brandon.nickel
Offline
Currently Peoria, IL - Eventually back to CO
« on: February 14, 2008, 11:54 PM » |
I'd like to see if anyone has come up with a clever way to store their MFT vertically on a wall when not in use. I'm thinking of a flip-up table that could be mounted/dismounted easily using the side profiles. An alternative is to build a castered table/cabinet to set it on, but if I end up with more than one, I'm going to need my floorspace back at some point. My workshop doubles for serious car maintenance from time to time.
Anyone?
TS55, MFT1080, Domino, OF1400, LR32, RO150E, DTS400, Trion, CT33
Dan Clark
Offline
« Reply #1 on: February 15, 2008, 01:20 AM » |
Brandon,
Someone posted pics of detachable wheels. I did a search, but couldn't find them.
Regards,
Dan.
Eli
Offline
A Yankee in Kangaroo Court
« Reply #2 on: February 15, 2008, 05:53 AM » |
If it was to hinge down, you'd have to have clearance at the back for the end of the rail.
If you were going to put wheels on it, the search terms would be "dual locking stem caster"
Do nothing, stay ahead.
brandon.nickel
Offline
« Reply #3 on: February 15, 2008, 11:16 PM » |
Dan, I've seen that series. The same person built a side table and added wheels. I'm thinking of a way to have it hinge up and store out of the way.
I'm thinking that I'll just end up with a rolling cabinet to set it on, but I was wondering if someone in a small shop had come up with something clever.
Steven in Iowa
Offline
Location: Cedar Rapids, IA "The Great Midwest" Member Since: Jan 2007
« Reply #4 on: February 16, 2008, 01:31 AM » |
Brandon,
Regards,
Dan.
I didn't see the post you refer to, but I took some wood blocks and fixed a runner the size of the profile slot to them. I attached some small casters to the blocks so that I can just slide them into the grooves, tighten a toilet bolt slightly, then tip on edge and roll into my storage space.
Rookie to be sure!
TahoeTwoBears
Offline
Location: South Lake Tahoe, California Member Since: Jun 2007
Sugar Bear - South Lake Tahoe, California, USA
« Reply #5 on: February 16, 2008, 10:54 AM » |
Sounds like a great idea. Any chance of seeing some pictures (for those of us that are language challenged this early in the morning)?
Steven in Iowa
Offline
« Reply #6 on: February 16, 2008, 03:46 PM » |
Sounds like a great idea. Any chance of seeing some pictures (for those of us that are language challenged this early in the morning)?  Photography isn't one of my strong points, but they will give you some ideas.
Rookie to be sure!
Dan Clark
Offline
« Reply #7 on: February 16, 2008, 05:12 PM » |
Works for me. There's a clear overview pic, a nice shot of the installed wheels, and a very nice, sharp closeup of both sides of the wheel assembly. Yep, I think that is worthy of:  Dan.
TahoeTwoBears
Offline
« Reply #8 on: February 16, 2008, 06:30 PM » |
I just had another look at the pictures and was struck by the one with the table on its side. Does it balance by itself or is it being held in some manner? If it balances, how long did it take you to move the wheels around to find the exact center of gravity?
Great job once again,
Mike
Tinker
Offline
« Reply #9 on: February 17, 2008, 08:33 AM » |
Mike
He works real fast and the table and wheels are lined up into a high speed turn as he moves it across the floor  Too much Daytona this week maybe  Tinker
Wayne H. Tinker
Eli
Offline
« Reply #10 on: February 17, 2008, 09:29 PM » |
My money is on the legs being unfolded.
brandon.nickel
Offline
« Reply #11 on: February 17, 2008, 10:19 PM » |
That looks like a nice, simple way to make the table portable. Good work. That still doesn't hoist it up onto the walls to clear the floor completely, but it's sure an improvement.
Eli
Offline
« Reply #12 on: February 18, 2008, 04:41 AM » |
I've got one fixed wheel that I ratchet strap to one corner of the table. Then I lift the other corner and drag the table on the wheel behind me. I think it might have been Qwas that posted the lawnmower wheel like that?
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #13 on: February 18, 2008, 02:00 PM » |
Brandon, I hope this attempt to post a reply gets through. For reasons unknown to me, a few replies I attempted last week did not. One of those replies was a detailed message about how you might attach one side of an MFT to the garage wall with a hinge mechanism, and use a small cable strung through a pulley mounted near the junction of your garage wall and ceiling to hoist the table into storage position if you wanted the lower wall space to be as open as possible. Another possibility is to attach one side of the MFT to the wall with a hinge mechanism mounted high enough to enable you to simply lower the free end to rest against the wall when not in use. Either of these fold-to-store mounts would also provide resistance to racking forces. Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
brandon.nickel
Offline
« Reply #14 on: February 19, 2008, 10:36 PM » |
Dave,
That's just the sort of ideas I was shopping for. Too bad your earlier messages got deleted. As for your PM, you're right on the money about my dual-use workspace. I'll send a PM.
-Brandon
vteknical
Offline
« Reply #15 on: March 23, 2008, 01:12 AM » |
Never argue with an idiot, they will drag down to their level and beat you with experience.
mhch
Offline
Hobbyist, France
« Reply #16 on: March 23, 2008, 01:53 AM » |
Would also be great to store lumber using the lift
brandon.nickel
Offline
« Reply #17 on: March 23, 2008, 10:08 PM » |
Yeah, that's certainly an interesting possibility. I wonder how hard/long it takes to raise and lower it...
vteknical
Offline
« Reply #18 on: March 24, 2008, 01:30 AM » |
Ned
Offline
Location: Mountains of Southern California Member Since: Jul 2009
« Reply #19 on: March 24, 2008, 08:37 AM » |
vteknical is pointing to this:  2000 LB. CAPACITY UTILITY WINCH 69.99 USD at Harbor Freight
mhch
Offline
Hobbyist, France
« Reply #20 on: March 24, 2008, 08:42 AM » |
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #21 on: March 25, 2008, 10:38 PM » |
vteknical is pointing to this:  2000 LB. CAPACITY UTILITY WINCH 69.99 USD at Harbor Freight Just don't overlook the relatively low rated weight capacity (250 lb) of the Amazon product offering. Or the load ratings of the ceiling structure to which you plan to attach your hoist / overhead storage rack. Stacking lumber adds up weight quickly. Dave R.
James Watriss
Offline
« Reply #22 on: April 16, 2008, 07:24 PM » |
Surely something like this would be a heck of a lot simpler to use as a hoist, easier to install, easier to modify for the purpose?
