Pages: [1]   Go Down
  Print
Author Topic: Question on Bottom of Finger Joint Box  (Read 2153 times)
David
Offline Offline
Author, speaker, and consultant to marketing folks
WWW
« on: August 22, 2010, 09:31 PM »
I'm building a small box with finger joints. I was going to make the slits for the bottom of the box with several passes over the table saw rather than mess with a dado blade. I suppose I could use a router, too, set up on a guide rail.
But in either case, I don't know how I'm going to do that without having the slots cut into the inside of an individual finger...and then look silly in the joint. Does that make sense? In other words, I need to route or groove the sides up TO the finger joint without scoring across it.
Any ideas on the best way to do this?
I can post a picture if that helps.
See my most recent book on Amazon: http://amzn.to/foglink "Managing (Right) for the First Time, published by RockBench Press
MFT/3 x2, MFT/Kapex x2, CT 22, TS 75, PS 300, KB 120, MFK 700, OF 1400, OF 2200, HL 850, DF 500, RO 125, RO 150, DTS400, LS 130, ETS 125, DX 93, T 15 + 3, SawStop PCS 1.75, Benchdog Router Table with PC7518
harry_
Offline Offline
« Reply #1 on: August 22, 2010, 10:01 PM »
you could make the bottom 'stopped'. Where the part that goes into the groove does not go all the way into the corner, that way the groove can be stopped.
if you use a router, you can stop your groove before the edge of the finger and be able to use a full squared bottom.
David
Offline Offline
WWW
« Reply #2 on: August 22, 2010, 10:10 PM »
And then use a chisel to clean it up a tad?
Something else I could do, I guess, is glue a strip inside the bottom and then glue the bottom of the box to the top of the strip.
lym
Offline Offline
« Reply #3 on: August 22, 2010, 10:20 PM »
i used a 1/8 straight bit o a router table for a small box that i made.  blocks at either end assures that you won't go too far into the fingers.  if the fingers are large enough, you could also use a 1/4 in. straight bit.
harry_
Offline Offline
« Reply #4 on: August 22, 2010, 10:22 PM »
Doubtful you would even need to chisel it
GPowers
Offline Offline
Metric convert
WWW
« Reply #5 on: August 23, 2010, 02:01 PM »
The Woodsmith Shop did a video on small finger joint boxes http://www.woodsmithshop.com/episodes/season3/305/ The talked about who the bottom and the finger mated.
Greg Powers
Pages: [1]   Go Up
  Print
Jump to:
