Author Topic: ripping a live edge slab  (Read 37765 times)
Offline lenick01
« on: January 04, 2015, 12:03 PM »
I'm looking for some pointers on how to rip a 3 inch thick live edge slab.  I have a 10 foot long slab that's destined to become a dining room table.  Unfortunately, it's not wide enough per my significant other.  I'm planning on ripping it down the middle and essentially making a panel out of it by gluing in another foot wide 3 inch slab in the middle.
I thought about using a table saw but I think it would be nearly impossible due to the weight and size.  I have a TS 55 but won't get through the full thickness - maybe making a cut and then flipping it over?  I'm worried that I won't line up the 2 cuts properly.  Of course this might be an excuse to get a TS 75....
Any tips would be appreciated!
Mike
Offline Tom Bellemare
  • Inactive Member
    • Tool Home LLC
Re: ripping a live edge slab
« Reply #1 on: January 04, 2015, 12:08 PM »
A TS 75 on the guide rail will only go 70mm deep. That's 75mm - 5mm for the guide rail. It's about 2-3/4".
A Trion or Carvex with a 140mm blade and guide stop can do the job if the blade guides are set up properly.
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline Sparky
« Reply #2 on: January 04, 2015, 12:22 PM »
When I have done this with my 75 i always flipped it and had small amounts of plaining to get a nice joint.
Ct 36, Ets 150/3, OF1400, Lr32 Set, domino 700 set, hl850, ts 75,Dts 400, kapex
Offline PA floor guy
« Reply #3 on: January 04, 2015, 12:26 PM »
Since we cannot get sword saws here in the states, has anyone looked into the prazi sword saw add on.  You can install it on most worm drive circular saws.  Other than that, you need a big beam saw.
Offline G3Trim
« Reply #4 on: January 04, 2015, 12:28 PM »
You could rip it with your ts55. Then true up the cuts using a router and a strait edge guide. just use a 2" strait cutter with the strait edge, then flip it over and use a bottom ball bearing bit that's long enough to ride along the freshly cut edge to finish off the rest of the face.
Offline Holzhacker
    • www.aic-chicago.com
« Reply #5 on: January 04, 2015, 12:32 PM »
If I have to cut a thick piece from both sides to make it through and the cuts don't line up, its because I was in a hurry and didn't pay attention to which side of the pencil line the blade was supposed to go. Very rare since that mistake really ticks me off.
Take your time you can do this.
Draw your line on the top side, transfer down to the bottom side with a square for reference but don't actually draw the bottom line, cut the top side, draw and adjust your bottom pencil line based on how your top cut ended up running, cut away;
The key is to pay attention to blade position to the pencil line or guide rail position to your lines; unless you are an idiot (you are on the FOG so I'm assuming you can't be) you aren't going to screw it up drawing your pencil line, its a positioning issue
So often people don't think about the fact that your blade can end up centered on your pencil line or to the left or right of the pencil line; this also holds true for guide rail clamping, minute differences make a clean cut or ridged cut
You can use the 55 and a Trion with a long blade. That works fine but you should use your 55 on the top side and let the Trion cut the bottom. Depending on how well or not you cut using this combo there may be a lot more work in flattening the sides to mate the insert piece. Mating is another story though
On the other hand its an excuse to buy a 75 and then cut the last 1/4" with a good handsaw
Offline ear3
« Reply #6 on: January 04, 2015, 12:39 PM »
I would jigsaw it then use router with straight edge and spiral bit to straighten edge (if you don't have some combo of guide rails to give you 10 ft. of length).  Just make sure the edge is as square as possible to the other sides.  After you fit in the board though, you will probably have to do the same operation on the ends, meaning you could leave the middle piece long on both ends because you know you will be trimming the edge afterwards.
  • Inactive Member
    • Tool Home LLC
« Reply #7 on: January 04, 2015, 12:40 PM »
A Trion or Carvex jigsaw with  S145/4 FSG, 499478, will do this in one pass using the guide stop. It has to be set up properly and use the max orbital.
It makes a nice, perpendicular cut 4"+ deep in hardwoods.
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline ear3
« Reply #8 on: January 04, 2015, 12:46 PM »
Why the guide stop?
  • Inactive Member
    • Tool Home LLC
« Reply #9 on: January 04, 2015, 12:47 PM »
It runs on the guide rail and keeps the cut running straight.
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline waho6o9
    • Garage Door Handyman.com
« Reply #10 on: January 04, 2015, 12:48 PM »
Use a Panther blade and you're good to go!
Offline ear3
« Reply #11 on: January 04, 2015, 12:51 PM »
Got it.  For some reason I thought you meant those stops that you hook into the rail to prevent the tool from going past a certain point.
  • Inactive Member
    • Tool Home LLC
« Reply #12 on: January 04, 2015, 12:51 PM »
It's odd wording but that's what Festool calls them...
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline ear3
« Reply #13 on: January 04, 2015, 01:04 PM »
Probably just a translation issue.  The limit stop is the Rückschlagstop (literally kickback stop), and the guide stop is the Führungsanschlag, where -anschlag in this technical sense also gets translated as "stop."
Offline Staniam
  • Enjoy what you do. Build something.
« Reply #14 on: January 04, 2015, 01:38 PM »
Can you provide a model number for the guide stop you're talking about?
LA Lakers - Oakland Athletics
The Arsenal: Festool - PDC, CXS, RO 125, TS55 REQ, OF 1010 EQ, CT MIDI;  Bosch - JS572EBL, JS120, 1294VSK, PS22
Offline ear3
« Reply #15 on: January 04, 2015, 02:00 PM »
The guide stop is for the Trion.  You already have the rail adapter base for the Carvex.
http://festoolusa.com/power-tool-accessories/jigsaws/guides-and-stops/guide-stop-490031
Offline Birdhunter
« Reply #16 on: January 04, 2015, 03:12 PM »
What does that piece weigh? Just amazed by the idea of flipping it over or even getting it into position to work with.
Birdhunter
Offline Dovetail65
« Reply #17 on: January 04, 2015, 03:24 PM »
I would use the table saw for sure. But possibly you only have a little bench top table saw? With a proper out feed table its not a big deal at all.
Offline waho6o9
« Reply #18 on: January 04, 2015, 03:42 PM »
" I'm worried that I won't line up the 2 cuts properly. "
You got this buddy, no worries u da man.  [thumbs up]
Offline WoodWhisperer
« Reply #19 on: January 04, 2015, 03:43 PM »
Some really good pointers for cutting thick wood.
Not to get off subject but where do you guys get your live edge timber?
Sean
TS55|TS75|OF1400|EC-ETS125|ETS125|MFT/3|
2-MIDI|Kapex|Carvex PS420| |Domino700XL|Compact Cleaning Kit|Waiting on my PRO 5.....
Offline WastedP
« Reply #20 on: January 04, 2015, 03:44 PM »
You may not have this option where you live, but if I had to make the glue line cut you're describing in a slab that thick, I would load it up in my truck and take it across town to a local shop that has a Schelling beam saw.  They would charge about $20 to change the blade over and make that single cut, to a laser line, but it would be quick, and most importantly, clean.  I would also bring the new slab to have it cut to width, perfectly parallel.  Those two extra cuts might add a little more machine time, maybe five minutes.
I realize this solution doesn't provide you with the excuse to buy a TS 75, or any other tools.  Sorry.
Offline Tinker
« Reply #21 on: January 04, 2015, 03:54 PM »
I sure would not.
I like the idea of cutting to limit of the TS 55.  Then finishing from the top with jigsaw or hand saw.  The less that slab is moved after the partial cut, the better.  That is one of those projects where I always figure lawman Murphy is always looking over my shoulder.  I am sure that is a great looking slab.  One wrong move flipping to make second cut and there goes the ball game.  Making the cut on a table saw (remember, that is a live edge slab.  I am reasoning it is live edge on bothe edges) is possible as long as the operator is very skilled and has a very good (sawyer's) eye for lining up the cut right at the very start.  If someone is not used to making such a cut, there are all sorts of troubles to get into.  A 10 foot by 3 inch slab has got to be quite heavy in anybody's language. It was not mentioned what wood the slab is, but I bet it is not Balsa.  Not even Sitka Spruce.
Tinker
Wayne H. Tinker
Offline Dovetail65
« Reply #22 on: January 04, 2015, 03:57 PM »
Why would he have to flip I thought this was only 3" thick? I have glued up stuff like this many times. I just guess my table saw is set up for stuff like this. 10 foot is no beg deal and a 3 Inch slab, I have a ship full of them in everything from Cumaru, Walnut  to Wenge. OWithh my Forest Woodworking blade blade I would have this ready for glue up right quick.
« Last Edit: January 04, 2015, 03:59 PM by Dovetail65 »
Offline Tinker
« Reply #23 on: January 04, 2015, 03:59 PM »
>>>You may not have this option where you live, but if I had to make the glue line cut you're describing in a slab that thick, I would load it up in my truck and take it across town to a local shop that has a Schelling beam saw.  They would charge about $20 to change the blade over and make that single cut, to a laser line, but it would be quick, and most importantly, clean.  I would also bring the new slab to have it cut to width, perfectly parallel.  Those two extra cuts might add a little more machine time, maybe five minutes.<<<
This idea came up while I was typing my last reply.
It is the best idea yet.
Tinker
Wayne H. Tinker
Offline Dovetail65
« Reply #24 on: January 04, 2015, 04:00 PM »
Where do you live, no one does anything here for 20.00. I would charge a 100.00 to come to my shop an take my time like that. And I am betting most companies wont even deal with something like that. What if they screw that piece up, then they are on the line for the material for a 5.00 profit? Actually, I dont think I would even take the piece, there is no upside for me as a business. For FOG friend maybe not someone off the street.
Owl hardwood would do it, with a 2 week lead time. But only if you purchase from them and they wont guarantee a glue joint.
« Last Edit: January 04, 2015, 04:04 PM by Dovetail65 »
Offline sumantamandal
« Reply #25 on: January 04, 2015, 04:15 PM »
What is the length and width of this lumber?
Cheers!
Sumanta
Offline wow
  • Inactive Member
« Reply #26 on: January 04, 2015, 04:53 PM »
And what species?
Offline Dovetail65
« Reply #27 on: January 04, 2015, 05:08 PM »
He said about 10' and 3" thick, I can't find reference to width or species. I am guessing 18-30(max)".
Could find weight here if we knew more:
http://www.woodweb.com/cgi-bin/calculators/calc.pl?calculator=weight_bd_ft
Offline Staniam
« Reply #28 on: January 04, 2015, 05:23 PM »
Gotcha, just different names for each tool.
Offline wow
  • Inactive Member
« Reply #29 on: January 04, 2015, 05:25 PM »
I just noticed that this was your first post. Sorry I didn't say it earlier, but...
[welcome] to the FOG!
