Author Topic: Removing failed epoxy pour with RO150  (Read 1422 times)
Offline dzehner2
« on: November 05, 2017, 08:17 AM »
Well, unfortunately I had some 2 part bar top epoxy go wrong on me and I need to remove the sticky mess of partially cured resin. It's too viscous to wipe off, even with a rag soaked in acetone. I'm thinking of getting some 24 grit Saphir paper for my RO150 and going to town. Has anyone else tried this method?
Offline bnaboatbuilder
Re: Removing failed epoxy pour with RO150
« Reply #1 on: November 05, 2017, 08:21 AM »
Scrape off the sticky part. Use vinegar to remove any residue. Leave it for a day so any part that did mix can cure and then you can sand.
- John
Offline bruegf
  • Michigan
« Reply #2 on: November 05, 2017, 08:23 AM »
Use a heat gun and a scraper to remove the majority of it first.  Then I'd try wiping with acetone and then sand.  Sanding uncured epoxy will clog the paper too fast.
https://www.westsystem.com/instruction-2/epoxy-basics/clean-up-removing/
Fred
Offline Alex
« Reply #3 on: November 05, 2017, 09:13 AM »
As said, scraping. No sanding.
Offline Vondawg
« Reply #4 on: November 05, 2017, 09:51 AM »
Definitely heat gun (carefully) and scrape
Offline Peter Halle
« Reply #5 on: November 05, 2017, 10:26 AM »
If the epoxy is really still semi-liquid then I would agree with others about heating and scraping.  Wear a respirator.  If it is semi soft to sticky then I would find some PVA https://www.amazon.com/Fibre-Glast-Release-Film-Quart/dp/B015NM6MDS/ref=sr_1_2?ie=UTF8&qid=1509895211&sr=8-2&keywords=polyvinyl+alcohol+mold+release&dpID=511k8lhwGaL&preST=_SY300_QL70_&dpSrc=srch put it in a sprayer or spray bottle and cover your project.  Then wait and see what happens.
I have a long disaster story that was saved ultimately by PVA but I will spare the details.
Offline Birdhunter
« Reply #6 on: November 05, 2017, 10:45 AM »
Be sure to get good ventilation.
Birdhunter
