Author Topic: Festool Guide Rail and Incra TS LS Postioner  (Read 2080 times)
Offline BoulderAv
« on: June 16, 2017, 04:23 AM »
Having bitten the bug of Festool after purchasing a DF 500, I am ready to purchase a TS 55 REQ and in a few months a OF 1400, I found this community on the way to making that expesive decision. Spending time here I ran across threads mentioning how users used the TS LS with their Festool products, I was wondering if it would be possible to use the Inca postioner to move the rail to a needed distance for precise cutting operations. I saw older threads about the same topic but unfortunately it seems that the photos of member projects adressing this issue have dispeared. I plan on using the track saw to break down large amounts of sheet goods for a large kitchen cabinet project and thought the repeatability of the TS LS could be useful. If anyone has any experince with this matter any comments would be greatly appreciated.
Offline TSO Products
    • TSO Products
Re: Festool Guide Rail and Incra TS LS Postioner
« Reply #1 on: June 16, 2017, 11:04 AM »
@BoulderAv - welcome to the FOG - the ultimate resource for FESTOOL users and beyond. I can't see how anyone wouold get the best results without active participation in this well moderated and helpful forum.
Email me your contact info so we can connetc without hijacking this thread. We have other INCRA connection interested customers and are looking into defining needs in a way that can lead to a practical accesssory connecting these popular brands in some applications.
Hans
hans@tsoproducts.com
TSOproducts.com
Home of the GRS-16 and GRS-16 PE Guide Rail Squares -  the MTR-18 Triangle and Work Holding solutions
Offline mike_aa
« Reply #2 on: June 16, 2017, 01:44 PM »
@BoulderAv  @TSO Products
A mounting plate to mount the Incra Positioner on an MFT is currently available but it doesn't address tying directly in to a guide rail.
Hans, I would be interested in seeing what accessory options you might come up with.
Thanks, Mike A.
« Last Edit: June 16, 2017, 01:55 PM by mike_aa »
    • TSO Products
« Reply #3 on: June 16, 2017, 02:30 PM »
@mike_aa  connecting these different brand products is on our product dvelopment roadmap.
You bet we'll keep you in mind. In due course that subject will also show up in our TSO INSIDER Newsletter.
Hans
TSOproducts.com
Offline BoulderAv
« Reply #4 on: June 16, 2017, 05:34 PM »
Hans
The largest conceptual issue I see is how to adjust the rail height for different material thickness, while keeping it square to the Incra Fence. I think if TSO could develop such a product it would allow a tracksaw to much better compete against the more dangerous tool of the tablesaw. I also plan on ordering one of your rail square soon as well since I have heard such good things about them.
Offline RobBob
« Reply #5 on: June 16, 2017, 07:13 PM »
Quote from: BoulderAv
Yes please.  If TSO can figure out an elegant way to do this it would huge!
Offline Corwin
« Reply #6 on: June 17, 2017, 03:29 PM »
... I was wondering if it would be possible to use the Inca postioner to move the rail to a needed distance for precise cutting operations. ...
The largest conceptual issue I see is how to adjust the rail height for different material thickness, while keeping it square to the Incra Fence. ...
Help me understand just how you want to use the Incra Positioner in conjunction with the Festool Guide Rail.
When I first got my TS55 and MFT, I tried setups using the Incra Positioner, but soon found it rather cumbersome and moved on to other options. While I haven't read every thread here that discusses the Incra Positioner, I believe that most, if not all, use the Positioner to locate the edge of the workpiece relative to the 'fixed' location of the Guide Rail. Did I miss something? I just don't see how using the Positioner to locate the Guide Rail will work well. Yet, if you have an idea that will work out, attaching the Positioner to the Guide Rail should be a rather simple task.
Looks like your rabbit joint is a hare off! ;)
