Pages: 1 2 [3]  All   Go Down
  Print
Author Topic: Dust Deputy On Systainer  (Read 24333 times)
Scott W.
Offline Offline
« Reply #60 on: April 05, 2008, 11:18 PM »
Scott,
Love the sys5 w/DD. What fittings did you need for the festool hoses to be able to attach?
thanks,
Eiji
Eiji,
This is going to sound a lot more complicated than it really is. Sorry, I don't have any part numbers here. I just called Timmy C. & said I want to connect x,y,z send me some parts  Cheesy and wa la!
From tool to DD:
The connector on the side of the DD (to the tool) fits the rubber end (tool end) of the medium sized Festool hose that came with the workshop cleaning accessory kit (D36??) I already had. That hose runs up my boom (backwards I guess Smiley). It connects with a Festool adaptor that came with the boom arm hose that connects to hoses vac end to vac end together. From there I connect a short piece of the hose that came with my ct22 (D27??) which I cut off & put a new end on so I had a smaller hose at the tool. That takes care of the "dust in side"
From DD to Vac:
The large hose that came with the boom arm (D50??) goes from the vac  to the DD. On the DD end. I had a Festool hose swivel end laying around (the end that goes into the vac) Just so happens that the hose side fits perfect over the DD port. I used another coupler from Festool (vac end to vac end) to connect the hose.
I guess in the end, It depends on which Festool Hoses you are connecting Huh?
I was actually only short one coupler when I started but had Timmy send me each end of the D27 also so I could cut it off & use a short piece for the final section to the tool.
Let me know what hoses you are using & I'll try to figure it out for you (or I'll call Timmy & let him figure it out  Smiley Cheesy Grin)
ADD: BTW, If you haven't read this entire thread, take a look. The others have some good ideas on making it more portable & other methods that may be even better. Especially if you need to take it on site.
Scott W.
« Last Edit: April 05, 2008, 11:23 PM by Scott W. » Logged
PA, USA
Tom Gensmer
Offline Offline
Residential Remodeler in Minnesota
« Reply #61 on: April 05, 2008, 11:26 PM »
Scott,
thanks,
Eiji
Eiji,
From tool to DD:
From DD to Vac:
Scott W.
Hi Scott! I too am very curious about this setup. For a slightly more simple setup, which parts do you think I'd need for connecting a CT-22 to DD using a D50 hose, and running a D36 or D27 hose from DD to tool? Is there a way of doing it so I'm not really modifying the hoses? What I'm getting at is I try to keep my stuff really mobile and modular, so I'm kind of wary of modifying my hoses in such a way that I can't readily use them just with the DD. I'd really like to keep my hoses in their stock configuration, and make any necessary modifications to the DD with reducers, collars, etc... I really appreciate your time on all this, thanks!
---Tom
« Last Edit: April 05, 2008, 11:27 PM by Tom Gensmer » Logged
Kapex, CT-26, CT-Midi, RO-150, RO-90, OF-1400, EHL-65, DTS-400, Domino (WITH PINS!!), MFT/3, Sprinter full of Systainers
Scott W.
Offline Offline
« Reply #62 on: April 05, 2008, 11:48 PM »
---Tom
Hi Tom,
I didn't modify any hoses just for the DD.
I cut the D27 hose off so I could use it added on to the end of the D36 from the boom so there would be a smaller hose at the tool. All the hoses are just as they came except now I have two shorter D27 hoses instead of one long one.
That said,
Run your D50 from the vac to the DD. On the DD end you need the Festool vac end to vac end coupler and one of the replacement swivel hose ends (vac side) the hose side will fit the DD, the vac side goes in the coupler, it's just a little plastic sleeve.
On the dust in side (to the tool) you need to get from which ever hose you are using to a rubber (tool end) of the D36 hose. I just turned my D36 around backwards and then adapted the other end (vac end) to a short piece of the D27 hose with a coupler.
