Pages: 1 [2] 3 4 5 6 7  All   Go Down
  Print
Author Topic: Domino Gadget for box building.  (Read 68898 times)
CList
Offline Offline
« Reply #30 on: May 14, 2010, 12:53 PM »
I agree that the angle bracket attachment is too small and shaky. I've gotten a feel for it - but I need to concentrate on every face-plunge I do to make sure it's sitting right. I like this as a simple, fast, easy-to-make solution!
OTOH, I don't know if I'm too crazy about using the tool upside down and having to use a different jig for each offset / wood thickness. I have a whole bunch of left over 8020  parts from when I was making my MFT table (still working out a few kinks with that, but it's 95% done, will post pics soon). SO I used one of the really beefy angle brackets (2.75" x 2.75" x 1/4") to make the angle bracket shown below. I put the 1/4" MDF on the bottom to give it a little larger base than just the Alu and to give me a place to mount a little handle - it works WAY better than the standard angle bracket. I also took the advice of the folks here and put counter-sinks on the holes on the backside of the Alu for the rubber lock-rings for the festool thumb-screws. Only problem is that the screws are so long it's a little tedious to take on and off, think I may order a bag of M5 thumb-screws next time I do a McMaster order.
Thanks for stirring my brain in the direct of improving on the plastic angle bracket, I like this much better and wouldn't have thought to do it!
For anyone who's going to do this, the holes in the base are centered 50mm apart and 52mm back from the face of the tool.
Sorry the pics are a little messy - my phone and poorly lit shop.
Cheers guys,
Chris
fshanno
Offline Offline
« Reply #31 on: May 15, 2010, 12:34 AM »
OTOH, I don't know if I'm too crazy about using the tool upside down and having to use a different jig for each offset / wood thickness. .......
Chris,
I take it your fence is working fine for you.  Part of my deal is that my fence can be a little funky sometimes.  With the board screwed to bottom and the fence in it's 0 degree position I get two large bearing surfaces that are very close to 90 and no risk of slippage.  I get the 10mm distance reliably.
I notice that you have the newer model with the paddles.  Makes me wonder if your fence is better than mine.
And yes, it is a little wacky using the Domino upside down.  I've done it quite a bit and I don't like it.  I wish I didn't have to do it but I get better results with my little board.
CList
Offline Offline
« Reply #32 on: May 15, 2010, 12:44 AM »
Ah yes,... the fence-slippage problem... That would be a good reason to go with the board.
I'd read about that before getting my Domino (it's less than a month old), but I think they fixed that problem with these newer paddle-style fences because it hasn't been a problem for me (so far), mine seems to stay exactly where I set it. I read some posts when the new model first came out about the pros and cons and someone mentioned they'd changed the milling somehow to make it less likely to slip. I was using it a bunch just this evening and will be doing another 40 or 50 mortices with it tomorrow so that'll be a good test; I haven't used it for any extended period yet on just one setting since I was still in the play-period where I was trying out all kinds of different things with it.
Cheers,
C
RonWen
Retailer
Offline Offline
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #33 on: June 11, 2010, 04:43 PM »
I made a sole plate for my Domino.  One side is for 3/4" stock and the flip side is for 1/2" stock.  I also attached a cabinet handle which is also reversible.
« Last Edit: June 11, 2010, 04:47 PM by RonWen » Logged
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #34 on: June 11, 2010, 06:18 PM »
Very nice Ron. The only thing I might do differently is use thumb screws to attach it. (scratch that since you'd still need a tool to remove the handle.)
Are you set up to make a small batch of these to sell? Not sure I'm in the market but I'm fairly sure you could sell them.
« Last Edit: June 11, 2010, 06:20 PM by Brice Burrell » Logged
Corwin
Offline Offline
« Reply #35 on: June 11, 2010, 06:43 PM »
 Thumbs Up   Great job, Ron!
Shirt Size:  L
RonWen
Retailer
Offline Offline
WWW
« Reply #36 on: June 11, 2010, 08:10 PM »
Very nice Ron. The only thing I might do differently is use thumb screws to attach it. (scratch that since you'd still need a tool to remove the handle.)[/b]
Yep, I considered that -- Just a tapped thru hole in the center front to screw a knob w/stud on from either side.  Then it would be useful to have the same knobs w/ 5mm studs holding the plate on -- No tools involved.  However, since I don't charge for my time ( Wink) & I thought that handle was kinda neat that's what I went with.
Yeah, I could probably make a batch or two...
RonMiller
Offline Offline
« Reply #37 on: June 11, 2010, 09:06 PM »
I'd be interested in one.
Ron
Wood_Junkie
Offline Offline
« Reply #38 on: June 11, 2010, 09:08 PM »
            Thumbs Up
I like your setup and most of the time I'm using 3/4" material.
If you decide to make a few, count me in!
RonWen
Retailer
Offline Offline
WWW
« Reply #39 on: June 11, 2010, 09:47 PM »
There does seem to be a fair amount of interest from others that would like one for their Dominos.  It seems my best option would be if one of the fine dealers on here (already setup for credit cards, shipping, etc.) might have an interest in handling that portion & I could just ship batches of the sole plates to them for distribution.  Please stay tuned.  Wink
Brice Burrell
Offline Offline
WWW
« Reply #40 on: June 11, 2010, 10:59 PM »
Ron, Paypal makes collecting payment very easy so there really isn't a need to sell these through a dealer. This is especially true of small for small batches. By the time you get you a fair price for your work, then add coast of shipping the items to the dealer, the dealer's mark up and then shipping again you might price some buyers out. The less this puppies are handled the better (cheaper). Of course it would be a little more work on your end, but hay, we're only talking about a small run.
Gary E
Offline Offline
« Reply #41 on: June 15, 2010, 11:32 PM »
Very cool idea. Count me in for one.
Gary
Still learning the easy stuff.
GPowers
Offline Offline
Metric convert
WWW
« Reply #42 on: June 16, 2010, 03:03 PM »
I love the simplicity,  and the repeatability for consistency, I would be interested.
Greg Powers
Jay Knoll
Offline Offline
« Reply #43 on: June 16, 2010, 04:21 PM »
Me too Thumbs Up
Jay
RonWen
Retailer
Offline Offline
WWW
« Reply #44 on: June 16, 2010, 04:27 PM »
OK, I'd better get serious & do something here.  Smile  Does the idea of a single tapped hole at the front center appeal more than using the cabinet handle attached with 2 button head screws appeal to most of you?  It would be quicker to reverse the plate if that is important to you.
GPowers
Offline Offline
Metric convert
WWW
« Reply #45 on: June 16, 2010, 05:34 PM »
One hole with a  big screw on knob!
Greg Powers
Mahogany Man
Offline Offline
Western New York
« Reply #46 on: June 16, 2010, 05:54 PM »
What Greg said!!
John
Does Howdy Doody Have Wooden Balls?
Dane
Offline Offline
« Reply #47 on: June 16, 2010, 07:38 PM »
Since I'll be buying one too, if it becomes available, might I suggest tapping the hole to the same thread as the Festool knobs so that we can all use the otherwise useless knobs that came with our clamping elements?  Make the whole thing cheaper for you to not have to supply the knob and we can use something that we all have kicking around anyway....
GPowers
Offline Offline
Metric convert
WWW
« Reply #48 on: June 16, 2010, 07:52 PM »
I like that Idea!
Greg Powers
RonWen
Retailer
Offline Offline
WWW
« Reply #49 on: June 16, 2010, 08:36 PM »
Sounds good.  I just checked mine -- they are M8x1.25 pitch threads.  It seems like it would be a pretty good knob for the purpose.
Wood_Junkie
Offline Offline
« Reply #50 on: June 16, 2010, 09:14 PM »
Excellent idea!  And they're easily removable sans any tools.  Is the stud length short enough to work with both ends of your support plate?  Or will it go through?
Hrrm... I suppose I could get up off my keister and go measure 'em...
Does anyone use the knobs with the clamping elements?
« Last Edit: June 16, 2010, 09:18 PM by Wood_Junkie » Logged
RonWen
Retailer
Offline Offline
WWW
« Reply #51 on: June 16, 2010, 09:31 PM »
Just the first time... Smile
Corwin
Offline Offline
« Reply #52 on: June 16, 2010, 10:05 PM »
Yea, like you can remember the first time...   Blink
Shirt Size:  L
RonWen
Retailer
Offline Offline
WWW
« Reply #53 on: June 16, 2010, 10:27 PM »
What were we talking about... Huh?
Corwin
Offline Offline
« Reply #54 on: June 16, 2010, 10:38 PM »
Were we talking...  Huh?    Heck, I forgot.      Embarassed
 Doh!       Oh yea, the single M8 x 1.25 threaded hole sound great!
Shirt Size:  L
GPowers
Offline Offline
Metric convert
WWW
« Reply #55 on: June 17, 2010, 11:55 AM »
What for? It is too much work to reach under the table to use them  Tongue Out
« Last Edit: June 17, 2010, 11:56 AM by GPowers » Logged
Greg Powers
jvsteenb
Offline Offline
« Reply #56 on: June 17, 2010, 12:01 PM »
Quote
To be honest: I can't even remember getting them with my clamping elements...... ?
So I guess I can truthfully say I've never used them.
Regards,
Job
TS55, OF1010, RO150, RTS400, PS300, T15+3, CTL22E, CMS-TS55+Basis5A (OF1010), MFT/3, MFS400/700, FS800-1080-1400-1900, Centrotec-SYS 09, DF 500 full set, some accessories Smiley
bruegf
Offline Offline
Michigan
« Reply #57 on: June 17, 2010, 12:44 PM »
I've actually used the knobs a couple of times when the clamping element wanted to tilt up away from the table as I clamped a piece, but that's very rare.
I'd be interested in one of your plates if you do a run.
Fred
Fred
RonWen
Retailer
Offline Offline
WWW
« Reply #58 on: June 18, 2010, 12:03 PM »
I did some re-figuring & I can make & sell the sole plates for (EDIT JULY 14) $38.50 ea.+ $4.95 postage.   I'll proceed to make a batch with the M8x1.25 threaded hole for the clamp element knobs. The plywood current standard thickness of 1/2" ply is 31/64" (.484") and the standard for 3/4" ply is 23/32" (.718").  Even if using actual 1/2" thick material that only moves it off center ~.008".   It is probably a little more important to somewhat center the 4mm Domino tenons in the 1/2" stock than the 3/4" material.
After I have a batch ready to mail I'll post the PayPal information & how to order.  Any other questions?
Thanks,
Ron
« Last Edit: July 14, 2010, 04:28 PM by RonWen » Logged
Wood_Junkie
Offline Offline
« Reply #59 on: June 18, 2010, 12:21 PM »
Awesome, Ron!
Just to clarify from your last post:
The 1/2" side will be intended to center on 1/2" ply (undersized, as you stated.. usually 31/64ths).
The 3/4" side will, however, be intended to center on actual 0.75" material.
Is this correct?
Pages: 1 [2] 3 4 5 6 7  All   Go Up
  Print
Jump to:
