Pages: 1 [2]  All   Go Down
  Print
Author Topic: ATF55 homemade right-side splinterguard  (Read 9614 times)
Forrest Anderson
Offline Offline
« Reply #30 on: September 06, 2008, 07:14 AM »
No modification was made to the saw except to replace the two panhead 4mm bolts at the bottom of the bladeguard by two roundhead and slightly longer 4mm bolts. These two bolts hold the 1" aluminium square channel through two vertical slots in the inside wall of the channel.
On my TS-55, these screws are not 4mm .  They are 4mm thick, but the screw pitch is extremely coarse.  I can not find any screws with the same thread-pitch.  Does anybody know where to find these screws?
Note that the saw being discussed in this thread is the older ATF55, not the TS55 which is currently being sold. The 4mm screws on the AFT55 that lat owns are described in the parts catalogue as "Flat head screw M 4 x 10" with Order No 228736, and are not used on your TS55. The catalogue describes the equivalent screws on the TS55 as "Screw DG 40 x 15", Order No 400710.
"M4 x 10" is a standard way of describing a metric-threaded screw which is 4mm diameter and 10mm long. Anyone know what the "DG 40" designation means for the TS55 screw?
Forrest
Compiler of the Consolidated List of Festool Links - the place to go for Festool reviews, manuals, brochures and videos!
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #31 on: October 08, 2008, 12:47 AM »
Lou,
I do not know of a source, but silicone rubber might work in your intended application.  They make windshield wiper blades and those "California" blades for sweeping most of the water off a car after washing it of silicone rubber.
Dave R.
lat
Offline Offline
« Reply #32 on: October 10, 2008, 11:19 PM »
Dave, thanks for the suggestion. I will try it on my next laminate project. As far as working with wood I am quite happy with the conversion, it does the job and is not in the way.
Lou
Lou
Pages: 1 [2]  All   Go Up
  Print
Jump to:
