Author Topic: Ripping with my TS75 in a CMS insert  (Read 4659 times)
Offline lshah72414
« on: February 11, 2018, 06:41 PM »
I was ripping 3/4 inch, eight foot sections of oak with my TS75 using the 52 tooth blade. Most of the time it cut through like butter. A couple of times, it seemed like the saw was bogging down(possibly knots) and one time it even stalled and I quickly turned off the CMS and disengaged it. I raised the saw blade higher and it then cut. Normally, I keep blade approximately 1/8 of an inch above the surface of the material I am cutting. To get it to cut this time I had blade approximately 1/4 to 1/2 inch above surface. Crosscuts were never a problem.
My question is twofold: a.) has any one else experienced this? If so, what was causing the problem?
b.) was I using the wrong blade? I have a panther blade but honestly was to lazy to switch blades.
Any suggestions would be appreciated. Thank you.
Offline Peter Halle
Re: Ripping with my TS75 in a CMS insert
« Reply #1 on: February 11, 2018, 06:51 PM »
If you are really ripping with the 52 tooth blade please stop.
For ripping you need to get a ripping blade for your saw from Festool or another vendor.
Offline jjowen
« Reply #2 on: February 11, 2018, 07:29 PM »
Hi Ishah72414, I read Peter's response has having an ironic humour to it. I laughed. The humour was in the terseness of it. I notice that you describe yourself as Still Learning. Aren't we all. FoG is the place to come with any questions, and you get prompt, good humoured responses. I just hope you did not take the response the wrong way.
Disclaimer: All posts after 12:00pm on Fridays (GMT+10) should be independently verified for relevance and veracity.
Offline lshah72414
« Reply #3 on: February 11, 2018, 07:37 PM »
@jjowen no offense was taken. I appreciate Peter’s candor. As stated, I have a panther blade, I just didn’t realize it made that much of a difference.  I do now. And if you don’t ask you don’t know. Thanks for the help.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #4 on: February 11, 2018, 10:32 PM »
I use a combo blade for ripping, even though I have apanther blade. I found I have to reduce my feed rate , slow it down and not for the material through the saw, let the saw/blade do the work.
But 52 tooth blade is more of a fine cut blade
Offline Peter Halle
« Reply #5 on: February 12, 2018, 09:09 AM »
@lshah72414 , I am glad you weren't offended.  My response was more concise than normal and that could easily be seen by those who have become accustomed to my posting style as being rude.  That was not my intention.  When I get concise it is usually because I want to yell "STOP RIGHT NOW because you can be doing damage."  Usually that is reserved to reported Plug-It cord issues where the problem can grow thru troubleshooting.
As a Moderator I can see the location of your ip address limited to city and state.  Warranty issues could come into play.  So that is why I was so short. I don't want to see you overwork a saw when a simple blade change would be so much better for you.
If I can be of assistance to you or any other member that would prefer that help be away from the public eye I can always be reached via the Personal Message system here.
PS.  After using a TS-55 for a decade now I am leaning towards adding a TS-75 to my collection in the near future.
« Last Edit: February 12, 2018, 09:34 AM by Peter Halle »
Offline jarbroen
« Reply #6 on: February 12, 2018, 05:25 PM »
The experts have already commented but I thought I could add something as a fellow 'apprentice'. :)
The 36T 'general' blade that came with my TS75 has worked pretty well for ripping 8/4 walnut.  Definitely listen to the saw on the right speed rate.  Leaves a clean edge and I've only had a couple rough spots where I was pushing too fast.
I had the TS55 before with the standard blade(56T?) and it was great for leaving a clean edge on plywood.  Ripping hardwood, not so much.
Offline jobsworth
« Reply #7 on: February 18, 2018, 11:44 AM »
@lshah72414
 ow good a cuts are you getting with your TS 75 in the CMS?
 Is it as good as you get using a guide rail?
what fence do you use? The one with the protractor head or the CS 50 fence?
Just curious
Offline lshah72414
« Reply #8 on: February 18, 2018, 05:11 PM »
at jobsworth,
I am using a cms/vl table attached to a mft with a cms 75 insert. To cut I am using both the sliding table with the protractor head, but, mainly a ls 25 positioner. With the positioner my cuts are dead-on. The only complaint I have is there is friction sliding the wood across the mft. With the track saw( I use mainly to break down my sheet goods), my cuts are getting very good, but take more time to accomplish, due to setup time. Please take what I say with a grain of salt as I am still in a learning curve. Thank you for asking.
« Reply #9 on: February 18, 2018, 05:41 PM »
@Ishah72414  you’re off to a good start and you have good instincts so you’ll learn fast. As you observed, when the blade is too fine for the work raising it works better. When the gullets are full of swarf there is more resistance, more heat, and more likelihood of burning. Raising the blade reduces the number of teeth in the kerf so it’s a bit better but changing to a blade with a more appropriate tooth pattern is best.
You probably also noticed that the blade was much better at cross cuts than rips due to the very different nature of the swarf produced.
Offline Getmaverick
« Reply #10 on: February 18, 2018, 08:49 PM »
Don't forget moisture content in the wood. Dryer wood will cut more easily.
Offline jobsworth
« Reply #11 on: February 20, 2018, 04:02 PM »
at jobsworth,
Thanks we all learn from each other. Im constantly coming here looking at the post. I just watch a video and got a idea and those my friends are dangerous, (ideas) :>D
Offline TPatti
« Reply #12 on: March 14, 2018, 10:14 PM »
Is there any way to get the CMS insert for TS75 in the USA?
Offline jobsworth
« Reply #13 on: March 15, 2018, 12:35 AM »
you could find a tool store in europe who will ship to the US. Also check eBay, Amazon
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=CMS+TS+75+module
Offline SRSemenza
« Reply #14 on: March 15, 2018, 09:50 AM »
Hi, Just a required posting.
Statement from Festool.
Warning: The Festool CMS System is approved for use with only the OF 1400 and OF 1010 routers in the US and Canadian markets.  It is not approved for use with the OF 2200, nor with any of the CMS modules currently available outside the US and Canadian markets (TS, Jigsaw and sanding modules).  Festool USA does not  endorse the use of these components and will not support them with spare  parts or repairs. The use of anything other than the OF 1400 and OF 1010 routers and their related accessories with the CMS will void the warranty agreement on the entire system for customers within the US and Canada. Festool does not endorse the application or use of any Festool product in any way other than in the manner described in the Festool Instruction Manual. To reduce the risk of serious injury and/or damage to your Festool product, always read, understand and follow all warnings and instructions in your Festool product's Instruction Manual.
