Pages: [1] 2  All   Go Down
  Print
Author Topic: Domino add-ons  (Read 6610 times)
live4ever
Offline Offline
« on: February 03, 2012, 02:02 PM »
I've ordered my Domino 500 and looking forward to putting it through its paces on a project with well over 150 loose tenon joints.
I've been reading about the various Domino add-ons...specifically Ron's Domiplate as well as RTS' MSG and SCG guides.  I'm not sure if I'm understanding the correct application of each - here is my rudimentary understanding:
Domiplate - easier and more stable than stock fence for 3/4" and 1/2" ply.  Is that the only use for it?  Does it work with regular (actual) 3/4" or 1/2" stock?
MSG - multiple stops, up to 6 pairs, adjustable across entire plate.  You have to set them yourself.  Useful if you have multiple commonly used mortise distances in a project or across projects, eg. cabinets.
SCG - one pair of stops that are self-centering and adjustable across entire plate.
Is this correct?  Which ones do you use/recommend as must-haves and what is your most common application where they are indispensable?  Any others?
My Green Addiction:  TS55 | ETS150/3 | RO90DX | DF500 | OF1400 | RAS115 | KS120 | LR32
Rembo
Offline Offline
« Reply #1 on: February 03, 2012, 02:11 PM »
You forgot to add INCRA.
live4ever
Offline Offline
« Reply #2 on: February 03, 2012, 02:15 PM »
Not to worry Rembo, I have plenty of Incra.  Smiley  Of course, that does not buy me your creativity or craftmanship.
You should release plans of your Domino jig.  Smiley
Rembo
Offline Offline
« Reply #3 on: February 03, 2012, 03:10 PM »
Yes, I do not quite understand the question))
but the response of the mill DOMINO. so this add-on ..  Smile
Kev
Online Online
« Reply #4 on: February 03, 2012, 06:54 PM »
I picked up the RTS SCG yesterday. Haven't used it, but I'm very impressed with the quality. It's perfect for getting a domino slot centred on a rail ... the flip one lug you're working with the same offset on another piece of stock.
williaty
Offline Offline
« Reply #5 on: April 05, 2012, 03:37 AM »
To me, the nicest thing about the SCG isn't that it self centers on stock. It's that the two guides are always equally distant from center of the mortise. That's a semantic difference, yes, but if you keep it in your head that way, you'll find all sorts of shortcut uses for it that have nothing to do with putting the mortise in the center and everything to do with keeping reference surfaces lined up flush.
Kev
Online Online
« Reply #6 on: April 05, 2012, 03:47 AM »
You're playing with my head ... I must be thick, but can you give me an example of what you mean please? (Although it may come to me later ... it's been a long, long, long, hard day)
williaty
Offline Offline
« Reply #7 on: April 05, 2012, 04:07 AM »
OK, let's take the example of connecting both ends of a table apron to the leg on either end of it. We want the top of the apron flush to the top of the leg and, in this thought experiment, the face of the apron flush with the face of the leg. Further suppose that we want the center of the Domino mortise 30mm down from the top edge (why we're only using one domino, who knows, but that's what we're doing :lol:).
So, adjust the SCG so that one paddle is 30mm away from the center of the mortise. Since you're adjusting one, the other one magically adjusts itself to the exact same distance. Because the paddles mirror each other automatically, it doesn't really matter if you hit 30mm, 29.5mm, or 30.4mm, they'll all magically line up because we have two stops equidistant from center. Flip the fence "flat" into the normal position to plunge into the end of the work with the fence set to put the mortise in the center of the apron stock (thin dimension center, that is).
Place the fence flat on the face of the leg. Using one of the paddles on the SCG, reference off the top of the leg. The other paddle on the SCG will just flip up out of the way. Plunge the mortise. Switch which paddle is up/down on the SCG, take the Domino and go to the apron stock. Place the fence flat on the reference face of the apron stock. Place the paddle of the SCG against the top edge of the apron stock. Plunge the mortise. Repeat this process at the other end of the apron stock. You now have table side that's got everything lined up flush, square, and even without any layout or measuring.
Because both paddles on the SCG are always the same distance from the center of the mortise, it no longer matters which paddle you use as a reference. So long as the fence is on your reference face and a paddle is on the reference edge, both halves of your mortise will line up. Of course, this is exactly the same way the paddles on the fence, the stops on the Cross Stop, the fences on the Trim Stop, and the stops on the MGS all work, but the advantage of the SCG is that the guide itself takes care of making sure you have both sides set perfectly, which is what ensures a perfect line up to the joint.
Now, obviously you can also use it for centering in the stock!
Kev
Online Online
« Reply #8 on: April 05, 2012, 04:37 AM »
Of Course ... and here brain drained stupid me wasn't even thinking that the SCG's paddles move independently ... DOH!!!
thanks
Kev.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #9 on: April 05, 2012, 12:18 PM »
My apologies for not noticing this thread when it was started. Looks like you guys already handled all the questions without me.  Cool
The term "self-centering" was never intended to mean putting the mortise in the center of the stock. Granted, I suppose that's the way most people use it. It was really meant that the two stop arms are automatically centered about the mortise location on the Domino. I actually try to de-emphasize centering in the stock just so users realize that it can be used for much more.
http://www.dominoguide.com/
PaulMarcel
Offline Offline
WWW
« Reply #10 on: April 05, 2012, 12:54 PM »
Ick, maybe you can rename it the You-Can-Self-Center-But-Why Guide.
I rarely use it to center.  Showed it in the review video, but emphasized the benefits at assembly time of offset mortises; offset mortises make it harder to accidentally assemble a piece in the wrong orientation without it being glaringly obvious.
Shirt size: L Cool
Twitter: @HalfInchShy
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #11 on: April 05, 2012, 01:07 PM »
I don't know, Paul-Marcel. I kind of like your idea of calling it "Floyd" better.  Big Grin I love your sense of humor in your videos!!!
I've been thinking about it a lot this morning after reading this thread, and I am beginning to realize that I'm an idiot for trying to de-emphasize a feature that many people consider to be a strong-suit. Instead of de-emphasizing how easy it is to center a mortise on a workpiece by using the workpiece to space the stop arms, I should just put more emphasis on how the guide does a lot more than that.
Regards,
Ick
(It takes 1 typo, and I'm "Ick" for life! hehehe Maybe that should be my new signature line.)
« Last Edit: April 05, 2012, 01:16 PM by Rick Christopherson » Logged
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #12 on: April 05, 2012, 04:48 PM »
I would second that motion. I have the MSG (inherited when I purchased my gently used Domino) and had never really used it. I gave it a try this weekend and I really struggled with getting the paddles centered by eyeing the lines. Kept ending up about .5mm off-center and I did not want to use the oversized slot on one side. I finally gave up (I only needed 2 dominoes) and pocket-holed the joint.
I had been drooling over the SCG whenever I leafed thru the latest Rockler catalog but had thought "heck, I already have one that is just not as fancy, why do I need this one...?"
Question answered.  Big Grin
The paddles are also a little finicky to get straight, I doubt I will use it much unless I need to do a bunch of repetitious pieces. The SCG I could envision using for a few slots totally because of the self-centering feature.
Just  2 Cents.
RMW
Add-on products for Festool @ www.ripdogs.com
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #13 on: April 05, 2012, 05:27 PM »
RMW, it sounds like you didn't get a manual with your inherited MGS-20 or 30 guide. You can download a pdf copy here...MGS-20/30 Manual. In the manual you will see a very simple and super accurate way to set your stop positions. Here is a quick recap:
Take two small boards and line up one edge, and then scribe a line across them both. If you need an offset between different stop positions, draw a second line that distance away from the first line. (I have 2 lines in the picture below.)
Then, take each of those boards, turn them over (pencil line facing the Domino fence) and clamp them to your Domino fence with the pencil line on the center line of your sight gauge. Now you can set the position of your right or left stop by butting it up against the block of wood. Repeat that for the opposite stop. The manual describes this in better detail, but this should give you the quick idea.
At first glance, many people think the SCG-10 guide is a replacement for the MGS-20 guide, but that is not the case. They both serve slightly different purposes. A rather high percentage of new customers actually take advantage of the Combo-kit I created on my website to buy both models at a reduced price.
P.S. If you didn't get a manual for your guide, you probably also didn't get a manual for your Domino either. If so, you can download my Domino Supplemental Manual
« Last Edit: April 05, 2012, 05:30 PM by Rick Christopherson » Logged
jacko9
Offline Offline
« Reply #14 on: April 05, 2012, 09:07 PM »
Live4ever Your question
"Domiplate - easier and more stable than stock fence for 3/4" and 1/2" ply.  Is that the only use for it?  Does it work with regular (actual) 3/4" or 1/2" stock?"
Yes, I use it with thin solid wood stock panels in frame and panel construction of small cabinets.  I find that the 1/2" side of the Domiplate is much easier to locate tenons in thin stock.
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #15 on: April 05, 2012, 09:49 PM »
Rick, you assume 2 things:
1.  Had I received the manual that I would have not immediately misplaced it in the frenzy to start making chips with a new tool, and;
2.  Even if I had retained the manual that I would have EVER looked at it.
Now, having figgered out that I actually need to pay attention to these details to obtain a desirable result, I will take your sage advise and not only download the manuals but also study them.  Doh!
Thank you.  Big Grin
RMW
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #16 on: April 05, 2012, 10:59 PM »
Yup! I'm no different. When I get a new product, I'll skim through the manual in about 30 second before it goes in a drawer or the trash. If something catches my eye--it's the drawer. If not--it's the trash.  Scared
The manuals that I write are a bit of a different story. People actually go looking for them. There have been nearly 40,000 downloads from my Festool Manual page since I installed a hit counter last year or the year before. That doesn't even count how many downloads have been made direct from the Festool website.
PaulMarcel
Offline Offline
WWW
« Reply #17 on: April 05, 2012, 11:31 PM »
I think there's a reason people toss the manuals immediately.  Just today, I was flipping through a tool manual.  It goes far beyond horrible.  I was looking for a specific answer then decided to just read it for the humor that a company (non-green...) actually considers this a useful end to a tree's life.
There was a safety section that starts: "You must always be careful when using power circular saw."
Shall I point out this was a manual for a jointer/planer?
So not to sound like a suck-up, but thanks for the real manuals, Ick.
Shirt size: L Cool
williaty
Offline Offline
« Reply #18 on: April 05, 2012, 11:44 PM »
What amazes me is that, as bad as user manuals are, service manuals are often worse! I own an independent Subaru-specialty shop. Mostly I build race cars and repair the street cars of guys who know me through my performance work. When I started this, I was really annoyed at how bad Subaru's repair manuals were. Skipped steps, useless diagrams, critical errors in fastener torques, etc. However, since then I've been exposed to a Dodge service manual and a Toyota/Scion service manual via taking care of my parents' cars. HOLY CRAP! One of them just lists the bolts to give a torque. In Engrish. How am I supposed to know what the "Back upper lower stop bolt" is? The other one lists engine removal as "Step 1: Once the all electrical, cable, and fuel connections to the engine have been disconnected...". I can't believe how good the Subaru manuals are in comparison.
So, yes, manuals have a deserved reputation for not being worth your time. However, it's also usually the only place to learn how to use the tool. Often, they're actually more useful to me pre-purchase to lean about the tools features rather than post-purchase to learn about how to use the features. I agree, when you run across actually literate technical documentation like Ick's, it's a relief.
williaty
Offline Offline
« Reply #19 on: April 05, 2012, 11:44 PM »
Also, a thanks to both Ick and Paul as I find the SCG very useful and it was Paul's video that convinced me to buy it and gave me ideas about how to make it really useful to me.
PaulMarcel
Offline Offline
WWW
« Reply #20 on: April 05, 2012, 11:52 PM »
What companies need to notice is that on forums, anybody glowing about their new SawStop or Leigh D4R Jig invariably makes a comment about the completeness of the manual, right down to shop-friendly spiral binding.  Couldn't have cost that much, but the ripple effects are worth so much more.
And thanks for the compliment, williaty!  Guess I should re-record my last video I did in Chingrish just for 'raughs'  Embarassed
Shirt size: L Cool
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #21 on: April 06, 2012, 12:05 AM »
Thank you Mr. St.-Orange  Big Grin
Back when I started writing manuals for Festool (specifically for power tools in general), I never realized that there are ANSI and UL documents that specifically mandate what safety warnings are required for each type of tool. So instead, I gathered all of the similar product manuals I could find on the internet and pulled out the applicable warnings. I found that nearly every manual out there had ridiculous warnings that weren't applicable to the tool. What really throw me for a loop was when I saw bad grammar and typos, all of the manuals had the same mistakes.  Scared
A few years ago, when I started working with the law firm retained by Festool USA, they gave me a copy of the ANSI and UL standards, and that is when I discovered that all of these typos were coming directly from the Standards!!! Believe it or not, but the typos and bad writing were actually MANDATORY under the way the regulations were written. I corrected this poor writing, and the lawyers even signed off on my corrections.  Cool Most writers would not go head-to-head with the lawyers, but I did. That's why my safety warnings aren't as ridiculous as most other manuals.
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #22 on: April 06, 2012, 12:29 AM »
Actually, all kidding aside, I did download your Domino manual when I first received the Domino, AND I read it. Still have it out in the work-shed.
I recall it was very clear & contained useful info, I just need a refresher.
RMW
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #23 on: April 06, 2012, 01:11 AM »
What amazes me is that, as bad as user manuals are, service manuals are often worse! ...
Ummm....Willi....Pal.....Friend....My day-job is writing Service Manuals!  Big Grin Big Grin Big Grin
All kidding aside, I know exactly what you are talking about. Before I went independent, I had this cow-worker that convinced our manager that she was capable of writing hardware manuals (as opposed to software), and was therefore on-par or even better than I was (because I refuse to ever write a software manual).
I was working on a Service Manual for a $500,000 product, and I wanted to see if there was any information I could steal from a sister-product manual. There was a procedure for replacing a stepper motor. The procedure should have been, "take these 3 screws out, and you are done." Instead, the writer had the technician removing the main assembly from the base (1 hour labor), then remove the subassembly from the main assembly (15 minutes labor), and then remove the 3 screws that were accessible the entire time.
That wasn't an isolated incident. The entire manual was written that way. The writer didn't realize that her 10 to 15 words actually amounted to hours and hours of labor. It took 30 seconds to type, but she didn't comprehend what that meant in real life.
When I write a service manual, I physically tear the machine apart in my office or shop. When I don't have access to a machine, I still virtually tear it apart within SolidWorks.
Oh, You'll get a kick out of this. I was under a tight deadline, so I took one of these $50,000 modules home over Christmas break one year. I had to reassemble it before bringing it back. Unfortunately, my cat wanted some attention from me, and did everything she could do to get in my way. Instead of fighting it, I started snapping pictures. I then re-wrote the procedures based on these pictures.
I went all the way up to the Vice President of the company to get permission, but the following pictures were released in the final Service Manual, and they remain there to this day!!! The whole machine costs between 1/2 and 1 million dollars, and these are what the Service Manual portrays.
Use the observation Port to verify that the belt is tracking correctly.
Have an assistant hold the pulley while you tighten the screw.
Don't lose your patience. Paws to reflect on your task before reassembly.
williaty
Offline Offline
« Reply #24 on: April 06, 2012, 01:20 AM »
Nice.
Two of my current favorites are the brake section that has you torquing a M12x1.25 steel bolt into an aluminum caliper to a torque of 85lbf-ft. The manufacturer of said caliper says that under no conditions should you EVER torque beyond 55lbf-ft because the caliper will fail. For this reason, there are "Subaru Brembo Specific" kits available from Helicoil and Timesert. There's also the suggestion to torque M6x1.00 bolts to 52.8lbf-ft to hold the clutch pressure plate to the flywheel. Needless to say, you discover the tensile strength of the little bolts.
In the automotive world, we get the added fun of the fact that the times allowed to complete tasks are based off some pencil pushers guess about how long it should take. Then they forget simple things like "the engine has to come out first". Even better, sometimes they allot time for taking the engine out once to do the clutch, then allot another amount of time to take the engine out a second time to get to the flywheel. I do wonder why these guys think the right side of a car is faster than the left. 4 hours to replace the left side cam seals. 20 minutes to replace the right side seals.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #25 on: April 06, 2012, 01:59 AM »
You'll probably get a kick out of this, but aside from writing manuals, I am also designing some performance auto parts for a company local to me. Over at my own forum I have a write-up about designing an intake manifold that is used for a 4-cylinder, 850 hp engine. It sounds as though you know engines, so when I say this is for a 30 psi turbo, you'll probably understand just how unusual that is. It's over at the Woodworking Cafe under the Blowhard: Part 2 thread.
williaty
Offline Offline
« Reply #26 on: April 06, 2012, 02:21 AM »
Looks like a nice project. I can't enlarge the images, but is the coupe in the first picture (the project car, I think), an S2000? Yeah, 30psi is pretty high for a non-WRC car. It gets interesting trying to keep all the couplings in the intake tract done up much above 20psi. I'm sure some of the other race series run high boost as well, but I'm mostly exposed to rally-related stuff, which runs up to 90psi. But only for about 200mi at full boost before it's a paper weight. Before opening my own shop, I did some design of suspension-related parts. It's nice to realize that probably half the modified Imprezas running around out there from 2002-2007 have a part I either designed, tested, or sold on them. I just happened to be at the right place at the right time to work with a couple of companies that are pretty dominant in that niche. I've been around high-power cars, worked on them a bunch, but it was tab-a/slot-b stuff from my end, someone else was doing the power design. I've gotten some pretty hilarious drives in them though. Restrictor-plate cars crack me up. Drive around and it almost seems like a normal car (well, other than the cage, straight-cut gears, etc). Flip the switch marked "STAGE" and suddenly the "idle" jumps up to 4kRPM, the boost settles on 20psi, and the car starts sounding like a string of firecrackers going off. Put the gas flat to the floor, clutch down, pull back on the paddle, and sidestep the clutch. Computer takes over and 800lbf-ft of torque tries to stuff your eyeballs into the back of your head. I honestly think I've got plaid a couple of times, lol. Then the restrictor plate takes over and the shove just dies more and more and more. By redline, it almost feels like a normal car again (though in reality it's still really making a lot of shove, it just feels normal in comparison).
I get guys coming up to me and giving me heck about driving a non-turbo station wagon all the time. They ask how I can have fun in the car without 300-400hp. I tell them once you've driven a car that weighs 2,000lbs and makes over 800hp, it just doesn't seem impressive do drive a 3300lbs car with 400hp. Those are, inevitably, the same guys who have all sorts of reasons why I was able to just calmly drive away from them on a mountain road even though I have a 250+hp disadvantage.
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #27 on: April 06, 2012, 02:57 AM »
That's surprising, because I set the forum up so that visitors have full access to all images and information. Maybe you just didn't click on the thumbnails. Yes, it is an S2000.
I left my speed days behind me quite a few years ago, but my 13 year old son sure gets a kick out of it when we're late for school and I poke the pig pulling out in traffic. I picked up a GMC sierra SLT a few months ago, and it has a nice throaty sound when you let it loose. At these gas prices, I am a little more conservative than I used to be. It's fun, but I can't help but seeing dollar signs flash past. I've never had a 6-speed transmission before, but I'm sure I will find a stupid reason to test it out sooner rather than later.
« Last Edit: April 06, 2012, 02:58 AM by Rick Christopherson » Logged
williaty
Offline Offline
« Reply #28 on: April 06, 2012, 03:01 AM »
I click the thumbnail and it tells me I have to log in.
Yeah, I have to admit I use the gas pedal less than I did even just a few years ago. Of course, I use the brake pedal less now too, what with there being no original parts other than the unibody and a couple of years of driver education. When the speed limit is 25mph, I just set the cruise on 29mph these days. Then again, I don't cancel the cruise to go around 90* corners onto a new street either...
Kev
Online Online
« Reply #29 on: April 06, 2012, 03:20 AM »
The Festool US to Oz price ratio is nowhere near as bad as it is for petrol. For High octane petrol we're paying over the equivalent of $US7 per gallon.
I've gone from a thirsty monster to a frugal Audi that returns 6l/100km on the highway (over 45 mpg).
Pages: [1] 2  All   Go Up
  Print
Jump to:
