Julian Tracy
Offline
« on: March 29, 2011, 02:18 PM » |
http://www.tooldepot247.com/proddetail.asp?prod=921086AA13* Much shallower depth than the Festool and half the price. Most Fein accessories I've seen are upto and sometimes exceed the quality of Festool stuff. Might be a better bet than the Festool version - I like that it doesn't stick out as far. JT
Brice Burrell
Offline
Remodeling Contractor
« Reply #1 on: March 29, 2011, 02:25 PM » |
Nice. You got a bad link.
Jeff Hein
Offline
« Reply #2 on: March 29, 2011, 02:50 PM » |
leakyroof
Offline
« Reply #4 on: March 29, 2011, 03:26 PM » |
Don't forget that good DC doesn't like sharp turns and small radius fittings. Haven't looked at the inside of the Festool Y fitting, but it may be stick out from the vacuum farther for a good reason.
harry_mc
Offline
Location: North Richland Hills, TX, USA Member Since: Nov 2008
« Reply #5 on: March 29, 2011, 04:58 PM » |
Is the Fein adapter anti-static?
Brice Burrell
Offline
« Reply #6 on: March 29, 2011, 05:26 PM » |
I'd guess no.
MarkF
Offline
Concord, NC
« Reply #7 on: March 29, 2011, 06:05 PM » |
I'm not trying to be a smart a@# ...but why would that matter? It's located at the end of the hose. I use a Fein Turbo II with a stock gray PVC hose and have this Y adapter attached with no static issues. Is this a Festool issue?
PeterK
Offline
« Reply #8 on: March 29, 2011, 06:22 PM » |
I guess it depends upon where you live. Here in Louisiana, I have used my CT22 with both regular and anti-static hoses and fittings and have never been shocked or had any type of issue. Maybe in arid Arizona or some such place it is a major problem.
Brice Burrell
Offline
« Reply #9 on: March 29, 2011, 08:19 PM » |
I'm not trying to be a smart a@# ...but why would that matter? It's located at the end of the hose. I use a Fein Turbo II with a stock gray PVC hose and have this Y adapter attached with no static issues. Is this a Festool issue? As Peter said you might have a problem in you lived in desert or, if are like me and cut a lot PVC (Azek) the anti-static feature makes a big difference.
mishle
Offline
« Reply #10 on: March 29, 2011, 11:14 PM » |
Living in Colorado when I tried using a non-anti-static hose it felt like holding on to an electric fence for cattle.
harry_mc
Offline
« Reply #11 on: March 29, 2011, 11:32 PM » |
I'm not trying to be a smart a@# ...but why would that matter? It's located at the end of the hose. I use a Fein Turbo II with a stock gray PVC hose and have this Y adapter attached with no static issues. Is this a Festool issue? Even here in Texas in the winter it gets dry enough in most buildings that static can become an issue (probably not an issue outside). I've only used the adapter at the beginning of the hose (right out of the extractor), not the end. If you aren't using an anti-static hose it won't make a difference. I only asked because if static is an important issue to someone, they should know that comparing the two adapters is an apples to oranges comparison. -Harry
MarkF
Offline
Concord, NC
« Reply #12 on: March 30, 2011, 10:00 AM » |
You guys are missing my question. I'll rephrase it: Would having a regular (ie:not anti-static) "Y" adapter significatly impact the performance of an anti-static hose? Apologies for the confusion!
I've always wondered why Festool offers a solution and nothing antistatic is offered from Fein. They are similar machines so you would think static is just as big an issue with Fein. It probably is and I'm just "blessed" (not) with humidity.
SRSemenza
Global Moderator
Offline
« Reply #13 on: March 30, 2011, 10:25 AM » |
Yes, the non-antistatic adapter will in effect make the hose non-antistatic. Because it breaks the connection to the grounded vac. When the connection is continuously antistatic , any static charge being produced by the flow goes all the way to ground through the vac. However, using a short jumper wire from the hose over the non-antistatic Y to the vac hose inlet will complete the connection and take care of the problem. Here is a pic of one that I did for my mounted , homemade boom arm. As you said , humid enviroments cause much less static. I have a good mix of dry and humid air over the course of the year. With out the antistatic I got zapped regularly by the hose. Why Fein doesn't do the antistatic thing is anybodys guess? Seth
« Last Edit: March 30, 2011, 10:29 AM by SRSemenza »
Festool Service 800-554-8741
MarkF
Offline
Concord, NC
« Reply #14 on: March 30, 2011, 11:18 AM » |
Thanks Seth!
Julian Tracy
Offline
« Reply #15 on: March 30, 2011, 11:26 AM » |
In ten years of using my Fein Vac, I never once got zapped. I'm in MI though, but it gets dry around here at times.
JT
mishle
Offline
« Reply #16 on: March 30, 2011, 09:28 PM » |
Festool is the first vac that I actually need anti static with. I have run Shop vac, Ridgid, and craftsman with out static shock, just sawdust buildup.
I do like the cleaner hoses with anti-static:)
