Author Topic: CAD Programme for Multifunction slab  (Read 14215 times)
Offline carlb40
  • Site carpenter
Re: CAD Programme for Multifunction slab
« Reply #30 on: June 07, 2015, 01:42 AM »
I really need to find someone local to mill a couple of tops for me. That or buy a CNC for myself [embarassed]
This might interest you then.  [big grin]
Sorry if it's already been posted elsewhere on here.  [embarassed]
Carl
Never never go, never never know [smile]
Flickr
Offline Craig B
« Reply #31 on: September 27, 2015, 09:42 AM »
just incase some one is interested?
Interested in the MF Slab, if you're still producing them. Did you say you are pretty local to Manchester?
Offline Kristian123
« Reply #32 on: June 08, 2017, 02:28 AM »
Anyone knows meanwhile which format this file has?
Best
Kristian
Offline Kristian123
« Reply #33 on: June 08, 2017, 01:30 PM »
Ok. I wrote them. They replied quickly and sent me .dxf :-)
Best
Offline jmbfestool
« Reply #34 on: June 24, 2017, 08:01 AM »
@jmbfestool
Thanks for the 2nd video.  [thumbs up]
Didn't realize that an automatic tool changer can be optioned for a CNC router. Makes complete sense, I've just never seen one in action.
Also like that your'e using ply rather than MDF.
Long time ago!   I dont know how I missed all these posts!
Yeah a tool changer was always a must for me when I bought my CNC.  You can get them without one but the program stops and waits for you to change tool.    Nah lol
@Cheese
« Last Edit: June 24, 2017, 08:12 AM by jmbfestool »
*********************************************************************** [thumbs up]UK members click me
Offline jmbfestool
« Reply #35 on: June 24, 2017, 08:03 AM »
It fly's through those 20mm holes I bet it don't take long to do the whole top
Yeah it does and that does not even max feed rate it will cut quicker.   Although because its size and weight its ramp speed isnt very quick so unless it has a longer cut it wont reach full feed speeds
@joiner1970
Offline jmbfestool
« Reply #36 on: June 24, 2017, 08:07 AM »
@jmbfestool
What bit are you using to cut & speed setting on that multiply sheet?
We use Onsrud & Amana bits.
We have a multicam 3000 5x10 here and were thinking of cuttin that stuff.
You a vacuum table also?
Fill me in please.
Sorry I never replied! I only just seen all these.
I know wont be much help now like.
I use onsrud cutters.
     Feed rate from 6000 - 15000 mm/min   Most the time 10000 mm/min
and RPM 18000-2200
Seems to give me longest cutting life on birch plywood with slight cutting marks on the edge.
@Picktool
« Last Edit: June 24, 2017, 08:13 AM by jmbfestool »
Offline jmbfestool
« Reply #37 on: June 24, 2017, 08:09 AM »
Sorry like I already mentioned only just seen these posts.
If you want one I don't mind making one when I'm working in workshop
Offline Picktool
« Reply #38 on: June 24, 2017, 03:12 PM »
@jmbfestool  Which Onsrud cutter... (#### ? )  :o
Compression?
Thanks!
and RPM 18000-2200
@Picktool
Well Dogey
Offline jmbfestool
« Reply #39 on: June 27, 2017, 05:20 PM »
Compression?
Thanks!
and RPM 18000-2200
@Picktool
Oh sorry yes compression cutter 9.45mm.
Then a few different size downwards cutters for grooves/slotes etc.
@Picktool
