Pages: [1]   Go Down
  Print
Author Topic: Face Frame Construction with Domino  (Read 1894 times)
MarKoz
Offline Offline
« on: June 19, 2012, 11:35 PM »
I see lots of posts on how to join face frames to cabinets with the Domino but can't find anything about constructing the face frames themselves.  Bear with me because I am a total noob.
I have rails and stiles that are 25 mm deep by 50 mm wide.  I can centre the tenon in the stile using the saddle fence - that puts the centre of that mortise 25 mm from the edge.  The alignment pins on the base of the Domino will put the centre of the mortise in the rail 37 mm from the edge.  I would like to make both mortises at the minimal width so the tenons can draw the parts into alignment.  Is there a way to make the centre of the mortise in the rail 25 mm from the edge?  I know I could just draw a pencil line 25mm from the edge of the rail and use the line scribed in the clear plastic reference scale but wonder if that would be accurate enough.
Any help would be most appreciated.
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #1 on: June 19, 2012, 11:50 PM »
Try this, Multi-Position Guide Stop or Self Centering Guide Stop.
MarKoz
Offline Offline
« Reply #2 on: June 20, 2012, 12:09 AM »
Awesome!   Thanks so much!
davee
Offline Offline
« Reply #3 on: June 20, 2012, 08:07 AM »
I don't have the guide stop (although it looks very nice), and just use the pencil mark with good success.  I typically do not use dominos in face frames as they are well contained once mounted to the frames.  I do use dominos in cabinet doors, etc. that require more strength.
Upscale
Offline Offline
« Reply #4 on: June 20, 2012, 08:44 AM »
The last face frame (oak) construction I did (for own use) before I bought myself a Domino, I used an invisible nailing kit (nails countersunk under a raised shaving of wood). And, while I didn't use any type of attachment between rails and stiles, it's held up well. But in saying that, I've always been apprenhensive about the wood suffering expansion and contraction problems producing gaps.
Now, I'd want to use the Domino to attach the rails and stiles if only to add a little extra support  protection against possible gaps appearing.
DF 500 Q, HL850E-Plus, CT22, 5 systainers and several accessories. I'm just a rank Festool beginner, but I'm trying hard. Smiley Oh yeah, now that I own a FOG hat 2011 edition, I guess I'm not such a beginner anymore.
fshanno
Offline Offline
« Reply #5 on: June 20, 2012, 07:14 PM »
I wouldn't recommend that for face frames.  End grain on the tight setting and side grain on the middle setting.  It's easy to tap the parts into alignment during assembly.  It's very handy to cut story boards for locating mid rails and mid styles.
Pages: [1]   Go Up
  Print
Jump to:
