Pages: [1]   Go Down
  Print
Author Topic: Vacuum hose enhancement  (Read 2868 times)
Steve Rowe
Offline Offline
« on: February 18, 2011, 07:01 PM »
One of the annoying things about hooking vacuum or extractor hoses up to power tools is that most hoses have ridges.  These ridges tend to catch on corners of work pieces and the MFT table.  I decided to fix this annoyance by installing 1-1/2" expandable sleeving over the vacuum hose and plug it cord.  This eliminates all drag and catching on the corners and so far I have been very happy with the solution.  I almost went for the heavy duty abrasion resistant sleeving however, it was not available in neon green.  Only time will tell how well it holds up to abrasion.  I sealed the ends using Rescue Tape which only adheres to itself and it provides a conforming tight fit to the hose and connector.  I also inserted the plug-it cord inside to eliminate having to tie it off to the hose.
Steve
GPowers
Offline Offline
Metric convert
WWW
« Reply #1 on: February 18, 2011, 07:18 PM »
Great idea that has been discussed in several threads:
http://festoolownersgroup.com/festool-tool-reviews/review-of-festool-ct-midi-dust-extractor-(583376)/
http://festoolownersgroup.com/member-projects/home-made-boom-arm/
http://festoolownersgroup.com/festool-tools-accessories/vacuum-hose-and-'plug-it'-cord-combination/
http://festoolownersgroup.com/festool-jigs-tool-enhancements/sleeve-for-ct-vacuum-hose/
Greg Powers
Alan m
Offline Offline
« Reply #2 on: February 18, 2011, 08:32 PM »
what is this stuff actually for and is there anywhere in the uk to get it
now
wish list
jonny round boy
Online Online
« Reply #3 on: February 18, 2011, 08:34 PM »
I got some just a few weeks ago for the hose on my new CT26. I'll find you a link.
EDIT:
Alan,
I got the braided sleeving here. I use 40mm stuff, which is big enough for the 27mm hose & a plug-it cord. Only available in black or grey though (no green!). I ordered 4 metres for the last one (you'll need about 3.5m total).
I have used adhesive lined heatshrink tubing on the ends of both mine. You'll need that at about 50 or 60mm. You need to be really, really careful with the heatgun though, to avoid melting the braiding or the hose! Eek!
It's a very good idea, it does stop the hose catching though sometimes the braiding itself can catch on very sharp corners. It doesn't last forever though - I did my first one about 4 years ago, and it's now starting to look a little bit tatty!
« Last Edit: February 18, 2011, 08:48 PM by jonny round boy » Logged
USPcompact
Offline Offline
« Reply #4 on: February 18, 2011, 08:39 PM »
Clicky.
These guys ship across the pond.
Here's the link to what I "think" Steve purchased.  Product is "BS125":  Clicky, again.
Kevin D.
Online Online
« Reply #5 on: February 18, 2011, 09:47 PM »
I just ordered a 40 foot spool from Cables and Ties for both my hoses.
http://www.cabletiesandmore.ca/ExpandableSleeving.php
I think I'll use the LV High Friction Silicon Tape for the ends if heat meting the ends doesn't work out somehow.
http://www.leevalley.com/en/wood/page.aspx?p=32183&cat=1,110,43466&ap=1
Anybody know where I could get this same kind of tape in Neon green?
TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Hat, Festool T-Shirt (2), Festool Floor Mat, Festool Stein.
Wish List:  Kapex, and more sanders.
Steve Rowe
Offline Offline
« Reply #6 on: February 18, 2011, 09:51 PM »
I did purchase the sleeving from CableTiesandmore.  I didn't realize this had been discussed in so many threads.
Kevin D.
Online Online
« Reply #7 on: February 18, 2011, 09:59 PM »
Neither did I Steve, and I would like to thank you for bringing it up once again it seems, as I finally got to get them just now.  Not to say I wouldn't have have done so sometime down the road, but it was your thread today that I have to thank. Thanks
And a thank you to GPowers for posting those links as well. Smile
GPowers
Offline Offline
Metric convert
WWW
« Reply #8 on: February 19, 2011, 01:20 AM »
Your in good company, it is a very good idea.
Greg Powers
Pages: [1]   Go Up
  Print
Jump to:
