Author Topic: Another CMS micro adjuster . . .  (Read 2609 times)
Offline wimblejon
« on: June 08, 2018, 03:18 PM »
I thought I’d share my latest attempt with you FOG folks.
Having purchased a TS-55 and the CMS workbench a couple of years ago, it quickly became apparent that the precision I was expecting wasn’t built in to the design.
Initially, my idea was to use an amended MFT/3-ZK:
280578-0
. . . which was going to use a 1mm pitch screw to move the rip fence left and right along the front V-groove. I soon realised that using the fence fixed to the front was not good, as there is too much sideways movement and cuts were not true.
On second thoughts, using the fence on the right or left hand V-groove prove much better as there is now no lateral movement - but that needed a different approach to a micro adjustment solution.
So I came up with this:
280580-1
It uses an M8 x 1mm pitch screw fixed laterally at the end of the sliding bar and a machined aluminium block fixed to the fence holding end. That has a spring loaded button that engages with the 1mm pitch screw and moves the fence very precisely 1mm with one turn of the end knob. I just have to remember to loosen the clamp screw before adjusting and tighten it afterwards.
It works, perfectly and I'm frankly astonished at the accuracy!
280582-2
As a (semi) permanent addition, however, it does restrict the full rotation of the protractor end, to the left, which may be needed for some other kind of cuts, but then I have bought a second fence and can use that one if necessary.
I did make it all by hand except for the release button, which my son helped me with by turning it accurately on his lathe.
280584-3
280586-4
Very happy to provide details/plans for the parts if anyone is interested.  [smile]
280588-5
« Last Edit: June 08, 2018, 03:21 PM by wimblejon »
Offline neilc
Re: Another CMS micro adjuster . . .
« Reply #1 on: June 08, 2018, 06:38 PM »
Very cool idea!  And simple!
Can you share more details / plans?
Thanks for sharing!
Offline wimblejon
« Reply #2 on: June 08, 2018, 06:45 PM »
Neilc,
I have the following drawings from Fusion360 and an overall plan in .pdf format. . .
Offline PreferrablyWood
« Reply #3 on: June 09, 2018, 12:11 PM »
This could be a very useful addition to my CMS setup. Thanks alot for sharing.
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline neilc
« Reply #4 on: June 09, 2018, 09:35 PM »
wimblejon - thanks for the PDF's - can you share a link to your Fusion file?  In the data panel you can right click and say 'share' and copy a shareable link.  Be sure to include 'allow download' as I'd like to explore further starting with your design
McMaster here in the states has a quick-adjust nut that you can use on a variety of threads that might work well with your concept for fast adjustment.
Thanks!
Offline wimblejon
« Reply #5 on: June 10, 2018, 04:25 PM »
Hi Neil,
Happy to share the fusion file here: https://a360.co/2l2kLfe
I had a look at the quick-adjust nut from McMaster and am very interested to see where you could take this using one of those.
Keep us posted?
Jon
Offline neilc
« Reply #6 on: June 10, 2018, 05:13 PM »
Thanks -
I'll experiment and report back!
