Author Topic: TS55 Cuts Wider in the Middle  (Read 3784 times)
Offline GoingMyWay
« on: September 14, 2018, 10:09 AM »
I've finally gotten back to doing some woodworking versus just cooking and taking pictures of food  ;).
Yesterday I bought a 5'x5' sheet of 3/4" baltic birch plywood.  I had it cut into roughly 3' and 2' pieces so it could fit into the back of the car to take home.
I was attempting to rip down a 10" x 5' piece of the plywood using my TS55 with a the blade that came with the saw.  I was using a brand new 75" rail that I had just cut the splinterguard prior to making my cut.
As you can see in the pictures the two end sections of the cut is pretty much right at 10", but the middle of the rip is something like 1/32" wider than either end.
285033-0
285035-1
285037-2
I initially made my cut using the edge that was the cut with the panel saw from the store as my reference.  I was thinking that maybe, somehow their saw was off so I made another 10" rip using the factory edge.  This time it looks to be almost 1/8" wider in the middle.
285039-3
285041-4
285043-5
I may actually be reversing which scenario resulted in the 1/8" difference, but in either case the middle of the cut does seem to be wider than either end.  Any ideas what could be causing this?
Thanks!
Inquiring Minds Want to Know
Offline DynaGlide
Re: TS55 Cuts Wider in the Middle
« Reply #1 on: September 14, 2018, 10:18 AM »
Off topic but who did you buy it from? I need to get some myself
Offline GoingMyWay
« Reply #2 on: September 14, 2018, 10:21 AM »
I got it from Harwoods in the Rough out in Manassas.  It was $62.54 with tax.  I had previously bought a small piece of baltic birch from Woodcraft, but that was $50 for less than half a sheet.
I believe Tart Lumber in Sterling sells the baltic birch for closer to $50 before tax.
Offline RKA
« Reply #3 on: September 14, 2018, 10:28 AM »
Well, don't rely on the factory edge or the panel saw to be straight.  Second, do you have a reference straight edge you can put along the raised profile on the track to check for straightness?  Make sure  the gibs are adjusted snug so the saw can't be moved sideways.  Even if that is properly done, you can introduce variations by shifting your grip or how you apply pressure to the handle, so try to remain consistent throughout the cut to minimize variations.
-Raj
Offline DynaGlide
« Reply #4 on: September 14, 2018, 12:13 PM »
Thanks. The last sheet I bought was from Colonial Hardwood near the Costco in Springfield. It was somewhere around $60.
Offline GoingMyWay
« Reply #5 on: September 14, 2018, 12:31 PM »
I forgot I should have probably trimmed off maybe 3/8" from either edge.  I'm just trying to make a clamp rack to hang on the wall so it actually doesn't matter if the cuts are even or square.
I have a 12" and 24" veritas straight edge, but they're rather short compared to a 75" track.  I also have a 30" stabila level, but I don't know that a level is quite the same thing as a straight edge.
I had said that the 75" track is "new" but it actually came with the reconditioned TS75 that I got from festoolrecon.com, so I guess the track could conceivably have been used also.  I did make sure that the saw base was tight to the track with no movement.  I also clamped the track to the plywood at both ends when I made my cut.  Hmm it could have been how I was pushing the saw - I admittedly did sort of speed up the push a little bit since it's just 3/4" sheet material.
I suppose I could retest with my TS75, but I'd really like to try to keep the remaining plywood in as large a piece as possible for a future project.
I just double checked the voicemail that Tart Lumber left me when I asked for a quote a month or 2 ago.  They charge $58.29 before tax for the 3/4" 5'x5' baltic birch, so I guess that's about the average going price.  On a side note, they quoted me a $30 delivery charge to Fairfax.  Hardwoods in the Rough quoted $50 to deliver to Fairfax.  I sometimes wish I had a truck as I have no way of getting full size 4'x8' sheet goods home.  If I had to pay for delivery I'd want to buy plenty of sheets so I wouldn't run the risk of needing to reorder and pay a delivery fee again.
Offline RKA
« Reply #6 on: September 14, 2018, 01:19 PM »
Using the level is fine to verify that the extrusion is indeed straight.  Even new extrusions have been reported to be somewhat wonky (I haven't experienced that myself).
As for the delivery price, there is another way to look at it.  Factor in a delivery 4-5 times a year.  Compare that to the insurance and maintenance of the truck (assume you bought something used where you could resell and recoup your initial outlay).  Even with a monthly delivery you still come out ahead.  I've used this justification myself and either rent or have HD deliver once a year.  My closest lumber yard delivers only during business hours, which doesn't work for me, that's where I miss the truck.  And sometimes I feel like taking a trip to a not-so-local hardwood dealer, not knowing if I will find something interesting.  It would be nice to have the ability to drag home whatever catches my eye.
-Raj
Offline GoingMyWay
« Reply #7 on: September 14, 2018, 01:55 PM »
Oh I forgot I also have a cheap 4' level from home depot as well.
