Pages: [1]   Go Down
  Print
Author Topic: TS 55 EQ Plus - Bevel cutting adjustment on track?  (Read 1641 times)
Tomfoolery
Offline Offline
« on: April 21, 2012, 12:14 PM »
Well - I took the plunge (so to speak) and started my Festool ownership with a TS 55 EQ + CT 36 e
My question is how do I adjust the saw so a bevel cut is in-line with a straight cut?
When i clamp my guide to a workpiece and have the saw set to 0 degrees - make a cut and then set the saw to 45 degrees and make a plunge cut shorter than the previous cut the top edge of the workpiece is not lined up.
The bevel cut seems to have the top edge 1-3mm closer to the saw.  It is visibly noticeable.
Any ideas?
Thank you all in advance!
-Tom
« Last Edit: April 23, 2012, 09:37 AM by Tomfoolery » Logged
Zacharytanner
Offline Offline
« Reply #1 on: April 21, 2012, 01:25 PM »
Welcome,
Go to Bob Marino's Festool site and on the left side click on Tips and Tricks and print the TS55 Guide from Rick,
Best,
Frank
Festool Kapex KS 120EB w/ 4 Blades
Domino DF500 Set
Domino DS Systainer 4,5,6,8,10
TS55 w/ FS1400 and FS2700 Rails
MFT/3 with Accessories
CT33E
D36 Tradesman
Trion PS300 Jigsaw
RTS 400 EQ Orbital Sander
RO 125
125  Abrasive Systainer with , 60,80,100,120,220 Grit Festool paper
2 Systainer Carts
Festool T18+3 Kit
CXS Kit with Centrotec Wood Bits
ETS 150/3
150 Abrasive Systainer
Festool Toolie
RO 90
RO 90 Abrasive Systainer
OF 1010 Router
Frank
hockey_magnet
Offline Offline
« Reply #2 on: April 21, 2012, 06:06 PM »
The cut edge on the rail side, should line up, The cut edge on the saw side can't possible line up, Per previous response, this is clearly indicated in the guide referred to on page 7 under "single point of entry.
Tomfoolery
Offline Offline
« Reply #3 on: April 21, 2012, 06:22 PM »
I read page 7:
"Single point entry means that the sawblade always enters the cut at the same location regardless what the bevel angle is set to. The pivot point of the bevel adjustment is located at the bottom edge of the splinter guard. This means that the cut will always be along the splinter guard for any bevel setting.
(Note that this is applicable only when the guide rail is used. When the guide rail is not under the saw, the bevel cut will move slightly outward, away from the main body of the saw.)"
and what is happening in my case is that when I cut a bevel cut the right side of the blade (looking at the picture) is moving right (toward the saw).
The two cuts do not line up on the once side of the blade.
I am just trying to reproduce the cut shown in the the picture and I can't.
Thoughts?
« Last Edit: April 23, 2012, 09:38 AM by Tomfoolery » Logged
Tomfoolery
Offline Offline
« Reply #4 on: April 21, 2012, 06:41 PM »
I just found this thread:
http://www.talkfestool.com/vb/festool-tools/5099-ts55-bevel-cut-offset-2.html
Looks like I am returning the saw...
Tomfoolery
Offline Offline
« Reply #5 on: April 23, 2012, 09:36 AM »
Update:
I took the saw back to the dealer - they setup everything to try and duplicate the problem i was having.
In their location the saw performed as expected - If I am wrong about something I will admit it.
One "trick" they used when changing the bevel on the saw was to remove it first from the track - this is something I did not do.
Apparently whenever I adjusted the bevel on the saw there was enought lateral force to move the track even though it was clamped.
I learned something about the "system" and really appreciate the time the dealer took to help set me straight.
Thank you all for your patience with a newbie!
Pages: [1]   Go Up
  Print
Jump to:
