Author Topic: What is best method to stabilize domino in middle of board  (Read 13663 times)
Offline scr00ge
« on: January 21, 2013, 08:10 PM »
Hello, I have just got my domino and put it right into production.  I notice it wants to kick when in the middle of a board without an edge to grab, I had the base support bracket on.  The material is prefinish maple,which tends to be a slippery surface. I was using domino to join the deck to a partition of an upper cabinet.  I'm sure this question has been asked, and someone could direct me to the post.  Thanks :)
« Last Edit: January 21, 2013, 10:17 PM by scr00ge »
Offline Peter Halle
Re: What is best method to stabilize domino in middle of board
« Reply #1 on: January 21, 2013, 08:22 PM »
First I would suggest that you slow down your plunge rate.  The Domino IMO has a learning curve.  I am assuming that you are placing the Domino against something.  If you continue to have issues and the Domino is constantly kicking one way you could of course make some sort og stop block.
Offline Brandon
« Reply #2 on: January 21, 2013, 08:48 PM »
Are you trying to do a field domino with no stationary support for the base?
Offline Brandon
« Reply #3 on: January 21, 2013, 08:55 PM »
I guess I could have finished my thought either way. I'm sure there are numerous ways that people do what I call field dominos. When I use my domino to build cabinet boxes and the dominos aren't on the end of a board I generally use my mft table and the flip down guide rail in conjunction with the flag stop for support for the base of the domino. I index off the bottom of the domino, which takes some getting use to for the proper alignment, I generally using 3/4" material so I'm use to it.
I've also used just the guide rail with different clamps in the same manor, the parallel edge guides with guide rails work well also.
The mft flip down guide rail and flag stop is probably the easiest for consistent repeated field dominos though
« Last Edit: January 21, 2013, 08:57 PM by Brandon »
Offline scr00ge
« Reply #4 on: January 21, 2013, 10:23 PM »
Thanks, luckily I just got MFT too, so I will try that with guide rail.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #5 on: January 21, 2013, 11:10 PM »
As was said use the rail. If you pinch with one hand and plunge with the other it works well.
Don't forget to set the depth of plunge to 12 or 15mm. Remember it is 10mm from the base to the center of the bit. Use the 20 height setting when mortising your shelf, set set of plunge as needed.
Offline SRSemenza
« Reply #6 on: January 21, 2013, 11:51 PM »
Take the support bracket off, that works best to help stabilize at the end of a board.  As has been shown with the guide rail, pretty much any good straight edge firmly clamped in place will do. If you slide the fence all the way to the top, you will be able to get a better hold on the handle to press down and against the fence very solidly.
I like to clamp a solid square across the piece and use the measurements to consistently locate the Dominos from piece to piece. I thought I has a pic or a post of it but can't find it now.
The distance from the base of the Domino (the part against the straight edge ) to the center of the mortise is 10mm. Which is oretty close to 3/8" which will pretty nearly center it for 3/4" material. All in all a very handy method.
« Last Edit: January 21, 2013, 11:54 PM by SRSemenza »
Offline sheeschen
« Reply #7 on: January 22, 2013, 01:03 AM »
I needed to do something like that with some 3/4 ply when making a double-wide sysport.  I drew a line down the middle of the base (actually 10mm to the side).  I then laid the middle upright on its side and clamped it to the base along that line.  Then I marked the domino positions and was able to do both the base and middle upright in one go, dominoing down into the base, and sideways into the upright.  One direction was done tight, the other direction loose.
At least I like to think I did it that way.  In reality, I think I assumed laying the domino flat on the base was going to magically bore into the center of the upright, and there was some confusion about how far from the actually center to clamp the upright.  I'm just glad I hadn't cut the shelves first.
      Scott
Offline Sparktrician
« Reply #8 on: January 22, 2013, 07:53 AM »
+1!  Listen to the motor as you plunge.  If there's a dramatically noticeable change in motor speed as you plunge, you're plunging too fast, and THAT can cause the Domino tool to slip right or left.  The advice from others to use the guide rail is right on target.
- Willy -
Offline scr00ge
« Reply #9 on: January 22, 2013, 11:26 PM »
Thanks again everyone, I like the idea of using the bottom of the domino to reference from, will be more consistent.  At least with 3/4 sheet goods.
Offline SRSemenza
« Reply #10 on: January 23, 2013, 12:34 PM »
Here is a little detail on using a square to position the Domino  http://festoolownersgroup.com/festool-how-to/using-a-square-to-position-the-domino/msg238154/
Offline festoolviking
« Reply #11 on: January 23, 2013, 01:40 PM »
Here is a little jig I came up with. It's a piece of plywood with the edge routed to fit the edge of the guide-rail. Two holes with M5 screws, nuts and washers used as a grip when tightening it to the domino.
https://www.dropbox.com/s/cvjl9xyudeqikp6/Photo%202013-01-23%2018%2023%2018.jpg
https://www.dropbox.com/s/4f515nyug8lra1l/Photo%202013-01-23%2018%2023%2002.jpg
https://www.dropbox.com/s/ff1629q3zh13ybl/Photo%202013-01-23%2018%2022%2018.jpg
Festoolviking
Festoolviking
Offline Steven Owen
« Reply #12 on: November 08, 2017, 11:03 PM »
Festoolviking
FV,
You’re definitely thinking out of the box with this solution.  You came up with a great strategy to use the rail.  You’d definitely would have to use a router/router table to make the rabbit for the track.  Most table saw Dado blades don’t cut rabbits as smooth as a router bit will.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline geoffshep
« Reply #13 on: November 09, 2017, 04:24 AM »
Trying to figure out what you are doing - are you trying to fix (say) a horizontal board to a vertical board or something similar?  Like fitting a shelf between 2 vertical cabinet sides?
It took me while to get to grips with this method of joining boards at 90 degrees in the middle of another piece, but I just built a small shelf unit this way and I'm pleased to say all the slots ended up in the right place and it all went together square!
https://youtu.be/2FC_4wQWWtI?t=1m46s
Offline Birdhunter
« Reply #14 on: November 09, 2017, 05:11 AM »
Festooviking... darn smart idea. Now, think up something similar for the Vecturo.
Birdhunter
Offline thedevme
« Reply #15 on: March 13, 2019, 06:55 PM »
@tjbnwi I was wondering if you still have these images. I know its a long shot but I thought I would ask.
Offline tjbnwi
« Reply #16 on: March 13, 2019, 11:25 PM »
Just looked, not on computers I'm currently using.
Offline Jiggy Joiner
« Reply #17 on: March 14, 2019, 06:38 AM »
A jig or clamped straight edge, or guide rail will all eliminate any chance of drift. In those sort of applications, thinking of the Domino as a router will aid any solutions needed.
Offline jobsworth
  • Festool Baby.....
« Reply #18 on: March 14, 2019, 12:32 PM »
These may help. Lots of info
#festoolsedgedomino
Offline thedevme
« Reply #19 on: March 14, 2019, 02:52 PM »
Alright thanks Tom
Offline SRSemenza
« Reply #20 on: March 14, 2019, 04:27 PM »
A couple pictures to go with my old post above.
Offline thedevme
« Reply #21 on: March 15, 2019, 11:01 AM »
(Attachment Link)           (Attachment Link)
This is a great idea but what do you do if the board is wider? @SRSemenza
« Reply #22 on: March 15, 2019, 11:16 AM »
Use layout lines and align the DF 500 to the marks.   [smile]
- Willy -
Offline thedevme
« Reply #23 on: March 15, 2019, 11:21 AM »
How do you keep the domino from moving?  I tried something similar but I got inconsistent results @Sparktrician
« Reply #24 on: March 15, 2019, 11:37 AM »
@thedevme Plunge the DF 500 S-L-O-W-L-Y!!!  Listen to the motor pitch.  If it changes radically and the DF 500 is shifting position while you're plunging, you're plunging too rapidly.   [smile]
- Willy -
Offline thedevme
« Reply #25 on: March 15, 2019, 11:42 AM »
Thanks - I actually just came back in before I read this and tried it plunging slowly does help but maybe because I am new to it - it takes me forever to line it up.  I feel more comfortable with everyones tips now I just have to do it.  Thank you.
Offline RKA
« Reply #26 on: March 15, 2019, 11:45 AM »
You can also brace the side of the fence that wants to scoot away from your clamped straightedge with your thumb and index finger.  It's just a router.  The bit turns in one direction, the body will be forced in the other direction so you can apply a little force to counter that twisting motion.  This can be a problem with smoother surfaces where there isn't enough friction to keep the domino in place.  But most of the time, if you're not plunging too fast it's not an issue.
-Raj
Offline thedevme
« Reply #27 on: March 15, 2019, 11:59 AM »
Thanks, @RKA - For when I do longboards and I need a bunch of them I decided to get/use a straight edge clamp that I found.  This will give me consistent plunges along the same line without needing the opposite board.  This coupled with the story stick I think I should be able to not have to take it apart every time to check.
Offline SRSemenza
« Reply #28 on: March 15, 2019, 04:55 PM »
I have a 26" square as well.  [wink]
If wider I usually use a guide rail with the domino against the back edge.   I haven't done that in a while but I think the TSO rail square might work.
Offline thedevme
« Reply #29 on: March 15, 2019, 07:20 PM »
I decided to use this - https://www.infinitytools.com/2-wide-straight-edge-clamps-3126 I also plan on getting a 100in one for longer boards when I need it but I didn't like how long it takes to clamp a track or whatever so this gives me a straight edge and clamp all in one.  Thanks everyone for the ideas.
