Pages: [1]   Go Down
  Print
Author Topic: Clamps for MFT  (Read 4240 times)
Wim
Offline Offline
« on: January 19, 2011, 01:12 AM »
I needed a few extra clamps for the MFT but no other clamp would fit through the 20 mm holes. But I have a few reversible clamps (OK, from Craftsman). So I removed the head, stuck the bar through the hole and attached the head again. Worked perfect.
I'm sure everybody could have thought of this, but I don't remember seeing it on the forum.
rookie08
Offline Offline
« Reply #1 on: January 19, 2011, 08:40 AM »
If they work well, sounds great to me!
Plus I'm sure you can't beat the price.  When are you going to paint them green? Big Grin
Cheers!
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #2 on: January 19, 2011, 10:53 AM »
Another clamp that works well is the Jorgensen Hold-Down Clamp for Workbenches (http://www.adjustableclamp.com/hd-1652.htm):
"Style No. 1652
Excellent tool for gluing, repairing, or hold-down projects. This glass-filled nylon hold-down clamp is designed for workbenches and work tables. A versatile addition to any tool box. Quick and easy adjustments to and from the work using the release locking nut that slides freely on the threaded shaft. Serrated hold-down jaws prevent slipping and can adjust to work being clamped and locks into position with the locking lever. "
 Smile
- Willy -
MFT/3 x2, TS 55, Guide Rails x5, Parallel Guide Set, CT 22 w/Boom Arm, CT Mini, RO 90, RO 125, ETS 125, RTS 400, RAS 115.04, C 12 + Centrotec Imperial Bits, CSX Set, TI 15, DF 500 Domino Set, SCG-10, Domino Plate from RonWen, MFK 700 Set, CMS-GE, OF 1010, OF 1400, OF 2200 Set, LR 32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, more "Stuff"-tainers...
Wim
Offline Offline
« Reply #3 on: January 19, 2011, 02:48 PM »
This is not meant as a replacement for the regular Festool clamps, I just needed clamping on the MFT when I had no Festool clamps left. It takes a few extra seconds to install the clamps but they worked well. I will buy a few more Festool clamps in a few days.
Beside screw clamps I will also buy clamping elements, they are so handy.
Texastutt
Offline Offline
Just Do It!
« Reply #4 on: January 23, 2011, 02:16 PM »
My Second for the jorgensen clamps. I have a swath of them, they work as hold downs, bench stops... Hooks, can't beat them with a stick.
"Beer is proof that God loves us and wants us to prosper." - Ben Franklin
Mavrik
Offline Offline
« Reply #5 on: January 23, 2011, 04:02 PM »
These work well too ... http://www.leevalley.com/en/wood/page.aspx?p=31129&cat=1,41637,41645,31129
TS55, MFT 1080, PS300, EHL 65, Domino, OF 1010, CTL 22, RO 125, BS75
manu31
Offline Offline
« Reply #6 on: February 26, 2011, 09:51 AM »
hi
here's a solution with little F clamp , you must open the clamp (with a file) and have a part of clip (for drawing) :
« Last Edit: February 26, 2011, 10:30 AM by manu31 » Logged
don't hesitate to correct my english mistakes
Pages: [1]   Go Up
  Print
Jump to:
