Author Topic: Ct 48 cart  (Read 1489 times)
Offline dboardman
Ct 48 cart
« on: August 07, 2017, 12:56 PM »
So this is a work in progress. My goal was to have a rolling go to cart for all things I use that are not stationary. The inside as of now holds just my ct 48, eventually I will be adding a small 2 gallon air compressor as well. The suction hose is ran up through the top through a 3" pvc pipe an out.  The top is on a lazy Susan spinner so the hose can rotate 360 degrees.  Both sides are on piano hinges and can be opened all the way out to get to the Ct for maintenance.
The plan is to add some bricks inside to help keep it from becoming tippy, it stands at about 6 1/2 tall. I left the bottom front, middle back, and half the top open for air flow for the machine inside.
Don't mind the mess in the background, I moved into this building a couple months back and there is about 100 unfinished projects.
Offline Fury5
Re: Ct 48 cart
« Reply #1 on: August 07, 2017, 08:50 PM »
Very creative.  I may have to copy it!