I'm sorry this seems complicated, It's not... It's just hard to explain.  Huh?
Scott W.
« Last Edit: April 05, 2008, 11:51 PM by Scott W. » Logged
PA, USA
Corwin
Online Online
« Reply #63 on: April 06, 2008, 05:39 AM »
I'll be receiving my ClearVue during the week and will attempt the SYS-5 container.  Now that the Sys-5 is also on her way, I began thinking of simply using a Sys-1 with the lid removed, and build a container with the SYS-1 as its base -- and doing something else at the top end.  Well, maybe that's what I'll try...
One thing I hope to also try is to place a wannabe cyclone separator in-line before the ClearVue cyclone during heavier operations.  This may allow the separator to remove the chips that seem problematic once they enter the Cyclone.  Anyone try this?  If that would function properly, it would make a nice setup for the planer.
Shirt Size:  L
Tom Gensmer
Offline Offline
« Reply #64 on: April 06, 2008, 08:31 AM »
Hi Tom,
That said,
Scott W.
Hi Scott! Yup, now it's all making more sense to me. When I can fit it into my budget I'm going to get a DD/Sys5 like you, it seems perfect for on-site use with planers and larger saws such as the Kapex and a benchtop tablesaw. Again, great idea, keep 'em coming!!
Regards,
Ned
Offline Offline
« Reply #65 on: April 06, 2008, 10:53 AM »
...I began thinking of simply using a Sys-1 with the lid removed, and build a container with the SYS-1 as its base...
So you'd be using the SYS 1 as the bottom of the container?  Seems an expensive way to get a Systainer-compatible base plate.
OTOH, if there's any size of Systainer you've got extras of, and don't really have any use for, that'd be the #1.   Smiley
Ned
ericbuggeln
Guest
« Reply #66 on: April 06, 2008, 07:08 PM »
Scott, I checked out your shop slideshow, very nice.  I had Timmy c send me a Sys 5 before the price increase.  I hope to borrow your design or in the worst case scenario use Sys 5 for random tools, etc.  My dog fits in a Sys 4, she is 12 lbs and also a badass.  Thanks for the design idea, Eric
Hi Eric,
I ran down to the shop this morning and did a quick measurement. The DD will go inside the Sys5 with my liner with no problem at all.
Scott
Thanks Scott for the intel.  Its funny how a lot of people seemed to need that final push to get into the cyclone world.
Corwin
Online Online
« Reply #67 on: April 06, 2008, 07:37 PM »
Ned
Ned, I'll have to agree with you on this...  Even though I have a SYS 5 on the way for this project, after you pointed out an obvious use for a Sys 1 for another use, I got thinking about this application.  But hey, I certainly do appreciate your replies and what ideas and advice you have offered on this forum.  It did make me feel a little stupid for not seeing what should have been obvious, but I've been on either side of that situation, and am all the better for your insight.  Thanks!      - Corwin
« Last Edit: April 06, 2008, 07:38 PM by Corwin » Logged
Shirt Size:  L
Texastutt
Offline Offline
Just Do It!
« Reply #68 on: April 06, 2008, 09:16 PM »
I'm not completely clear what your talking about with the Systainer 1, but without the lid they systainer's are not as strong.
"Beer is proof that God loves us and wants us to prosper." - Ben Franklin
Ned
Offline Offline
« Reply #69 on: April 06, 2008, 09:33 PM »
The SYS 1, shortest of the standard Systainers at 105mm, about 4 inches, high.
I say it's the one you're most likely to have lying around because sometimes you'll want a bit more room than standard, say for your jigsaw, and pop the insert and tool into a larger Systainer than the tool came in.  If you do this kind of swapping around, it's invariably to a bigger one.  Do this often enough and you run out of uses for the SYS 1 before you run out of SYS 1s.
Ned
Michael Kellough
Offline Offline
Southern New York
« Reply #70 on: April 06, 2008, 09:59 PM »
The idea is to put a taller plywood box into a Sys 1 and put the cyclone on top of the plywood box.
The Sys 1 will be the latchable interface to the Festool vac.
Texastutt
Offline Offline
Just Do It!
« Reply #71 on: April 06, 2008, 10:03 PM »
Oh OK I'm clued in now.  Cool
Corwin
Online Online
« Reply #72 on: April 10, 2008, 03:18 AM »
Yep, that ClearVue showed up yesterday, and I hooked it up as shown in the photo in no time today.  Works like a champ -- Hoses fit directly (but I did order a longer D50 just for the occasion) and the paint bucket does not collapse when you deadhead the nozzle.  Be a little nicer if those paint buck lids came on and off easier, but this was quick and easy.  Best of all, it works great!
Now for one of those tool organizers that fits on the inside a Systainer lid...
Shirt Size:  L
Texastutt
Offline Offline
Just Do It!
« Reply #73 on: April 11, 2008, 05:22 PM »
That Looks like a Shop Thang...  but if it keeps the dust out of expensive bag its good, I now understand fully why a Systainer 1 would be good. I'm looking for a way to keep the dust off of my table saw on site.
SRSemenza
Global Moderator
Online Online
« Reply #74 on: April 11, 2008, 10:18 PM »
     A special  lid removal tool is available for those bucket lids.  I think I might have one kicking around somewhere. I will try to dig it up and take a pic if you want?
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
ericbuggeln
Guest
« Reply #75 on: April 11, 2008, 11:32 PM »
Those tools(5 gallon bucket lid opener, i think) work great.  The only thing is that the more times you use them the lid begins to not bend back to it's original position.  This would probably mean you would need to get replacements every once in awhile?
Corwin
Online Online
« Reply #76 on: April 12, 2008, 03:12 AM »
Hey, that 5 gallon paint bucket was simply what I had around (and there's a few more around here too), so I just wanted to set it up and try her out.  This was a simple task to fit the ClearVue to the bucket's lid and perfect when I discovered that it fit into the Workshop Cleaning Set's Systainer 4 -- with even a little room to spare for whatever.
Actually, I am surprised that this container has not imploded as so many have reported -- maybe because I have not yet cut the D50 hose down to fit?  I was thinking the bucket would be the problem (or delay) in setting up the cyclone, but found that this works fine.  Best part is simply attaching the hoses without the need to find the right fittings.  I do plan on applying some copper tape to complete the AS circuit sometime later.  These cyclones have been an item I have looked at for about 1-1/2 years and knew I would get around to this one day, but my bag was needing a changing, so this was a great time.
As to being a 'shop only' item, well, it doesn't need to be.  The ClearVue unit will not fit into a Systainer 5, but if they were to offer a Systainer 6 the works would stow nicely.  Until then you could find some way to transport the cyclone without damage, and a container and some hose shouldn't prevent one from going on the road with their cyclone equipped CT.  Mine will have to travel, but that's just from my basement shop up to the garage for those times when I need to break down some larger material.
Shirt Size:  L
Texastutt
Offline Offline
Just Do It!
« Reply #77 on: April 12, 2008, 08:30 AM »
I take and cut off the "clips" from the bucket on the table saw and it makes it easy to open, don't cut it too high or the lid will not fit snug.
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #78 on: April 12, 2008, 05:27 PM »
Scott,
Yes, the dual drums fill fairly evenly.  Oneida provides short lengths of clear hose to connect the drums to the bottom outlets of the cyclones, and you can see the debris flowing through those hoses into the drums, too, so you can see when they filled.  The key ring style remote control that comes already installed works well, too.  All you have to do is assemble (bolt together the pieces), sealing them with the supplied tube of silicone caulking.
Dave R.
Mike Chrest
Offline Offline
N.W. New York State
« Reply #79 on: April 13, 2008, 12:38 PM »
 Michael K,
Quote
Why not make the bottom of the plywood box slightly larger than the sides and cut notches. If you use 1/2" ply for the bottom it latches to the vac perfectly.
Here's a thread on an adaptor plate ( see picture on post 14).
http://festoolownersgroup.com/index.php?topic=1286.0
Mike C.
Corwin
Online Online
« Reply #80 on: April 14, 2008, 04:37 AM »
Mike C.
Cutting a plywood base to fit was my first intention, but I did like the Systainer-4 setup.  When my ClearVue arrived I found that the paint bucket worked for starters (as it was all that I had around to use) and placing it into the Systainer-4 that came with my cleaning set worked out great.  I may still cut out a plywood base for some future need, but this setup works so nice I may leave well enough alone.
I did notice a little static I received from my PC-121 sander today and decided to do a quick fix.  Since the Festool hoses attach directly to the ClearVue, I ran one wire on the outside from end fitting to end fitting by simply placing the bare wire between the hose and the fitting.  For the inside, I stripped a length of wire, fed thru intake and pulled up thru exhaust by pulling up with some tongs.  To connect to the inside of the fittings, I simply coiled the wire such that it would contact the inner surface of the fittings.  This did eliminate the static I was encountering with the PC sander -- did not have that issue with the TS55 or EQ1400, but with those tools my hands were in contact with plastic parts rather than the metal that is adjacent to the handles on the PC.  Anyway, I do plan on getting some copper tape to improve upon my AS connection solution -- but, this it did address the problem.
Shirt Size:  L
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #81 on: April 14, 2008, 02:29 PM »
To ground my Bosch 4x24 belt sander, I used a short length of small sized flat-braided copper wire.  I secured one end under one of the screws near the power trigger switch; this screw is threaded into the metal frame housing of the machine.  I then wrapped the other end of the braided wire around the DC outlet nipple and forced a Festool 27 mm hose over it.  Absent that ground wire I was getting a near steady stream of tingling shocks from the Festool hose to the back side of my hand that was holding the power trigger switch and gripping the handle of the sander.  Absent that ground, the shocks would start within 10 seconds of powering on the belt sander.  This might be the best demonstration of the value of A/S being designed into the Festool system I have ever experienced.
Dave R.
Tom Gensmer
Offline Offline
« Reply #82 on: April 26, 2008, 09:38 PM »
Hi Tom,
That said,
Scott W.
Regards,
Ok... I'm just about ready to pull the trigger on this thing...... What I'd LIKE to do is not modify my D27 or D36 hose. So, what it looks like is to go from the DD to my tool-end hose I need the rotating D36 tool-end  (#487721) to connect to the DD, and then some sort of adapter so I can connect from there to a standard D27 or D36 hose, or even a Y-piece (452898). So, can I.....
1. Go directly from a D36 Reducing sleeve (487721) to a D36 Rotating Connector (452894), which I can connect to via a Connector Sleeve (493047) for connection to a Y-piece, D27 or D36 hose?
2. Or do I need just a few inches of D36 hose to go between parts 487721 and part 452894?
I apologize for getting so nitty-gritty here, I just want to make sure I have all of the proper parts and connectors on hand so I'm not left waiting to use the DD because I'm one part short..... Anyways, I appreciate any help you folks have to offer!
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #83 on: June 20, 2008, 09:55 PM »
Tom,
What Scott wrote will work exactly.
Here's another way, if you prefer.
1.  For the DD inlet, remove the vacuum end adapter from a 35mm hose and fit the hose directly to the inlet.  Mine was a snug fit.  I installed the 36 mm hose on the Boom Arm with the tool end fitting intact.
2.  To enable use with Festool products that require a 27mm hose, make an adapter.  All you have to do is fit tool end fittings to both ends of a short piece of 27 mm hose (mine is about 1 foot long).  The tool end fitting of the 27mm hose will fit snugly up inside the tool end fitting of the 36mm hose.
I prefer using the 36mm hose when I can because it is less prone to clogging when using a router (or planer).
3.  If you want to leave the tool end fitting on your 36mm hose, intall a rubber plumbing reducer onto the inlet of the DD, and fit the 36mm hose with fitting into it.
4.  To ensure electrical continuity of the anti-static features of the Festool system  (which my belt sander will prove or disprove real fast!), I installed braided copper wire in direct contact with the metal nipple of the DD inlet running over the outside of the rubber adapter and under the SS screw clamps, and wrapped it so it is wedged between the outside of the vacuum end fitting of the 36mm hose and the inside of the inlet of the rubber plumbing adapter.  As a further precaution, I also extended that grounding wire to the DD end fitting of the 50mm hose (both ends come equipped with vacuum machine end fittings) and wedged it between the fitting on the 50mm hose and the outlet of the DD.  This arrangement also allows me to quickly remove the DD and couple the 50mm and 36mm hoses using a Festool connector.
Dave R.
ericbuggeln
Guest
« Reply #84 on: June 20, 2008, 10:56 PM »
Dave and Tom, I just recently got to set up a boom arm and Dust Deputy to my ct 22.  I added a three prong outlet and was able to run the two Festool cords plus an extension cord for other tools without a lot of B.S.  Besides the improved dust collection it is really nice to be able to get all the cords and hoses together and not have to always be changing cords around.  I had it set up to use a SYS 5, but have ran it all week with a 5 gallon bucket and am not sure what I would gain form using SYS 5.  I run a y-blanking piece off of the Dust Deputy to a D27 for Festool stuff and a D50 for Miter and contractor saw.  So far I love it for on site work, it is the epicenter of my whole operation now.  Tom based on your other posts I think you would love it.  Not as portable, but works so well, you'll deal.  If anyone wants to see pics of the Dust Deputy on Sys 5 and 5 gallon bucket to compare let me know.  It is the culmination of what I learned form this forum, so you probably already saw it, Eric
MichaelTurri
Offline Offline
WWW
« Reply #85 on: October 28, 2011, 02:54 PM »
The thing I don't like about Oneida's Festool Specific Solution is the size. So big. No need, really. I'm thinking of retrofitting a systainer as done in this thread, but smaller. To determine the right size of systainer to repurpose, I did some rough calculations to compare systainer volumes with the CT bags. Here's what I found:
SYS1 (11.7L or 3.1Gal)     :    CT MINI (10L or 2.6 Gal)
SYS2 (17.6L or 4.6 Gal)    :    CT MIDI (15L or 4.0 Gal)
SYS3 (23.5L or 6.4 Gal)    :    CT 26 (26L or 6.9 Gal)
SYS4 (38.1L or 10.1 Gal)  :    CT 36 (36L or 9.5 Gal)
SYS5 (46.9L or 12.4 Gal)  :    CT 48 (48L or 12.7 Gal)
Basically, a SYS2 comes close to the 5 Gal pail version of the Dust Deputy! That's really slim. While you obviously won't be able to take advantage of the Systainer's entire volume once you build an interior receptacle, the overall volumes are surprisingly close! So a SYS3 with an interior receptacle would probably replicate or expand upon a cumerson 5 Gal pale. This affords people the choice of developing a more low profile chip container, albeit with less capacity.
I checked with Oneida, who confirmed that one can use a smaller size receptacle. The example I used was a shoe box. Now the other interesting thing to note here is that the smaller the size receptacle, the thinner the wall thickness would need to be before crushing would occur. I'm going to start looking around for premade solutions, although I bet a 0.25" finnish plywood would be more than enough to withstand the crushing forces.   I'll also work on ways to use an interior bag to simplify cleanup.
I'll keep updating as I progress down the road with this project. In the meantime, feel free to contact me with any ideas.
Woodworkingnut
Offline Offline
« Reply #86 on: December 01, 2011, 01:27 PM »
Scott,  I just posted a different version but similar to yours  take a look you may want to build one it gives you more useability.
Pages: 1 2 [3]  All   Go Up
  Print
Jump to:
