sawdustinmyshoes
OfflineMember Since: Jan 2008
« on: September 03, 2009, 08:38 PM » |
 With this grip, my fingers don't physically fit between the plug and the saw base.   When changing to an alternate grip, my knuckles wedge against the handle.  But look what happens when the bevel is adjusted to 45 degrees.  Success! Acres of room.  Joe
« Last Edit: March 10, 2013, 11:40 AM by sawdustinmyshoes »
ForumMFG
Offline
« Reply #1 on: September 03, 2009, 09:15 PM » |
Nice!! Thanks for pointing that one out, I forgot about that one!
Brice Burrell
Online
Remodeling Contractor
« Reply #2 on: September 03, 2009, 09:35 PM » |
Some guy has been preaching that one for a few years now, last year he even made a video for youtube.
Brice Burrell
Online
« Reply #3 on: September 03, 2009, 10:20 PM » |
Dang, Brice! I've visited your site several times but don't recall that tip. It would have saved me some aggravation.
Joe
Real astute vistor I see, Tips for the TS55 and TS75.  Still I'm glad you posted this tip, maybe more people will see it.
« Last Edit: September 03, 2009, 10:21 PM by Brice Burrell »
Neill
Offline
« Reply #4 on: September 03, 2009, 10:24 PM » |
Brice, Who was that masked man? Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
Brice Burrell
Online
« Reply #5 on: September 03, 2009, 10:26 PM » |
Brice,
Neill
You mean that guy that shouldn't be front of a camera, I have no idea.
Nigel
Offline
« Reply #6 on: September 05, 2009, 03:02 AM » |
Plunging on the side of the mft gives more access if your in a hurry!
Tom in SoCal
Offline
« Reply #7 on: September 10, 2009, 01:52 AM » |
But why on earth should you have to go through all that -- just to plug in the cord? It should have been put in a more accessible location.
-TH
Tom Ryan
Offline
Location: State College, PA (moving soon to Wallingford, PA) Member Since: Mar 2007
« Reply #8 on: September 12, 2009, 02:07 PM » |
If it bothers you, just plug it in and leave it. Then you can treat it as a saw with a fixed cord like almost any other saw.
kosta
OfflineMember Since: Jul 2009
« Reply #9 on: September 12, 2009, 02:52 PM » |
-TH
A more accessible location is a bad idea. Better to have the cord hidden and out of the way.
joiner1970
Offline
« Reply #10 on: September 12, 2009, 04:29 PM » |
Alex
Online
« Reply #11 on: September 12, 2009, 05:33 PM » |
Well, I don't see the benefits of the Plug-It cord so much.
When I just had my Rotex I would unplug it all the time, but I think that was more to play with a new feature I never had before than that it was really necessary.
Because now I leave the Plug-It cords attached all the time on my tools, I hardly ever take them off. I just see no need for it. After all, when you gonna use the machine, you need the cord, right?
« Last Edit: September 12, 2009, 05:34 PM by Alex »
Brice Burrell
Online
« Reply #12 on: September 12, 2009, 07:45 PM » |
Alex, I use velcro straps to attach the cord to my vac hose so I remove the plug-it from the tool end to change tools. I do keep a cord in each Systainer so I'm never without one on the job.
Alex
Online
« Reply #13 on: September 12, 2009, 08:29 PM » |
Yes, that's definitely a good reason. Hadn't thought about that since I never do that.
Jerome
Offline
« Reply #14 on: September 12, 2009, 10:10 PM » |
Another way is to use the hose wrap. I always want the CT22 hooked up as well as the power. Here is one of the setups I use.
Jerome TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone. Wish list WoodRat, Workshop supplies drum sander http://www.flickr.com/photos/nui-jerome/
ForumMFG
Offline
« Reply #15 on: September 12, 2009, 11:54 PM » |
Whats the deal with the hose wrap? I'm really not following you here.
Jerome
Offline
« Reply #16 on: September 13, 2009, 01:52 AM » |
It keeps the powe cable and vac hose together and so reduces clutter. It also means I always have both to hand. It is not an original.
Nigel
Offline
« Reply #17 on: September 13, 2009, 02:44 AM » |
I thought the point of the plug -it was to make it easier to change tools.I always change plug-it and hose at the tool.Once it wears in a bit it's easy enough to turn.A lot easier than changing the the cord and the tool.
Charimon
Offline
Tool and Tile Junkie
« Reply #18 on: September 13, 2009, 03:24 AM » |
It keeps the powe cable and vac hose together and so reduces clutter. It also means I always have both to hand. It is not an original. The other advantage, some would even say PRIMARY Advantage, a cord wrap provides is a much more "snag free" surface than the rail catching bumps of an nonwraped hose. Craig
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
Tom Bellemare
Festool Dealer
Offline
« Reply #19 on: September 13, 2009, 11:24 AM » |
I think the biggest advantage of the plug-it syste,m other than leaving the cord with the hose, is that when your cord gets torn up, cut up, or otherwise abused, you just change it out.
I have taped or spliced a few cords in the past. No need with this system.
Daniel_n
Offline
« Reply #20 on: September 13, 2009, 12:24 PM » |
I dont really agree with you on this one Tom. "Just change it out" sounds good - but at 31USD (in Sweden, don't know how much it is in the US) it is horribly expensive. Not even the pros, that of course are much more in a hurry than me as an amateur to quickly fix a broken cable, can possibly benefit from this, as it only takes a few minutes to change a standard cable, and it costs way less than 31USD. Although I still like the plug-it cable, as the quality of the cable itself is excellent and it is very convenient to leave the cord with the hose.
« Last Edit: September 13, 2009, 03:02 PM by Daniel_n »
ForumMFG
Offline
« Reply #21 on: September 13, 2009, 04:28 PM » |
Well, If you own more than 1 festool tool and you only use one plug for all your tools then when one breaks you can switch it out with another cord you already had. I have a drawer full of plug it cords that are still brand new and I only use one 16 ga cord and one 18 ga cord. Plus, regardless of the price, being able to quickly change out a damaged cord is a lot safer then trying to jerry rig it.
Daniel_n
Offline
« Reply #22 on: September 13, 2009, 04:51 PM » |
Agree with you regarding the cables I already have. But regarding the safety - what's a jerry rig? A simple fix solution with duct tape or something? I meant a proper change of cable, which is more dangerous than just changning to another plug-it cable only in theory (assuming you know what you are doing).
Alex
Online
« Reply #23 on: September 13, 2009, 05:22 PM » |
There's nothing 'jerry rigging' about changing out a cord. It's very easy because all you need to do is unscrew a couple of screws and then tighten them back up with the new cord in. Of course there are people who are able to this up  , but those people shouldn't be allowed near tools anyway. I maintain and repair all my tools and it's no rocket science. Of course the Plug-It cord is much easier to replace, but the steep price of 17 euros compared to a normal replacement cord of 4 euros is not nice.
ForumMFG
Offline
« Reply #24 on: September 13, 2009, 09:04 PM » |
I was referring to this comment as "Jerry Rigging". I know there is nothing jerry rigging about switching out a new cord..
Brice Burrell
Online
« Reply #25 on: September 13, 2009, 09:49 PM » |
The prices are $35 and $36.50 USD for the Plug-it cords here in the States. Funny thing is the heavier gauge cord is cheaper, strange.
richard.selwyn
Offline
Normandy, France
« Reply #26 on: September 14, 2009, 04:30 PM » |
I probably use the TS 55 nearly every day and would really miss the plug it cord (which I have never had any trouble attaching at 90 degrees). Switching from saw to one sander then another is a breeze with the boom arm and the plug it. Switching to other tools like the biscuit jointer is less quick and easy. The only time I have regretted it is when I arrived on site without one (I've got a whole pile in the drawer as well). Hope I won't do that again.
Wonderwino
Offline
Location: American Bison Country Member Since: Apr 2008
« Reply #27 on: September 14, 2009, 05:38 PM » |
I like the plugit cords because I have the heavy one "permanently" attached to the boom arm on my CT33 and can just change tools (TS75, Domino, sanders) without threading a power cord each time.
Water separates the people of the world; wine unites them.
