Pages: [1]   Go Down
  Print
Author Topic: Quickgrip Festool clamp hybrid  (Read 2172 times)
LostInTheWood
Offline Offline
« on: April 20, 2011, 10:54 PM »
The festool clamps are great, but lack the handiness of the quickgrips.  I was going to buy the DeWalt version which would have been exactly what I'm looking for, but they only fit the rails and MFT rails.  They don't fit into the holes in the MFT.   I figured modifying them would not be as reliable as the forged leg on the festool clamps so I went the other way and modified the clamping end.   For about $21 I picked up a set of the smaller QGs, not a big loss for the sake of experimentation.   I went to work opening up the areas for the festool clamp bar to pass through.  I used an endmill  and mounted the parts on the cross slide of my lathe.  It's a little rough, but those of you with three axis machines should find this easy.  I fine tuned everything with a small file and put it all together.  It turns out that they work great!  Easy one-handed use.  They don't have the crushing power of the screw clamps and a little less throat than the originals ( both jaws seen in first pic for comparison), but a small price to pay for how I would like to use them.
waho6o9
Offline Offline
WWW
« Reply #1 on: April 20, 2011, 11:00 PM »
Most excellent!    Smile
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #2 on: April 20, 2011, 11:35 PM »
Very cool idea, I have been Jones-ing for one handed clamps.
You gave me an idea for an alternate, I may try to lop off the end of one of my quick-grips and weld a piece of bar stock on to replace it & see how that works.
Add-on products for Festool @ www.ripdogs.com
LostInTheWood
Offline Offline
« Reply #3 on: April 20, 2011, 11:51 PM »
Thought of that too and it would have been easier.  The reason I didn't do that was for the strength of the finished joint.  You need to lop off quite a bit of material on the bar and "heel" part of the assembly to get it to pass through the MFT hole.  Even with built up weld in the right places I wasn't sure.  Maybe the smaller QGs would work better for that idea.  Again, the forged piece on the festool clamp had everything going for it already so I went the other way.   Please post here if you are successful.   I'm temped to try it myself with the leftover parts I have.
Pages: [1]   Go Up
  Print
Jump to:
