First o answer the post, why place an OF1400 in a table at all, it for hand use, not table use. It;s not the best way to spend money nor the best use of this particular router.
For 1150.00 you can get a little Jet 1.5hp shaper that uses an induction motor and has a reverse. It will blow away any router table(and can be used as a router table) for making raised panel. It can use router bits and shaper cutters. It even uses 1/2" and 3/4" spindles.
So when I see people dropping 1500.00 on a router table(I have done so many times) to do raised panels I kind of tilt my head. Once you run a raised panel through even this little shaper you won't go back to even the largest of routers. That quiet hum and low end power just can't be beat of the induction motor. The 1.5hp induction motor, IMHO, blows the 3.5hp universal router motors away and puts them to shame, for use with the larger bits especially. And let's not get to the 3HP shaper tables of course that is the way to go if you have the cash for raised panels.
Of course I have had both shaper tables and router tables and each has their use, but if I could have only one and had only 1200.00, I would take a long hard look at that Jet 1.5hp shaper. Of course it has to stay in the shop but it's footprint is very small. I even made a larger table for mine. I think Shane sells these little shapers.
I had good luck with my Jet, some other reviewers didn't like theirs. Shop Fox makes a 2HP for even less at 1050.00 that seems to get nicer reviews as well. 1134.00 including shipping for a 2HP induction motor shaper table, it seems like a steal and the table top seems larger than the Jets. Unless it simply doesn't turn on there is no way possibly it isn't far better than any router table for raised panels.
http://www.grizzly.com/products/2-HP-Shaper/W1674?gclid=CjwKCAjw_dTMBRBHEiwApIzn_OxWbxB9nSRATIVMwO3k48IniA8itml-pVnsY-yWfcy31Tb5kcDDABoCi_AQAvD_BwE&utm_campaign=zPage&utm_source=grizzly.comSay all you want about Girzzy or Shop Fox, this is still better for the same cost as any router table, especially for the larger bits like raised panels..
