Author Topic: Rail splinter guard fix  (Read 3480 times)
Offline Svar
« on: October 30, 2017, 07:48 PM »
Splinter guard typically starts to peel off from the ends. I wrap clear tape around the edges to secure it as shown.
Note: I used blue painters tape only to make it visible on the pictures. Clear packing tape works best. It adheres very well, lasts long time, does not interfere with anything, and secures the strip in all directions.
« Last Edit: October 30, 2017, 07:52 PM by Svar »
Offline Chris Perren
Re: Rail splinter guard fix
« Reply #1 on: October 30, 2017, 07:50 PM »
Excellent Suggestion!
Online Trevin
« Reply #2 on: October 30, 2017, 10:49 PM »
Good Idea!!!  I vote for @Svar to win some sandpaper!!!   [big grin]
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline SRSemenza
« Reply #3 on: October 31, 2017, 12:25 AM »
Nothing like a simple solution sometimes. Amazing how many little things get overlooked until someone else points them out.   [doh]
Offline ear3
« Reply #4 on: October 31, 2017, 09:40 AM »
Thanks for the suggestion!  I think all of my rails require this treatment at this point.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Offline RJNeal
« Reply #5 on: October 31, 2017, 10:53 PM »
I have been doing that since Festool switched guide strips. I usually use the red stucco tape. Seems to last longer.
Then again you should see the bottom of  my 10’ rail. It’s pretty much got a red racing stripe. I do have a replacement makita strip.
Thanks for sharing
Rick
Offline jtwood
« Reply #6 on: November 01, 2017, 12:16 AM »
Great idea, especially the price!
Thx,
Steve
« Reply #7 on: November 01, 2017, 10:04 AM »
Excellent idea Svar... [thumbs up]  clear packaging tape it is. I replaced the strip on 2 of my rails this spring but I noticed both are now just starting to droop a bit.
Offline Don Ware
  • Festool Dealer
  • Anderson Plywood
« Reply #8 on: November 01, 2017, 10:20 AM »
I have always back cut the last 3/4" of the splitter guard. And back cut the very end. I never line anything up with the very end of the guide. And it keeps it from getting caught on things.
Don Ware
Anderson Plywood Sales
Culver City, California
Offline Kev
« Reply #9 on: November 02, 2017, 05:02 PM »
Where's the forum personal bookmark feature? [sad]
I'm replacing all of my strips soon, got to remember this!!!
Offline Naildrivingman
« Reply #10 on: November 04, 2017, 03:22 PM »
Ditto...this works well for me.
Dance with who brung ya...
Offline Gregor
« Reply #11 on: November 05, 2017, 02:48 AM »
A bookmark in the browser should do that trick.
Offline SRSemenza
« Reply #12 on: November 05, 2017, 10:51 AM »
While not exactly what you are looking for it will  get you the same end result.   Click the "Notify" button towards the upper right of the topic. Even though you will only be notified when a new post is made that will also add it to your list of topic notifications. That list is in your profile. So the list will serve as a list of forum bookmarks that are links to the topic.
« Last Edit: November 05, 2017, 10:54 AM by SRSemenza »
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #13 on: November 08, 2017, 08:25 AM »
Im going to try that
