BillG
Offline
« on: February 21, 2012, 05:36 PM » |
Greetings all I have been reading here for a while now, but this is my first post. I recently acquired an MFT3 for my shop. In moving stuff around (i.e. shoehorning it all into place) I have come to the conclusion that the best spot for it for the foreseeable future is next to my big lathe. I am somewhat concerned about moisture, since I turn a lot of very wet wood. I searched the board here and found a couple of threads on sealing the top of the MFT, but no comments on how it actually worked out in use. I would hate to seal it all up only to discover it was a real bad idea, worse than it getting a little wet from time to time. Has anyone here sealed up their table and used it for a while now? Did you experience any other effects than the expected one of preventing moisture damage? Would you do it again? Thanks.
Wood_Junkie
Offline
Location: Madison, Wisconsin - USA Member Since: Dec 2009
« Reply #1 on: February 21, 2012, 06:18 PM » |
First:  Could you just get a small tarp and throw that over the MFT? Seems to me that's a much simpler (and cheap!) solution than sealing the top. If you do decide to seal it, you must use oil-based finishes. Water based would cause the MDF to swell. A simple wipe-on polyurethane finish might be sufficient. But be aware, getting any finish buildup (or worse, runs!) in the MFT holes may cause them to bind on MFT accesories. I.e. my Qwas dogs are a TIGHT fit. If I got a finish drop, I wouldn't be able to remove them.
BillG
Offline
« Reply #2 on: February 21, 2012, 06:36 PM » |
Thanks. A tarp did not occur to me. I can just use the drop cloth I already have in the shop. One of my concerns was getting goop in the holes. Yeah, I know about water based finish and swelling too. I have been running a woodworking business for 19 years now, and have learned all sorts of things the hard way.
RL
Offline
« Reply #3 on: February 21, 2012, 06:43 PM » |
Some people put a wash coat of shellac on it. That's probably the easiest way to seal it and it won't gum up the holes either.
I like green.
Festoolfootstool
Offline
The trouble with Bob is its all about Bob
« Reply #4 on: February 21, 2012, 06:43 PM » |
Welcome to the fog billg
Nice looking lathe..
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
davee
Offline
« Reply #5 on: February 21, 2012, 07:11 PM » |
I trashed an MFT top through turning wet wood in the vicinity. I had plastic over the top but it snuck under. I have since shellaced the top which slows moisture absorbtion but doesn't entirely stop it from occuring. You are correct to be cautious.
GPowers
Offline
Metric convert
« Reply #6 on: February 21, 2012, 07:30 PM » |
Welcome BillG.  Pull up a chair and have a drink of GREEN cool-aid. One sip and you will be hooked.
« Last Edit: February 21, 2012, 07:32 PM by GPowers »
Greg Powers Size:XL
Kev
Online
« Reply #7 on: February 21, 2012, 07:50 PM » |
 My thoughts - don't treat the top. You can always buy new tops or make your own if you can address the accuracy needed. If you absolutely must - as mentioned - something like shellac is best. From a different perspective, I would personally want to avoid spraying moisture generally, not just the MFT surface. Can't you shroud the lathe in some way? Kev
BillG
Offline
« Reply #8 on: February 21, 2012, 07:54 PM » |
Thanks. It makes Festool stuff look inexpensive by comparison. But it is the main tool in my shop.
BillG
Offline
« Reply #9 on: February 21, 2012, 07:56 PM » |
 My thoughts - don't treat the top. You can always buy new tops or make your own if you can address the accuracy needed. If you absolutely must - as mentioned - something like shellac is best. From a different perspective, I would personally want to avoid spraying moisture generally, not just the MFT surface. Can't you shroud the lathe in some way? Kev I've been spraying stuff around the shop for most of the years I have been in business. But shrouding the lathe would be tough, as I am often teaching with it, and I need access all around while it is being used.
Alan m
Offline
« Reply #10 on: February 21, 2012, 07:58 PM » |
id cover it or fold it up and put it to one side. sealing could cause problems . you might make the surface too slipery to work on or clamp things to
SRSemenza
Global Moderator
Offline
« Reply #11 on: February 21, 2012, 08:48 PM » |
Hi Bill, Welcome to the FOG!  I was just thinking what Alan said. Maybe just move it aside or move and cover it? Seth
Festool Service 800-554-8741
Kevin Stricker
Online
« Reply #12 on: February 22, 2012, 12:20 AM » |
I'm surprised someone could ruin a top with some wet wood, I have had several drinks spill on mine with no lasting effects. Came back from lunch last week and saw that the painters had used one as a convenient place to sit their snow cooled Cokes while eating lunch, with a bunch of snow and drink rings still there an hour later. Wiped it down, just another stain. You can always hit it with a sander if it gets too bad.
Thought about sealing mine with shellac but worried it might warp the top if you didn't get both sides. Then I put a couple dozen kerfs in it and stopped worrying.
waho6o9
Offline
Location: San Fernando Valley, Los Angeles California Member Since: Dec 2009
« Reply #13 on: February 22, 2012, 12:38 AM » |
I used paste wax on mine and had no problems with it.  welcome to the Fog BillG!
« Last Edit: February 22, 2012, 12:39 AM by waho6o9 »
davee
Offline
« Reply #14 on: February 22, 2012, 08:32 AM » |
Shellac definitely makes the top a bit more slippery, but not so that it is a detriment to working. I've not experienced any issues with clamping difficutlies. I actually like the affect on the ability to slide pieces. I agree with with suggestion to move the MFT when using the lathe. Its amazing how much sap is thrown off when wet turning - it soaks not sprinkles.
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #15 on: February 22, 2012, 09:46 AM » |
I've been using Butcher's Bowling Alley Wax on mine. I've had to do repeated coats over time. Moisture from coffee/tea cups seems to wipe right off with no ill effects. The wax does not make the top more slippery at all.
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
BJM9818
Offline
« Reply #16 on: February 22, 2012, 09:55 PM » |
I've been caught out in the rain with mine twice. I was playing with fire trying to get things done and that overcast sky became a full downpour. MFT was always the last item I got indoors. Wiped it down and no issues so far. I like the wax idea of all of them. If I were to used a sanding sealer I would give it a light sanding after it dried to increase the friction on the work piece.
BillG
Offline
« Reply #17 on: February 23, 2012, 11:09 AM » |
Thanks everyone for all the responses and welcome. I had a class yesterday, and just threw my shop drop cloth over it. That seemed to do just fine. I have been using Festool tools for a number of years now, since about 2003. I am expanding my inventory as opportunity permits. The lathe is my primary tool in the shop, but I do enough flat work that it is worth having good tools to do it.
harry_
Offline
« Reply #18 on: February 23, 2012, 08:50 PM » |
You guys with the pristine MFT tops are damaging to my psyche  If it is set up outside and it rains, it gets wet. If it rains really hard, it gets really wet. If inside was an option under a cloudy sky it was an option under a sunny sky. If I happen to have my sander out, I sand it. The only place it really gets 'the swells' is near cuts so I sand them back down, no big deal. If I happen to spill stain on it, I wipe up the stain. What don't come up, don't come up adding to its 'professional patina' If I happen to be using shellac or poly, since I don't ever return anything back to the can, I just use what would be 'waste' on the top. Remember it is a WORKTOP, not a china cabinet!
Charimon
Offline
Tool and Tile Junkie
« Reply #19 on: February 26, 2012, 06:14 PM » |
Harry- Shhhhhhhhhhhhhhh Don't mention WORK it is no fun
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
alanz
Offline
« Reply #20 on: February 26, 2012, 06:44 PM » |
Bill,
I put a wash coat of shellac on my MFT/3 a few years ago... seems to work well.
And not surprisingly, (you know me...) I made a small tweak to my MTF/3 setup.
Because I tend to do things differently than many other folk, I mount the angle unit and fence on the near side of the table rather than the more typical far side. I did have to mill a notch in the 'other end' of the fence to match the original notch that typically slides under the guide rail when used on the far side.
Triton 2.25 router; CMT Industrio table; Jointech fence; SC planer; Dewalt miter; Delta 14" bandsaw; Festool TS55, MFT/3, CT22, ETS150/3, OF1400, PSB300EQ; Dewalt Scrollsaw; Nova DVR XP lathe, JJ-6CS jointer, Ryobi OSS; Grizzly 1023s cabinetsaw
alanz
Offline
« Reply #21 on: February 26, 2012, 06:48 PM » |
Kev said From a different perspective, I would personally want to avoid spraying moisture generally, not just the MFT surface. Can't you shroud the lathe in some way?
If you've ever watched Bill G. at the lathe, although he doesn't control water spray coming off of the wood, his turning style is more like target practice... he aims the wet shavings EXACTLY where you're standing, and there's no escape! Then again, maybe he just does that when I'm watching < s >
« Last Edit: February 26, 2012, 07:12 PM by alanz »
BillG
Offline
« Reply #22 on: February 27, 2012, 09:59 AM » |
You guys with the pristine MFT tops are damaging to my psyche  If it is set up outside and it rains, it gets wet. If it rains really hard, it gets really wet. If inside was an option under a cloudy sky it was an option under a sunny sky. If I happen to have my sander out, I sand it. The only place it really gets 'the swells' is near cuts so I sand them back down, no big deal. If I happen to spill stain on it, I wipe up the stain. What don't come up, don't come up adding to its 'professional patina' If I happen to be using shellac or poly, since I don't ever return anything back to the can, I just use what would be 'waste' on the top. Remember it is a WORKTOP, not a china cabinet! Harry, if you could see the rest of my shop, you would realize I am not worried about appearance, only function. Kev said From a different perspective, I would personally want to avoid spraying moisture generally, not just the MFT surface. Can't you shroud the lathe in some way?
If you've ever watched Bill G. at the lathe, although he doesn't control water spray coming off of the wood, his turning style is more like target practice... he aims the wet shavings EXACTLY where you're standing, and there's no escape! Then again, maybe he just does that when I'm watching < s > Yeah, it is hard to contain the shavings from that gouge without putting the whole lathe and myself in a bubble, and that ain't gonna work. I don't mind the top getting dinged and dirty, I just don't want it swelling up like a tick while I am making shavings. So far that drop cloth seems to be working out well. I just got back from some "target practice" with shavings up in northern PA, and the one piece of wood I turned was so wet I could have used a windshield wiper on my helmet.