I was only very light heartedly yearning for a truck.  I think delivery is much more economical all the way around (I'm just kinda cheap when it comes to paying for shipping.  Amazon Prime has made me believe I should try to avoid paying shipping whenever possible).  I had also thought about renting a van or truck, but the hassle of putting more gas in and returning the truck comes out to almost as much as the delivery fee.  I'm also not strong enough or don't have long enough arms to pick up a 4'x8' sheet by myself so it would be more convenient to just have it delivered to my garage.
« Reply #8 on: September 15, 2018, 04:22 AM »
Did you have enough support under the sheets so they didn't flex/bog down in the middle when you were running the track saw?
I usually run parallel support for long cuts along the cut line unless the sheets are small and then I cross brace them and make sure there is no flex at either end or in the middle before critical cuts.
It's either that or maybe if your tracksaw was not laterally adjusted to the track with them adjustment knobs so you had some play from side to side gouging out a wee bit more as you went along and could not keep parallel with the track with the baseplate due to lateral shift.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline Sparktrician
« Reply #9 on: September 15, 2018, 08:26 AM »
@GoingMyWay, I bought Baltic birch from Tart in 2010 at ~$107/sheet (4' x 8').  You might want to look very carefully at Garnica plywood at Hardwoods in the Rough.  It's very nice stuff with no voids, and a bunch less expensive than Baltic birch.
« Last Edit: September 15, 2018, 08:28 AM by Sparktrician »
- Willy -
Offline GoingMyWay
« Reply #10 on: September 15, 2018, 09:23 AM »
I was cutting on a piece of 2'x4' MDF.  The first cut was fully supported by the MDF (with the exception of the ends that were overhanging by ~6 on either side), but the second cut I made was actually skewed a bit on the MDF that maybe half or 3/4 of the end of the cut was not supported at all.  That could definitely be part of the problem that I hadn't considered at all - though the end of the cut still measured close to 10".
The track adjustment knobs were tight so there wasn't any play or wiggle on the track.
Tart Lumber said they only have 5'x5' sheets of baltic birch now.  I wish I had known to look at the Garnica plywood when I was there.  Do you know about how much that goes for?  It's a 4'x8' sheet I assume?
« Reply #11 on: September 15, 2018, 07:08 PM »
When I ordered the 4' x 8' Baltic birch, @GoingMyWay, it was a special order; it was not in stock.  I don't know the current pricing for Garnica.  It does come in 4' x 8' sheets.
- Willy -
Offline DynaGlide
« Reply #12 on: September 15, 2018, 08:39 PM »
Hardwoods in the rough no longer carries Garnica
« Reply #13 on: September 16, 2018, 09:40 AM »
Bummer!!!  A&M Supply in Upper Marlboro is apparently the only supplier in the area now.  They also have an outlet in Henrico, VA.
- Willy -
Offline Peter Halle
« Reply #14 on: September 16, 2018, 11:36 AM »
@Sparktrician , thanks for the source.
Offline Gregor
« Reply #15 on: September 16, 2018, 11:46 AM »
You can check straightness of the rail by putting it with the splinterguard edge against the edge of the piece that was just under it at the cut (flipping it over or turning it) - any error will double, should it not be straight you'll see it.
Offline RKA
« Reply #16 on: September 16, 2018, 12:59 PM »
@GoingMyWay  Any luck sorting this out?
-Raj
« Reply #17 on: September 16, 2018, 01:23 PM »
"...I was cutting on a piece of 2'x4' MDF.  The first cut was fully supported by the MDF (with the exception of the ends that were overhanging by ~6 on either side), but the second cut I made was actually skewed a bit on the MDF that maybe half or 3/4 of the end of the cut was not supported at all.  That could definitely be part of the problem that I hadn't considered at all - though the end of the cut still measured close to 10"...."
Ok, that isn't a large board - but was the MDF supported? And if so, by what? Laying out MDF between two sawhorses will not make them all that flat - especially running a track saw with a little pressure on. Unless supported length wise too they will deflect some during cutting. When I cut sensitive material like Corian/Staron I need to ensure the whole length is fully supported and straight with no flex before committing to the final cut.
"...The track adjustment knobs were tight so there wasn't any play or wiggle on the track...."
Ok, that's not it then.
Offline GoingMyWay
« Reply #18 on: September 16, 2018, 03:17 PM »
I hadn't had a chance to test the straightness of the rail yet. I won't be able to do that until next weekend at the earliest.
The MDF was sitting on top of 4 bench dogs on my Kreg table. I'd think that was supported enough. I didn't think I was pushing down that hard.
« Reply #19 on: September 17, 2018, 08:05 AM »
Let me know if you need a second rail to compare to.   [smile]
- Willy -
Offline ElectricFeet
« Reply #20 on: September 17, 2018, 09:46 AM »
I was attempting to rip down a 10" x 5' piece ... but the middle of the rip is something like 1/32" wider than either end.
I initially made my cut using the edge that was the cut [in] the store ... [then] I made another 10" rip using the factory edge.  This time it looks to be almost 1/8" wider in the middle...
My gut tells me that the material was bowed (in storage) or is bowing (while cutting), but more data is needed:
First, let me get this straight (no pun intended). You have tried to cut 2 x 10" pieces from either side of a single piece and they are both wider than the desired 10" in the middle.
Question: How wide is the remaining centre piece -- at the ends and centre? That is, the centre piece you left behind when you cut off 10" from either side.
If EITHER (1) the edges of that centre piece are parallel (it is of equal width all the way along) OR (2) the width increases uniformly from end to end, then you're cutting straight and the factory or the shop (or both) are messed up.
If on the other hand, they too are bowed, then something's happening in the cutting or the material itself is bowed.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #21 on: September 17, 2018, 10:48 AM »
Ok coming in this thread late, my suggestions are
1) remove factory edge first.
2) verify you cutting technique, using 2 hands on the saw even pressure through the cut.
3) make sure you ply is supported completely under the ply. Some people use foam insulation
4) Clamp the ply make sure it isn't moving on you (prolly isn't but thought id throw it out there)
Hope tis helps
Offline GoingMyWay
« Reply #22 on: September 26, 2018, 06:43 PM »
I finally got around to test the straightness of the guide rail. I may have done the testing incorrectly or what I have measured may be totally irrelevant, but nonetheless here is what I did:
The splinterguard appears to match up with the cut edge of the plywood.  It also appears to match up if I flip the guide rail upside down and place it against the cut edge.
285354-0
285356-1
When I tested the back of the guide rail against the cut edge there was quite a large gap.  The back of the guide rail appeared to be flush with the factory edge of the plywood.
285358-2
285360-3
I also placed a 30" Stabila level against the middle of the cut edge and there was a .009" gap.
285362-4
285364-5
P.S. the plywood is bowed - I have been storing it at an angle against the wall.  I'm not sure if it was bowed when I bought it or my cut piece developed the bow from leaning against the wall for the last 2 weeks.
The 5'x5' piece of plywood was cut into approximately 3'x5' and 2'x5' pieces.  I actually made 1 cut from each different piece of plywood.
The remaining large piece that I have measures approximately 25 15/16" at the top, 25 15/16" in the middle, and 25 7/8" at the top (the width did seem to be tapering as I went up).    That makes it sound like the guide rail might have been askew when I made the cut.
Would it make more sense to "start from scratch?"  I have a GRS-16 guide rail square if that might help me.
Offline lwoirhaye
« Reply #23 on: September 26, 2018, 07:50 PM »
Well, plywood is not an inert material.  When cut sometimes internal stresses change and an edge can go a little banana-shaped.   For some work this is not an impediment and can generally be ignored.
I have an edgebanding press that requires quite straight cuts to do a good job, so I'm obliged to pay attention.  On long pieces of ply I want to band, I rip them a little oversized, let them move overnight if they want to and recut any edges that have gone wonky.
Offline GoingMyWay
« Reply #24 on: September 27, 2018, 07:33 AM »
I'm thinking this is more operator error (incompetence) rather than any internal or external plywood movement.
« Reply #25 on: September 27, 2018, 07:51 AM »
If you’re clamping a long rail at both ends to a bowed piece of plywood, then things will inevitably shift during the cut.
The board looked to be bowing “up” at the edges in the photo of your first cuts. If the straight rail is sitting on top of a concave board like this, then there will some space between the rail and the board as you reach the middle of the cut. The weight of the saw (and the not inconsiderable forces it’s exerting on the board) will force either the wood to conform, or the rail to conform, or the “far” clamp may shift slightly.
I don’t think the GRS-16 will help over these distances. Measuring a large 3-4-5 Pythagorean triangle will get you squarer. But “being square” won’t solve the “being straight” problem.
A flat floor with a well-supported board would be my first choice if it’s available. Or you could try clamping the rail to the ply AND something else that’s straight undeneath — effectively sandwiching the ply flat for the cut.
Or wait another couple of week for it to bow back again  [wink]
« Reply #26 on: September 27, 2018, 08:12 AM »
Unfortunately this is necessary more often than one would expect.
Offline DynaGlide
« Reply #27 on: September 27, 2018, 08:46 AM »
Bowed plywood from Hardwoods in the Rough?  ::) Same thing happened to me but it wasn't as nice as your 5x5 BB. The stuff I bought from Colonial Hardwoods has some leftover sitting against a wall on end and to my eye is still straight.
Offline SRSemenza
« Reply #28 on: September 27, 2018, 09:57 AM »
I have had plywood bow in the horizontal direction, not much but  a little. It has always occurred with plywood from a big box.  And also with 5 x 5 baltic birch.
« Reply #29 on: September 27, 2018, 04:12 PM »
No plywood is really flat (if that’s what you guys are talking about) compared to MDF or particle board. What bugs me and Iwoirhaye is when the core plys are stressed differently than the surface plys and when the sheet is cut the cut line is not straight. Sometimes it’s an immediate reaction sometimes it takes a while. Once made a bunch of cabinets from pre-finished maple ply (Columbian, not made in Col.) and every part had to be rough cut oversized then cut again later to get a straight edge.
