Pages: [1]   Go Down
  Print
Author Topic: Bessey clamps and MFT?  (Read 4768 times)
arso_bg
Offline Offline
« on: March 05, 2010, 01:38 AM »
Hi everybody!
Does someone know if these Bessey clamps can be used with the Festool MFT ?
Can they fit into the holes?
http://www.woodpeck.com/besseyminiclamp.html
Thanks !
Memphis Larry
Offline Offline
WWW
« Reply #1 on: March 05, 2010, 09:10 AM »
I don't know if it is the same item, but I bought some clamps at Lowes that looked like that one to see if it would work on the MFT.  They were listed as welding clamps.  The welding clamps from Lowes would have worked except the flattened part at the bent end of the clamp was too wide to fit through the hole w/o grinding it off.  I took them back and ordered some more Festool clamps instead.   Sad
Domino, RO 150 FEQ, TS 75 EQ, MFT/3, LS 130 EQ, CT 33 E, OF 1400, Kapex KS 120 EB, MFK 700 EQ SET, Parallel Guide Set, CT Midi, Rotex RO 90 DX, Qwas Dogs & Qwas Rail Dogs, ETS 150/3, Granat Hand Sanding T-Loc Assortment, LR 32 Sys...
JimRay
Offline Offline
« Reply #2 on: March 05, 2010, 10:21 AM »
I'm pretty sure that the Bessey's won't work. If you look at the top end you'll see that the cross section is a lot taller that what the Festool clamps have. I think that this will interfere with them sliding into the guide rails. I have not tried the Bessey's though. On the other hand, those are nice clamps, and at the worst, if you get them and they are not compatible, you'll have more clamps!
Jim Ray
Jim Ray
Qwas
Retailer
Offline Offline
WWW
« Reply #3 on: March 05, 2010, 04:39 PM »
I have 2 of the 8 inch model of this clamp. It will not fit most of the holes due to the design. The  8 inch model will fit the outside 2 rows of holes since you can lower the clamp farther to get past that S hook on the bottom of the clamp. The 12 inch model might get to the third row of holes also.
Steve Adams  QwasProducts.com
justinh
Offline Offline
« Reply #4 on: March 07, 2010, 03:42 PM »
i slotted the holes on my mft and mft style work bench to accomodate the Kreg bench clamp's bottom bolt.  the round holes now resemble a key hole.  the ridge on the bessey clamps slide right through the slot.  i prefer the bessey clamps to the festool as the tend not to slip.
justin
arso_bg
Offline Offline
« Reply #5 on: March 08, 2010, 01:04 AM »
Thank you Justin!
This is very interesting. Could you post some pictures of the "key holes" so that we can better understand how you use the Kreg bench clamp on the Festool MFT ?
Is the MDF table top strong enough according to your experience to withstand the enormous forces without any damages when you use the Kreg clamp?
« Last Edit: March 08, 2010, 01:09 AM by arso_bg » Logged
justinh
Offline Offline
« Reply #6 on: March 09, 2010, 08:49 PM »
i don't have any pictures but it looks like the slot and hole in either of the Kreg clamping plates.  the mdf handles the pressure fine.
woodwreck
Offline Offline
« Reply #7 on: March 19, 2010, 04:09 PM »
NO  I got tired of the guessing so I went and bought one locally as you show. Model "MM" $25. The throat of the clamp is too short, so that it only fits the outer row of holes on the table in order to swing upright. It is about 1/2 shallower than the Festool clamp.
Now I will go return it.    Beating a dead horse
Regards,
Woodwreck
arso_bg
Offline Offline
« Reply #8 on: March 19, 2010, 05:54 PM »
Thank you for your efforts and the info Woodwreck
It's a pity that they don't fit ...
Regards
« Last Edit: March 19, 2010, 05:55 PM by arso_bg » Logged
worknfool
Offline Offline
If you can't use a hammer, it must be electrical.
« Reply #9 on: May 22, 2010, 04:00 PM »
Just bought a handful $10 a piece for the 12", and they fit. The tail piece has to be slid to the very end of the beam to allow the head to be manipulated into the hole.
Maybe it's time to start building Gibbets in front our rulers' castles? Perhaps they'd get the hint.
vkumar
Offline Offline
Sunnyvale (near San Jose) California
« Reply #10 on: May 22, 2010, 04:29 PM »
Can you please post which specific make and model fits and where did you get it?
Thanks.
Vijay
worknfool
Offline Offline
« Reply #11 on: May 22, 2010, 08:12 PM »
Sorry I didn't respond earlier, actually I'm sorry I opened my big mouth at all. Went back to check and the 12" only works within the first two rows of holes. Mid-table is still out of reach. The supplier was Skarie in Baltimore. Don't know if the ship but their number is (410) 728-6000.
Pages: [1]   Go Up
  Print
Jump to:
