Author Topic: New training videos from Sedge  (Read 42902 times)
Offline TylerC
  • Festool USA Employee
    FOG Administrator
« on: April 19, 2017, 05:01 PM »
A lot of you know Festool trainer Brian "Sedge" Sedgeley. He's starting posting minute-long videos of Festool tips and tricks. They're on Instagram, but you can watch them online without an account. For a lot of you long-time Festool folks, many of these will be old hat, but there's lots of good stuff here.
He's posting a new video each Monday and Friday.
You can see them all here:
https://www.instagram.com/festoolsedge/
Here's a few of my favorites:
How to increase the tension on your clamping elements: https://www.instagram.com/p/BR0t4iaj2GI
How to automatically shut off your ETS EC if the hose falls off: https://www.instagram.com/p/BSbbKY2DiSv/
How to align your DOMINO mortises on a crosshair: https://www.instagram.com/p/BS3s0jcjHSH
How to calibrate your KAPEX laser (by simply cleaning the lens): https://www.instagram.com/p/BRvaendDKDp/
How to properly connect your Guide Rails: https://www.instagram.com/p/BSleKgKDBn6
What questions would you like to see Sedge answer?
Offline yetihunter
Re: New training videos from Sedge
« Reply #1 on: April 19, 2017, 05:40 PM »
I just learned two things that I will put into action a la maña.
Thank you!
Offline Scott Burt
  • Magazine/Blog Author
  • painter/writer/educator
    • Prep to Finish
« Reply #2 on: April 19, 2017, 06:09 PM »
I'll go right on the record and say that I learn tons from this fellow. Truly a gifted trainer who makes things accessible to all.
Offline live4ever
« Reply #3 on: April 19, 2017, 06:19 PM »
I suddenly like my clamping elements so much more.  Who knew.
Offline Sparktrician
« Reply #4 on: April 19, 2017, 07:03 PM »
Gotta love that Sedge!!!  He is so wicked shaaahp!!!    [big grin]
- Willy -
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #5 on: April 21, 2017, 02:52 AM »
Great info, Steve ought to get a hair cut like Sedges
« Last Edit: April 22, 2017, 12:52 PM by jobsworth »
Offline Mismarked
« Reply #6 on: April 22, 2017, 07:42 AM »
Great info.  Especially centering domino on crosshairs.
   Does he have any video tips on how to use my iPad?  I could only get it to play about half of the videos.
Offline DrD
  • I might not be fast BUT I sure am slow
« Reply #7 on: April 22, 2017, 08:33 AM »
Spent most of the time in the shop yesterday trying to figure out how to do this very thing.  Logged on this morning, saw the post, watched the video - who knew about the milled edge?  Sedge is brilliant, and thanks to him, I'm now a little more educated about my Festools!  Great job, and THANKS!
« Last Edit: April 22, 2017, 12:40 PM by DrD »
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Online Cheese
« Reply #8 on: April 22, 2017, 10:32 AM »
I also appreciated the video on the DF 500 used to place Dominos within a field.  [thumbs up]
Offline gbruzze1
« Reply #9 on: April 22, 2017, 11:16 AM »
Can they enable English subtitle please?
Offline ear3
« Reply #10 on: April 22, 2017, 08:06 PM »
Installing blade and setting tension on carvex. One of the guys at the roadshow demonstrated a way of doing it that I had never seen before, which I think many people are probably unaware of.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/Long-Life Bag and BT module • CT Sys w/Long-Life Bag • MFT/3
Offline mwildt
« Reply #11 on: May 02, 2017, 09:08 PM »
@TylerC Do tell Sedge we appreciate his trips and tricks video's. Keep them coming.
Offline TylerC
    FOG Administrator
« Reply #12 on: May 03, 2017, 08:22 AM »
Thanks. He LOVES doing these.
Offline Dongar
« Reply #13 on: May 03, 2017, 11:17 AM »
The instagram site needs labels or an index saying what is covered in each video.
Offline TylerC
    FOG Administrator
« Reply #14 on: May 03, 2017, 12:35 PM »
If you click on each video, Sedge provides a quick description along with hashtags (ex. #mft). That's about the extent that you can do on the actual Instagram page itself.
We're planning to make similar videos available on YouTube and festoolusa.com.
Offline RobBob
« Reply #15 on: May 03, 2017, 04:12 PM »
I must be missing something.  Can't see the entire presentation because the screen is cut off when watching on a pc.  Why would I want to watch these on a tiny phone screen or less than full screen pc monitor?
Is there a way to adjust the volume when watching an Instagram video on a pc like there is for a Youtube video?
It would make more sense to put these videos on Festoolusa.com and Youtube first.
Festool should stop trying be "hip" and do what makes sense and reaches their largest audience first, then trickle down to the other platforms.
« Last Edit: May 03, 2017, 04:22 PM by RobBob »
Offline Dovetail65
« Reply #16 on: May 03, 2017, 05:32 PM »
More people use phones than PC by a huge number, Its not being hip, it's staying relevant. Mobile internet surpassed all forms of computer desktop and tablet internet use combined in early 2016 and will never go back.
That being said the videos look the same to me.
It appears these were made on Instagram for Instagram.
I prefer PC use myself. I just got a new dream laptop and it's so nice to use, a desktop replacement that would have filled up a city block when I was a kid, if this kind of computer power was even possible then. His videos sure would look nice on my nice new screen had he recorded them with PC in mind.
« Last Edit: May 03, 2017, 05:38 PM by Dovetail65 »
Offline TylerC
    FOG Administrator
« Reply #17 on: May 03, 2017, 06:35 PM »
Yep. We just shoot them on an iPhone and post directly to Instagram. Quick and dirty. We'll do some similar videos for YouTube, but we want to maintain a similar loose feel.
Sedge has racked up more than 3,000 followers in a month and a half, so somebody seems to like it. (But maybe they're just following him for the crazy Maine accent!)
Offline RobBob
« Reply #18 on: May 04, 2017, 07:44 PM »
That does not mean that most Festool tool owners prefer to watch instructional tool videos on a smartphone.
We are not talking about watching an episode of the Kardashians.
What do you think is the average age of someone who owns and uses more than two Festool tools?
« Last Edit: May 04, 2017, 08:04 PM by RobBob »
Offline c_dwyer
« Reply #19 on: May 04, 2017, 08:10 PM »
What's a Kardashian?
Offline Dovetail65
« Reply #20 on: May 04, 2017, 08:48 PM »
I already said I prefer PC.
28% of Instagram user are 35-49, if that isn't the age group Festool is shooting for they are making a huge mistake.
Offline Scott Burt
    • Prep to Finish
« Reply #21 on: May 04, 2017, 08:52 PM »
Festool owners are similar to other human beings in that they have to constantly adapt to opportunities and not fall into the clutches of complacency.
If you want to see this free series, you gotta have Instragram and a phone.
Offline RobBob
« Reply #22 on: May 04, 2017, 09:01 PM »
I have Instagram and a phone.  I'll still pass.
Have you seen the videos from Laguna, Hammer/Felder, Dewalt TV, Milwaukee Tool, etc?  Much better than Festools, a supposedly premium tool manufacturer.  BTW, have you seen the Onekey app from Milwaikee?
« Last Edit: May 04, 2017, 09:12 PM by RobBob »
Offline Dovetail65
« Reply #23 on: May 04, 2017, 09:08 PM »
Well Instagram is to get new users anyhow, not cater to existing customers(that's secondary I think), that's what the forum and this website are for. Instagram from my perspective is to tease potential new customers and get them to go to the website. That's one reason Instagram videos aren't all that great as far as in depth information or quality, they are more for creating a quick buzz or for stuff to go "viral". You Tube can do the same but allows for a better  video experience. Right now the phones adn Instagram videos aren't quite good enough for me to skip my PC.
I use Instagram to get to people I know never will come to my website otherwise.
« Last Edit: May 04, 2017, 09:11 PM by Dovetail65 »
Offline Svar
« Reply #24 on: May 04, 2017, 09:11 PM »
Well Instagram is to get new users anyhow, not cater to existing customers, that'a what the forum and this website are for. Instagram from my perspective ia to tease potential new customers and get them to go to the website. SO that one reason Instagram videos aren't all that great, they re more for creating a buzz.
What's Instagram?  [huh]
 [poke]
Offline Scott Burt
    • Prep to Finish
« Reply #25 on: May 04, 2017, 09:12 PM »
Other than that, Instagram is just one of the most popular social media networks.
Offline RobBob
« Reply #26 on: May 04, 2017, 09:13 PM »
Yeah, we're not talking about social media, are we?  We are talking about INSTRUCTIONAL TOOL VIDEOS!
People that would benefit from an instructional tool video typically already own the tool.
This is just another example of how lazy Festool has become.
« Last Edit: May 04, 2017, 09:18 PM by RobBob »
Offline Scott Burt
    • Prep to Finish
« Reply #27 on: May 04, 2017, 09:19 PM »
Actually, we are talking about a free, organic video series that is hosted on social media...yes.
I have watched a bunch of these videos and they are geared to people who own the tools.
I wouldn't call it lazy to be putting out free instructional content for users. I'd call that pretty freakin cool.
Offline RobBob
« Reply #28 on: May 04, 2017, 09:23 PM »
On FOG, when referring people to a how to video for a Festool product, whose videos are mentioned or linked to most often?
Peter Parfitt's or Eric/Erock's.  Of course, Festool has already soured Eric and he does not produce Festool videos anymore.
Offline Scott Burt
    • Prep to Finish
« Reply #29 on: May 04, 2017, 09:25 PM »
With all due respect to Peter and Eric, we are talking about Brian Sedgeley on this one.
'Nuff said.
