Pages: [1]   Go Down
  Print
Author Topic: Rotex 150 sander-sanding planed poplar  (Read 2083 times)
Rick Caviglia
Offline Offline
« on: February 02, 2010, 01:42 AM »
Hi, I'm wondering if anyone could advise me on my use of the Rotex 150. Up until now I've milled all the trim boards from 80 year old fir that I salvaged from the demo. But now I've bought some lumber and I'm sanding 1x7 poplar baseboards that have been planed. These then get painted with a coat of oil based primer and a latex finish. I didn't want to get too aggressive so I've been starting with 100 grit and ending with 120. It's been taking quite a while to get all the "planing lines" out and I'm wondering what others out there do. Should I be starting at 80? It seems that the fir was sanding faster, but maybe I'm just getting tired. It's taking me 30-45 minutes per 10' board
Thanks in advance for any advice.
Rick
BTW-I bought the new Festool sanding blocks set and they're really comfortable to use. Best I've ever had.
Alex
Offline Offline
« Reply #1 on: February 02, 2010, 06:00 AM »
I usually do this with 60 or 80 grit crystal.
Tom Bellemare
Festool Dealer
Online Online
WWW
« Reply #2 on: February 02, 2010, 12:19 PM »
Rick:
It really depends on how smooth your planed pieces are.
Let's assume it calls for starting with 60, like Alex suggests. I'd:
  • use gear driven mode (mode switch to the left) with 60 until it looks "fuzzy" instead of seeing the planer marks,
  • switch to RO mode (mode switch to the right) with same paper and give a once over,
  • use gear driven mode (mode switch to the left) with 80 until it looks "fuzzy" instead of seeing the marks from the rougher grit,
  • switch to RO mode (mode switch to the right) with same paper and give a once over.
At grits 100 and up, I'd stick to RO mode until about 500 or 1000 (polishing). Then I'd go back to strictly gear driven mode.
I realize your not going that high but if you were...
I don't think you save time by skipping grits or steps. It's too easy to change from step to step or grit to grit with this system.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
RonMiller
Offline Offline
« Reply #3 on: February 02, 2010, 01:11 PM »
What Alex said.
Ron
Rick Caviglia
Offline Offline
« Reply #4 on: February 02, 2010, 06:28 PM »
Thanks Tom,
I never thought of going all the way down to 60 grit (thought it would be too rough). I have some 50 grit, I guess I'll test that on the backside of a board.
Thanks again,
Rick
Pages: [1]   Go Up
  Print
Jump to:
