Pages: [1]   Go Down
  Print
Author Topic: Festool Vac Sys - veneer press kit?  (Read 3057 times)
mattfc
Offline Offline
« on: October 24, 2008, 06:00 AM »
Love the idea of the Vac Sys, haven't seen it in action yet, and is also pretty expensive. I might be able to justify it if I could use for dual purposes, such as for a vac press. What do you guys think, I have had a look at the spec, vacuum pressure seems fine, although flow rate is quite low compared to specific vacuum presses, that said, I guess the bulk of the "easy" air could be removed first with a vacuum cleaner, then the vac sys for the final stage.
Pump capacity: 2.7 m3/h at 50 Hz, 3.5 m3/h at 60 Hz
Imperial conversion= 1.75cubic foot min
Minimum vacuum: ≥ 810 mbar/ ≥ 81 %
Imperial conversion=1700 punds /sq ft
Thoughts?
Matt
Bill Wyko
Offline Offline
Location: Tucson AZ 30 miles from water, 3 feet from heck.
« Reply #1 on: October 28, 2008, 04:03 AM »
Go to www.veneersupplies.com Joe has vacuum systems for just about everything and plans and parts to make it yourself.
The bitterness of poor quality, lingers long after the cheap price is forgotten.
mattfc
Offline Offline
« Reply #2 on: October 29, 2008, 05:50 AM »
Thanks for the link (although am UK based), any view as to whether the Festool Vac has enough power, or would another vacuum pump be required?
Eli
Offline Offline
A Yankee in Kangaroo Court
WWW
« Reply #3 on: October 29, 2008, 06:54 AM »
I think it's probably got enough power. I tried it last weekend, it's got a lot of suck. I'm sure it's built quite well. Although it's continuous duty, a veneer vac doesn't seem huge, the ones I've seen. About comparable physical size. It could handle it I bet.
Do nothing, stay ahead.
Pages: [1]   Go Up
  Print
Jump to:
