Author Topic: A new and easy solution for jointing on the tablesaw ?  (Read 14906 times)
Offline sebcbien
« on: August 08, 2016, 10:12 AM »
Hello, I had to joint 2m long stock and only had a small jointer.
I searched the web and found the kind of jig to joint on the table saw like this one:
I scratched my head a little more and bought a long aluminium rectangular tube like this one:
It's strong and doesn't bend easily.
I made 3 holes in it and clamped to my CS 70 fence.
Now I have a longer reference fence and I can joint 2m long stock the easy way.
I made some tests and it works very well.
Maybe I miss something because I didn' find this trick anywhere on internet.
any objection on this solution ?
249230-0
Offline sebcbien
Re: A new and easy solution for jointing on the tablesaw ?
« Reply #1 on: August 08, 2016, 10:15 AM »
249232-0
« Reply #2 on: August 08, 2016, 12:01 PM »
That works! The longer the fence the better if you're cutting well behaved wood.
I have a Paralok fence that is about 54" long so it's good enough most times
but when I want a longer fence I just clamp an 8 foot level to the existing fence.
If you're cutting badly behaved wood the long fence will increase binding which could result in kick-back.
In the old days before engineered wood products fences often stopped at the arbor to allow warping wood room to move without binding.
Offline Chris Wong
  • Festool Dealer
  • I make sculptural furniture.
    • Flair Woodworks
« Reply #3 on: August 08, 2016, 12:26 PM »
I can think of a few downsides. If both edges of your board are convex, your method won't work.  Also, the fence must be at least twice as long as the material being cut.  Also, it won't joint the face!
Chris Wong, http://FlairWoodworks.com
The thoughts and ideas expressed here are my own and do not necessarily represent those of http://UltimateTools.ca.  But Dan does say "hello".
Offline blaszcsj
« Reply #4 on: August 08, 2016, 12:54 PM »
In a pinch I use a level as my reference surface that I hold the board against and slide past the fence rail.
If a board is bowed both ways you just need to run it thru both sides. Approximate the first cut, fix the board to the straight edge and do the first edge. It may take two passes, I have done this before with acceptable results. A good blade is also essential for this working well!
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
« Reply #5 on: August 08, 2016, 01:08 PM »
Not if you're willing to make several passes.
With a badly bowed board run the concave side against the fence to make a flat section in the middle of the convex side. Then flip the board over and use that center flat/straight section to guide the board and trim the "ears" of the concave side. A couple more flips/passes and you have a straight board with parallel sides.
With a very long board you can bias the fence toward the infeed side. Sometimes you have to add a shim between the board and the fence to maintain a straight feed-line through the blade.
My jointer has a short bed so I get better results jointing edges with the tablesaw, as long as the stock is thin enough, 3" or less.
Face jointing is another story.
Offline ear3
« Reply #6 on: August 08, 2016, 04:10 PM »
Just curious why one might opt for this method over tracksaw + long rail.
« Reply #7 on: August 08, 2016, 04:23 PM »
Way faster, only one moving part. Especially superior when working with narrow stock.
Offline Chris Wong
  • Festool Dealer
    • Flair Woodworks
« Reply #8 on: August 08, 2016, 04:50 PM »
Very resourceful!
Offline sebcbien
« Reply #9 on: August 08, 2016, 07:23 PM »
Yes, this is also a great advantage with this method, one tool, one guide and you have a jointed AND parallel board.
I've jointed 180cm stock quite easily.
I noticed with such lenght that the guide is still a little "soft".
To have a perfect result, it's better to not put too much pressure on it.
Maybe I will try to find harder/thicker/wider aluminium or bind two together.
Thank you all for your comments.
Offline Gregor
« Reply #10 on: August 09, 2016, 04:05 AM »
Try it turned 90°, having the profile flat instead of upright should give it a little more resistance against sideways bending.
Offline sebcbien
« Reply #11 on: August 09, 2016, 05:17 AM »
Thanks Gregor, you are absolutely right, I should had mentioned this.
I was lazy and just posted "old" pictures left in my smartphone (February 2016...).
Rotated by 90°, it's of course better but still not "perfect" and the clamping is more difficult.
Looks like there is a lot of different aluminium, and clearly the one of the tube I've used is not as hard as the one of the festool fence.
I will place some calls today to see if there is different alloys availaible for those tubes
« Last Edit: August 09, 2016, 05:39 AM by sebcbien »
Offline pixelated
« Reply #12 on: August 09, 2016, 08:50 AM »
To joint a board on a table saw, you need a flat reference edge to run against the fence. This is why the pictured jig is clamped to the board which will be jointed. Extending the fence by clamping a long straight edge to it doesn't do the same thing. Using several passes with light cuts will work, but the jig can do it on one pass (plus one more cut on the other side without the jig to make the board edges parallel).
« Reply #13 on: August 09, 2016, 10:45 AM »
The jig is good, as is the long fence and tracksaw. It's great to have options. One will better fit the situation.
Offline sebcbien
« Reply #14 on: August 09, 2016, 10:47 AM »
You are true if the stock is longer than the fence (before and after the blade)
But not if the stock is shorter than the fence (that's why mine is very long).
In this case, the stock will have two points of contact to the fence before hitting the blade.
As those two points of contact will stay during all the cut (because the fence is long enough) the cut will be straight in one pass.
Only problem is when the stock has two concave sides, in this case, multiple passes is mandatory.
« Last Edit: August 09, 2016, 03:34 PM by sebcbien »
Offline sebcbien
« Reply #15 on: August 09, 2016, 03:33 PM »
I made a small drawing to illustrate:
It's better also to rotate horizontally, to keep the same face as "reference" (it the stock top and botom faces are not parallel)
Offline fritter63
« Reply #16 on: September 14, 2016, 11:05 PM »
(Attachment Link)
As they say in (Ecclesiastes?), "There is nothing new under the sun".
I used to have a jig like this years ago (it didn't make the "cut" when we moved 1000 miles). But I think I got the idea from Fine Woodworking. I've got a similar smaller type sled that rides in the miter slot, that I've been using to joint guitar fretboards for years (it just became obsolete with the addition of the CNC to my shop).
Offline sebcbien
« Reply #17 on: September 15, 2016, 05:58 PM »
no jig and no mitter slot here, just a long fence...  [wink]
« Reply #18 on: September 15, 2016, 07:46 PM »
The simplest and still the best solution.
Offline sebcbien
« Reply #19 on: January 11, 2017, 05:44 PM »
Hello,
I just made a video explaining this technique:
I should be displayed with English text and I translated the video in English subtitles (but I speak French in this video)
Thanks for watching  [smile]
« Last Edit: January 11, 2017, 05:55 PM by sebcbien »
Offline JimD
« Reply #20 on: January 14, 2017, 09:32 AM »
I'm also in the long fence camp.  Mine has t-slots which make attachment easy.  It used to be my way of getting boards ready for glue-up.  These days I use my track saw.  For anything within it's 8' capability, I would do that.
