Author Topic: Festool Clamps compatible with T Track brands  (Read 117716 times)
Offline SRSemenza
« on: August 28, 2007, 10:23 AM »
        I just discovered that the Quick Clamp fits in my T Track. The screw type clamps would not.   8)
srs
An additional list provided by Chrisprols.
Note - newer screw type clamps have the same profile as  the Quick clamps.
Quick Clamp -ok- incra T Track
screw Clamp -nok- incra T Track
Quick Clamp -ok- woodpecker track (requires sanding)
screw Clamp -ok- woodpecker track (requires sanding)
Quick Clamp -nok- Lee Valley 1/4 Track
Screw Clamp -nok- Lee Valley 1/4 Track
Quick Clamp -ok- Lee Valley 5/16 track(Item 12K7932)
screw Clamp -ok- Lee Valley 5/16 track(Item 12K7932)
Quick Clamp -ok-  40 series of 8020 Inc. extrusions
screw Clamp -ok-  40 series of 8020 Inc. extrusions
Quick Clamp -nok- Rockler T Track
screw Clamp -nok- Rockler T Track
Quick Clamp -ok- the base of the Incra LS Positioner
screw Clamp -ok- the base of the Incra LS Positioner
Quick Clamp -ok- 15 series extrusions from 80/20
screw Clamp -ok- 15 series extrusions from 80/20
Quick Clamp -nok- Kreg regular track
screw Clamp -nok- Kreg regular track
Quick Clamp -nok- Kreg Top Trak
screw Clamp -nok- Kreg Top Trak
Quick Clamp -ok- veritas 5/16 (sloppy)
screw Clamp -ok- veritas 5/16 (sloppy)
Quick Clamp -ok- Orange Aluminum" track
screw Clamp -ok- Orange Aluminum" track
Quick Clamp -ok- Dakota 1/2" T Track
« Last Edit: February 27, 2016, 06:23 PM by SRSemenza »
Offline Dave Ronyak
  • Flyin' from NE Ohio
Re: Clamp T Track
« Reply #1 on: August 28, 2007, 12:27 PM »
Seth,
What is the brand of your T-track?
Dave R.
Offline SRSemenza
Re: Clamp T Track
« Reply #2 on: August 28, 2007, 08:12 PM »
Seth,
Dave R.
        The T track in the pictures is Incra.  I just went to the shop to try a couple others.
               Fits the Incra with flat head or pan head screws holding the track down.
               Fits the Incra scale track with flat or pan head.
               Fits Woodpeckers track with flat head.
               Does not fit Kreg track at all.
Offline Dave Ronyak
Re: Clamp T Track
« Reply #3 on: August 30, 2007, 02:01 PM »
Thanks, Seth.  You saved me from buying incompatible track!
Dave R.
Offline SRSemenza
Re: Clamp T Track
« Reply #4 on: May 07, 2008, 10:54 AM »
   The question of compatible T track has come up several times since I first started this thread.   If anyone has the Festool Quick Clamp and other brands of T Track than have already been posted here, please give it a test and add the results to this thread.   Also note that the type of screw head can sometimes make a difference.
Offline SRSemenza
Re: Clamp T Track
« Reply #5 on: June 08, 2008, 11:46 PM »
   I have been told that the clamps will not fit into Lee Valley Track either.
Offline wooden
Re: Clamp T Track
« Reply #6 on: June 09, 2008, 12:07 AM »
There are 2 common sizes of t-track available and often used in woodworking - 1/4 and 5/16.  This might be the problem?
Of course, there are lots and lots of different size t-tracks....but 1/4 and 5/16 is most often seen in woodworking stores.
If you look at Lee Valley, they sell both sizes of track and hardware that is appropriate for one or the other:
http://www.leevalley.com/hardware/page.aspx?c=2&p=52399&cat=3,43576,52799
Offline Qwas
    • Qwas Products
Re: Clamp T Track
« Reply #7 on: July 08, 2008, 11:48 PM »
The clamps work in the 40 series of 8020 Inc. extrusions.
I have some and tried it. The screw and quick clamps both work in the track.
Offline Qwas
    • Qwas Products
Re: Clamp T Track
« Reply #8 on: July 08, 2008, 11:51 PM »
The problem is the depth of the 5/16 inch track. Some tracks are not deep enough to allow the clamps to fit in the slot.
Any 1/4 inch track will not work, not wide enough to begin wth.
Offline SRSemenza
Re: Clamp T Track
« Reply #9 on: July 09, 2008, 01:48 AM »
      Hmmm,   The tracks that I have found they fit are all termed 1/4" T Track. Not for the actual measured size of the track, but because the heads of 1/4" bolts will fit in them.   The trouble is that the extrusians are of differing brands have enough differences to make some work and some not.  Which is why I started compiling this list.
Offline KorDes
  • Festool Dealer
    • robertsonandsinclair
Re: Clamp T Track
« Reply #10 on: July 09, 2008, 07:06 AM »
Tried the clamps on the t-tracks from Rockler and they dont fit.  :(
Offline SRSemenza
Re: Clamp T Track
« Reply #11 on: July 09, 2008, 10:15 AM »
     Thanks for the info. Did you try both types (Quick and screw)?  They have different profiles themselves.
Offline Fridolin
Re: Clamp T Track
« Reply #12 on: May 07, 2012, 03:49 AM »
In spite it is not quite on topic:
The Festool clamps fit to the base of the Incra LS Positioner.
You can clamp it securely to the edge of any table and use the Positioner.
« Last Edit: May 07, 2012, 03:51 AM by Fridolin »
Offline Brian.ca
Re: Festool Clamps compatible with T Track brands
« Reply #13 on: May 07, 2012, 07:34 PM »
They (screw & quick clamps) also work in the 15 series extrusions from 80/20
Offline Acrobat
Re: Clamp T Track
« Reply #14 on: May 10, 2012, 07:43 AM »
Do you have any other brands of track? What about Kreg?
Don't wake me, I'm livin' the dream!
Offline SRSemenza
« Reply #15 on: May 10, 2012, 05:40 PM »
The Festool clamps will not fit the Kreg track.
Offline Richard/RMW
« Reply #16 on: May 10, 2012, 06:21 PM »
They will fit all the Woodpecker tracks however it requires grinding/sanding a hair off the side of each clamp, the leg that slides into the track. The amount was minor, I just touched it to my disk sander for < 1 second.
50966-0
RMW
Offline Burchie
    • Change Design Group
« Reply #17 on: May 15, 2012, 04:40 PM »
RMW:   Regarding your picture, what do you primarily use the two woodpeckers T tracks with the sliding bar setup for?
Offline Richard/RMW
« Reply #18 on: May 16, 2012, 08:28 AM »
I'll take a gues!   Routering dados?
Yup - Dadoes but also other grooves/rabbets and cuts like the slots in the aluminum bars shown in the photo.
I can adjust the width between the t-tracks and then use various router guides and bits. Example would be using the Festool 40MM guide ring with a 8mm straight bit, if I widen the spacing between the tracks to 50MM the cut becomes 18mm (8mm bit + 10mm gap) and I make the cut in 3+ passes.
Add stops to the t-track and I can easily limit the length of cut. It works great when I need repeatable cuts, which I often do since I make multiple copies of the same small part.
RMW
Offline maisoui
« Reply #19 on: June 25, 2012, 10:48 AM »
Hi there, hi Seth,
did you try the Kreg Heavy Duty Track as well, or just the normal (I think 1/4") Tracks?
Offline SRSemenza
« Reply #20 on: June 25, 2012, 12:44 PM »
Hi there, hi Seth,
Hi, welcome to the FOG!  [smile]
I only tried the regular, I don't have the heavy duty ( http://www.amazon.com/Kreg-KMS7704-48-Inch-Heavy-Track/dp/B0002QZ4UI )  to test.  Based on the pictures of the heavy duty , it looks like the channels are shallow like the regular.  I am sure someone  here on FOG must have some of the heavy duty that they could try the clamps in.
Offline Richard/RMW
« Reply #21 on: June 25, 2012, 12:49 PM »
Hi there, hi Seth,
I have the Kreg Top Trak, channels look identical to the Heavy Track, and they are too shallow for the Festool clamps.
RMW
Offline maisoui
« Reply #22 on: June 25, 2012, 02:35 PM »
@ RMW: Thanks for trying ... anyway ... too bad ...  ???
Offline dmc123
« Reply #23 on: June 25, 2012, 08:17 PM »
I have 8' of old Rockler t-track I never used and sadly the 4 or 5 flip-stops I have from the MFT/3  DO NOT FIT!  The flip-stops do fit the Incra track (I picked some up at Woodcraft on sale last month).
Offline gnlman
« Reply #24 on: June 30, 2012, 05:36 PM »
Just rec'd my Lee Valley T Tracks and both the quick clamps and the screw clamps fit in the 5/16 track(Item 12K7932) . They do not fit in the 1/4 track though....Glad I read this thread it might have taken me years to give this a try!! lol
Thanks for all the help I've rec'd in FOG forums, I finally got to post something nobody else had!! haha
Greg
Offline SRSemenza
« Reply #25 on: March 11, 2013, 02:05 PM »
I believe that all the Festool clamps have the same slightly slimmer profile as the Quick clamps in my original post.  So the compatibilities should be the same for both the quick clamps and screw type clamps assuming you are not using screw type clamps from quite a few years ago.
Offline moody
« Reply #26 on: March 11, 2013, 05:56 PM »
I wonder if these: http://www.ebay.com/itm/4-ft-T-Slot-T-Track-Aluminum-Jig-Clamp-Hold-Down-/270533884216?pt=LH_DefaultDomain_0&hash=item3efd137938 will accept the festool clamps? It says it accepts standard 1/4-20 hex bolts, the same as the incra track. Anyone tried these?
Offline Richard/RMW
« Reply #27 on: March 11, 2013, 06:47 PM »
I have tracks that appear to be identical, which I purchased from McMaster Carr. The clamps do fit them.
RMW
Offline skids
« Reply #28 on: March 11, 2013, 08:42 PM »
RMW
Jackpot! I was just mulling this question...thx!
What I want to know now is if those Incra tracks can be set in 3/4" birch ply. I have a need to add them to my extension wings for my Kapex to make the fence adjustable.
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
Offline Richard/RMW
« Reply #29 on: March 11, 2013, 08:49 PM »
RMW
The Incra T-Track and T-Track Plus are 1/2" thick so they can be dado'ed into 3/4" ply. They come with short pan head screws seemingly for that purpose.
RMW
