Tom Hummel
Offline
« on: October 08, 2007, 09:33 PM » |
I love my Festool cordless drills and I really appreciate the engineering of the unique Festool chucks. Like others I use square drive Robertson screws along with all the various other types. I have grown to appreciate the accuracy and the speed of the Centrotec chuck. It is so much better than all the other quick change chucks/adapters out there. So this square drive Centrotec void has kept me searching for a better way.
I always assumed that standard 1/4" bits are a little too big to fit in the Centrotec chuck. Not so... the Festool bits simply have the corners knocked off, the flats are the same size as any standard bit. I believe this was posted in an email on the old Festool Yahoo site by Jerry. Aside from that the only significant difference is that the detent is in a different location to allow the shaft of the bit to go all the way inside of the drill.
Experimenting with a 6" squared drive bit and the grinding wheel I was able to produce a crude working version that slipped right into the Centrotec chuck. Once I knew it would work I created the following bits with my Mill/drill. The metal lathe is the perfect tool for this, however I was able to produce nice working versions on my mill with a ball endmill and a straight endmill with my rotary table.
One added benefit with these bits is that the factory detent does not seem to be a problem and as a result my homemade bits fit the offset chuck as well.
« Last Edit: October 08, 2007, 11:08 PM by Tom Hummel »
Dan Clermont
Festool Dealer
Offline
Location: Vancouver / Burnaby, British Columbia, Canada Member Since: Jan 2007
Canadian Festool Dealer
« Reply #1 on: October 08, 2007, 10:28 PM » |
Nice Job!!!
I'll take 4!!! of each Robertson size
Do you ship to Canada?
Dan Clermont
Canadian Festool Dealer and User!!! 778-558-7745
Mirko
Offline
Location: Vancouver, British Columbia Member Since: Jan 2007
« Reply #2 on: October 09, 2007, 12:33 AM » |
Nice job Tom, or shall we call you "Mr Robertson"  I have thought about this before but never got around to trying it, glad to see it works! Your version is also stronger than the Festool bits because they lack the small green "O" ring (besides looking nice what is its purpose??) this dam thing is a fracture point, you will find this out very quickly when you drop your drill! they break like glass, o ring marks the spot. Great work! Mirko
Corwin
Offline
« Reply #3 on: October 09, 2007, 01:27 AM » |
Honey hush! That is one slick bit. I'll take several also.
Shirt Size: L
Tom Hummel
Offline
« Reply #4 on: October 09, 2007, 08:51 AM » |
Nice Job!!!
Dan Clermont
Dan, Sorry I am not set up to make these for others, I'll be happy to provide detailed instructions. I don't think the bits that I made with the Mill/drill work any better than the ones I made with the grinder, they just look better. Nice job Tom, or shall we call you "Mr Robertson"  I have thought about this before but never got around to trying it, glad to see it works! Your version is also stronger than the Festool bits because they lack the small green "O" ring (besides looking nice what is its purpose??) this dam thing is a fracture point, you will find this out very quickly when you drop your drill! they break like glass, o ring marks the spot. Great work! Mirko Thanks Mirko I believe the green O ring keeps the Festool bit from going in too far, this is only an issue if the Centrotec chuck is off the drill. On my bit the milling stops where the O ring would normally start. I have modified several brands of bits, I picked up the bit in the photo at McMaster Carr. My favorite bit is the Senco #2, they are sold locally in a 2 pack that can be seen here: http://www.nailgundepot.com/shop/files/images/product_thumbnail/d_1224.jpg
Tom Ryan
Offline
Location: State College, PA (moving soon to Wallingford, PA) Member Since: Mar 2007
« Reply #5 on: October 09, 2007, 11:22 AM » |
Would the following work (for someone that doesn't have milling equipment)?
Put the drill in a vice (or otherwise hold it secure), with a non-Centrotec chuck. Put in the bit to be modified. Turn on the drill. Hold a small round file against the bit where you want the new detent. Are drill bits soft enough to file? Is the spacing between detent large enough to provide enough clearance?
Tom (who almost exclusively uses square drive screws).
Tom Hummel
Offline
« Reply #6 on: October 09, 2007, 12:18 PM » |
Tom, That could possibly work depends on the hardness of the bit and the hardness of the file, the best way to find out is to try it. The detent does not have to be absolutely perfect so you could just put it in a vice and file your way around. You would need to use a flat file to take part of the points off. I don't understand your question "is the spacing large enought to provide enough clearence?"
Jim Becker
Offline
Think twice...write once...
« Reply #7 on: October 09, 2007, 08:04 PM » |
I had the pleasure of trying out Tom's bits tonight and they are awesome. They run absolutely true and eliminate the runout that I've been living with using the BH-65 to hold "commonly available" square drive bits.
As a note to Festool...I really can no longer accept that Robertson/square drive bits cannot be had in acceptable quality to have in the Festool line when Tom presents a clear example of what one guy can do in his home shop using a relatively common type of mill/drill to machine the corners and the correct detent location. (and this after a test run with a grinder) I brought this up several years ago when I first bought my Festool drill/driver with all the bells and whistles. North America is more in love with square drive fasteners every day...it would be nice for folks investing in what is arguably the best portable tool system to have that option "natively".
« Last Edit: October 09, 2007, 08:06 PM by Jim Becker »
“Never raise your hands to your children, it leaves your groin unprotected.†- Red Buttons
Dan Clermont
Festool Dealer
Offline
« Reply #8 on: October 09, 2007, 09:07 PM » |
Not to jump on the bandwagon here but in Canada we use Robertson head screws almost exclusively EH!!! I have one stored in my toque all the time.  I'd really like to see Festool make the effort to produce Robertson bits. Thanks for Listening Dan Clermont
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #9 on: October 09, 2007, 09:31 PM » |
Tom, That could possibly work depends on the hardness of the bit and the hardness of the file, the best way to find out is to try it. The detent does not have to be absolutely perfect so you could just put it in a vice and file your way around. You would need to use a flat file to take part of the points off. I don't understand your question "is the spacing large enought to provide enough clearence?" Files are generally very hard, and probably harder than the driver bit shank. If the steel of the driver bit is too hard to to file, grind the needed detent profile om the shank of the driver bit. Grinding is standard machine shop practice for shaping materials that are too hard for use of cutting tools. The rim of a narrow vitrified grinding wheel or fiber-reinforced cut-off disk could be dressed to a rounded profile approximating shape to be ground into the hexagonal shank of the driver bit you are modifying. Drill bits are likely to require grinding to shape; they have to be hard to do their intended job at cutting metals that are softer than the bit. Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
Richka
Offline
« Reply #10 on: October 09, 2007, 10:58 PM » |
I did the same thing a while back. I used a metal lathe with carbide insert tooling. The driver bits turn fine with carbide. I turned 1/4" hex which is approximately 7.15 mm to 7.0 mm and added the detent location. Modifying standard tooling (read cheap) appeals to my Yankee sense of thrift... (repost: Photo didn't go the first time)
