Author Topic: Retrofitting a dimension scale to a CMS TS miter/cross-cut fence?  (Read 2508 times)
Offline TinyShop
Has anyone succeeded at somehow retrofitting a dimension scale to either the stock CMS TS miter fence (when used as a cross-cut fence in conjunction with the sliding table and a flag stop) or, similarly, to a cross-cut fence cannibalized, say, from another Festool tool (like the MTF/3)? Or, has anyone added a sacrificial fence to one of the above that likewise features a dimension scale and integrated flip stop? In comparison, competitor's products (like Mafell's ERIKA saws) at least offer the option of fitting a cross-cut fence that features a dimension scale and integrated flip stop.
Or is there something abut the design or accuracy of the Festool CMS TS/OF/MFT/3 miter guard / sliding table that somehow limits the usefulness of such a feature...?
ETS 150/5 EQ (DE) [PO], TS 75 EQ (DE) [PO], OF 1400 EQ-F (DE) [N], CXS (DE) [N], CMS-GE [DE], CMS TS 75 (DE) [N], LA-CS 50/CMS (DE) [PO], VB-CMS (DE) [N], MFT/3 (CZ) [N], DF 700 EQ w/Seneca Small Mortise Kit (DE) [PO], FEIN Multimaster 350 QSL (DE) [N], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [N], BOSCH 1590EVS w/dust collection (CH) [N], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [N], CT SYS (DE) [PO], Milwaukee 0302-20 (US) [N], Two (2) Porter Cable 862 (TW) [N], Porter Cable 447 (US) [N], Zyliss Vise (CH) [N], Hitachi C 8FB (JP) [H]
[PO] Pre-owned   [N] New   [H] Heirloom   (XX) country of origin
Offline Bert Vanderveen
Re: Retrofitting a dimension scale to a CMS TS miter/cross-cut fence?
« Reply #1 on: February 08, 2017, 08:22 AM »
The profile of the fence can be moved around, which makes the whole exercise of adding a scale moot. OTO you might get away with adding one if you calibrate it every time, referencing off the built in scale of the CMS. (I might try that…)
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
Offline TinyShop
« Reply #2 on: February 08, 2017, 07:28 PM »
I like your idea of referencing the built-in scale to achieve the "zero" position, but why bother if there's no scale and flip stop fitted to the miter fence? Although, this would work when setting up to cut short pieces.
Any retrofitting of a scale to the short stock miter fence (or, ideally, a longer one borrowed from an MFT/3) would require that the scale be positioned on the top face of the miter fence to eliminate wear and tear (to the glorified sticker) and to make it easy to use. The problem, of course, is that the Festool flag stop isn't designed to float over a scale nor is the extrusion designed with this functionality in mind.
For posterity, here's an example of an after-market solution that might be made to work with a piece of Festool extrusion (easy to make it work with a sacrificial fence mounted to the vertical face of the extrusion):
[Source: http://www.leevalley.com/us/wood/page.aspx?p=73516&cat=1,43455,61994&ap=1]
And, for comparison, the miter/crosscut fence extension (a.k.a. "longer miter/crosscut fence") and flip stop that are optional equipment for the Erika saw:
Offline Tom Gensmer
« Reply #3 on: February 08, 2017, 07:46 PM »
I have the Mafell Erika 70 and the 1m fence with flip stop. For indexing the fence, I simply use a block of a known dimension (for example 40mm), set the flip stop to that dimension, put the block against the flip stop, then slide the assembly towards the blade until the block juuuuust touches the teeth of the blade.
For fences and flip stops in general, you can quickly end up chasing diminishing returns trying to achieve "perfect" results. With that in mind, I generally revert to the mindset that "Consistency trumps Precision"...
CT-MIDI, C-18, RO-150, RO-90, OF-1010, OF-1400, MFK-700, MFK-700EQ/B, EHL-65, DTS-400, LS-130, MFT/3 (x4), MFT/Kapex (x3), KA 65 Conturo, endless Systainers
