Author Topic: Router and mft 3  (Read 3657 times)
Offline Eczan
Router and mft 3
« on: July 30, 2017, 04:39 PM »
Hello !
I like to know if someone can advise me how to place / hang Festool Router 1400 under the MFT 3, so I can use the MFT 3 like a router table.
Perhaps there is already a good construction and description how to do that.
Many thanks !
Regards,
Ed.
Online ear3
Re: Router and mft 3
« Reply #1 on: August 03, 2017, 07:29 AM »
He uses a different router:
I imagine there might be some issues with setting the depth if you were to try to attach the 1400, but why not give it a try and report back?
In case you don't already know and are prepared to spend $$$, there is the CMS attachment for the MFT:
http://www.festoolproducts.com/festool-57000025-cms-vl-mft-3-router-table.html
http://www.festoolproducts.com/festool-57000024-cms-vl-mft-3-router-table-set.html
« Last Edit: August 03, 2017, 07:38 AM by ear3 »
Offline Peter Halle
« Reply #2 on: August 03, 2017, 08:40 AM »
Personally I am not a fan of the thought of mounting a router into the MFT, but can see the appeal.
Here is a video link from Guido Henn that might give you some ideas - especially how to mount the router:
Offline Peter_C
« Reply #3 on: August 03, 2017, 03:03 PM »
A Festool rail works pretty well as a straight fence too. A couple blocks of wood on each side of the bit allow you to create most any fence situation needed.
Personally I would recommend using a piece of melamine and a couple of saw horses. That way you get a proper router plate and are not cutting a giant hole into the MFT top.
A cheaper Triton router would work great to permanently leave in the router table too. It allows top height adjust when mounted in a table.
Offline Naildrivingman
« Reply #4 on: August 05, 2017, 06:56 AM »
I would be concerned about deflection of the MDF top with weight hanging from it (probably negligible if you don't leave the router attached for long periods of time).
Dance with who brung ya...
Offline Bohdan
« Reply #5 on: August 05, 2017, 08:35 AM »
I mounted an ELU MO177 router in an MFT1080 Table and the top promptly sagged in the middle. I had to brace the top from underneath with some steel braces and some bolts to adjust the level of the top. I also found that the effort to get it out and put it back was too much trouble and bought an OF2020 as another router. That subsequently finished up in a CMS table and I don't use the ELU much.
Offline Eczan
« Reply #6 on: August 05, 2017, 03:22 PM »
Many thanks for all your advice and suggestions! Very helpfull!
I think I will make the router table as demonstrated of the video Peter Halle posted.
So glad I have joined FOG. So many usefull information.
Regards,
Ed.
Offline Eczan
« Reply #7 on: August 06, 2017, 04:56 PM »
I also found this inspiring video on YouTube. A very simple and genius router table.
