sawdustinmyshoes
OfflineMember Since: Jan 2008
« on: September 04, 2009, 09:21 PM » |
Another tip picked up during End User Training at Indy: We've all been frustrated at least once by our screw clamps not cinching up without several turns of the screw. Adopt this method for guaranteed results within 1/2 turn. Simply apply pressure downward and inward (blue arrow) where the clamping arm meets the bar while turning the screw with the other hand.   Joe
« Last Edit: April 26, 2012, 12:18 PM by sawdustinmyshoes »
Neill
Offline
« Reply #1 on: September 04, 2009, 10:45 PM » |
Joe, I know you guys were there for only two days, but how many hours were you there each day? Great tips and thanks again for sharing.  Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
ForumMFG
Offline
« Reply #2 on: September 05, 2009, 10:44 AM » |
Neill,
Monday - 8:30 to 5:00 training 5:00-8:30 cookout Tuesday - 8:30 to 4:30 training 4:30 - 6:30 feedback discussions
-Dave
JJ Wavra
Offline
« Reply #3 on: September 05, 2009, 07:42 PM » |
Another thing that I use is the magswitch. If I am clamping the same size over and over I put it right above were joe has his finger so that the arm does not fall down makes things a lot faster.
JJ
ForumMFG
Offline
« Reply #4 on: September 05, 2009, 09:33 PM » |
JJ, now thats a good tip, I like that.
bruegf
Offline
Michigan
« Reply #5 on: September 06, 2009, 12:07 AM » |
A couple of other things that were mentioned to keep the clamp arm from falling down was the use of o-rings and there was also a mention of drilling holes through the arm to allow insertion of a roll pin.
Fred
Fred
Peter Halle
Global Moderator
Offline
« Reply #6 on: September 06, 2009, 04:52 AM » |
Fred,
I ran across what I was trying to think of at the class. Brice uses tubing on his clamps. He has it posted on his website.
ForumMFG
Offline
« Reply #7 on: September 06, 2009, 05:03 AM » |
Fred,
Peter, For what?
Peter Halle
Global Moderator
Offline
« Reply #8 on: September 06, 2009, 05:35 AM » |
Here is the link for Brice's video. I watched it a long time ago. Unfortunately I am using a Mac and can't view his video. http://www.burrellcustomcarpentry.com/subpage50.htmlPeter
Jerome
Offline
« Reply #9 on: September 06, 2009, 06:55 AM » |
If you option click then select to open it with Quicktime player you will have no problem. I don't.
Jerome TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone. Wish list WoodRat, Workshop supplies drum sander http://www.flickr.com/photos/nui-jerome/
Brice Burrell
Offline
Remodeling Contractor
« Reply #10 on: September 06, 2009, 09:24 AM » |
Peter Halle
Global Moderator
Offline
« Reply #11 on: September 06, 2009, 09:45 AM » |
Thank you Brice.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #12 on: September 07, 2009, 01:51 PM » |
Great tip, Brice. You could also use a piece of tubing slipped over the longer arm of the L-shaped frame of the Festool "F-style" clamp to prevent the arm of the Festool clamp from sliding beyond a present point, instead of using the magnet as described by JJ. O'Rings mentioned by Fred are a great idea for this purpose, too.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
WarnerConstCo.
Offline
« Reply #13 on: September 13, 2009, 12:31 AM » |
The finger tip might be my favorite from the whole thing.
Wierd huh?
