
« Reply #28 on: February 13, 2018, 11:57 AM »
It is a pity that the Aluminium blade is no longer available in the US. I used one recently and found it to be perfect for aluminium and I even tried it with brass and copper.
