Author Topic: Circle Jig for 1400 router  (Read 4452 times)
Offline JCLP
« on: December 15, 2016, 12:54 PM »
Hello everyone. Below are some photos of my $12.00 circle jig. Firstly, I would like to thank Jim Kirkpatrick, also a Fogger, for the idea. I bought 2 steel rods size 5/16" x 36" at home depot. I then used the knob from the edge guide as the pivot point. Fits perfectly with a few washers to alter the distance it sticks out underneath. Now I can cut 4' circles for my project.
Thought I would share.
JC
Offline JCLP
Re: Circle Jig for 1400 router
« Reply #1 on: December 15, 2016, 02:11 PM »
Just tried a 20" circle on MDF and it worked like a charm. Now I'm going to try a 4' circle on 1" thick ply. ( 2 - 1/2" sheets at the same time ). Photos to follow.
Cheers,
JC
Offline JCLP
« Reply #2 on: December 15, 2016, 03:14 PM »
Here are photos of cutting out a 4' circle. It turned out perfect. Sorry photos are a little out of focus. Iphone's fault.
Cheers,
JC
Offline gunnyr
    • https://www.instagram.com/compassfinecarpentry/
« Reply #3 on: December 15, 2016, 09:24 PM »
Nice solution!  Thanks for posting.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|PRO 5 LTD|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
Offline Chris Wong
  • Festool Dealer
  • I make sculptural furniture.
    • Flair Woodworks
« Reply #4 on: December 15, 2016, 09:35 PM »
Nice  setup. Thanks for sharing.
Chris Wong, http://FlairWoodworks.com
The thoughts and ideas expressed here are my own and do not necessarily represent those of http://UltimateTools.ca.  But Dan does say "hello".
Offline jtwood
« Reply #5 on: December 15, 2016, 11:35 PM »
A great post.  Solved a problem for me.
Thanks,
Steve
Offline JCLP
« Reply #6 on: December 16, 2016, 12:59 PM »
So I needed to remove 1/8" from the top of my work piece so I would have a 13" wide circle depression for a lazy susan bearing. Thought about going out and buying the extended base but then a light bulb went off in my head. Why not try the new rods I bought in conjunction with the stabilizer on the router base. Worked like a charm. Now I have an adjustable base for my router. It's amazing how far you can stretch $12.00.
Cheers,
JC
Offline Jim Kirkpatrick
    • Jim Kirkpatrick Woodworking
« Reply #7 on: December 16, 2016, 05:22 PM »
Great work JC!   [thumbs up]
