Author Topic: Vac-Sys & Ro 90 Tip/Maintenance  (Read 746 times)
Offline Mario Turcot
« on: February 09, 2019, 02:30 PM »
I went into the shop on Friday to find a white plastic cap about 2cm in diameter on the ground. Before I throw it in the scrap bin, I tried to find out where it could come from. Here my finding
One of the Vac-Sys screw went lose pop out the cap and was about to fall from the base. The Vac-Sys has been used for about 5hrs max. The reason for the screw to get lose is probably about vibration.
Lesson learned #1: Check both screws before and after each use  [smile]
A good friend of mine borrowed the RO 90 to sand a few doors. He was using the Delta pad and when I removed the pad to put back the circular one I found this.
And this is how it should look  [big grin]
Lesson learned #2: Clean residue regularly, not only when you switch pads.
« Last Edit: February 11, 2019, 06:48 AM by Mario Turcot »
Mario
Offline grobkuschelig
Re: Vac-Sys & Ro 90 Tip/Maintenance
« Reply #1 on: February 09, 2019, 04:21 PM »
Hi Mario,
I also noticed this, even when the RO90 is used with the round pad in normal fashion.
I keep a small, maybe 1/2 inch wide paint brush in the Systainer. Makes cleaning out the pad mount a breeze...
Offline Sanderxpander
« Reply #2 on: February 09, 2019, 04:48 PM »
My Ro 90 fills up quickly too, I use a brushed nozzle on my vac to clean it.
« Reply #3 on: February 11, 2019, 06:50 AM »
Found a new home for my old toothbrush  [cool]
Mario
