Pages: [1]   Go Down
  Print
Author Topic: Guide Rail Deflector Modification  (Read 2490 times)
SRSemenza
Global Moderator
Offline Offline
« on: September 14, 2007, 11:20 PM »
   I cut a notch in one of my Deflectors and removed the side projection on the bottom. This allows it to be positioned in either Guide Rail slot. I thought this might help a bit when the hose is dragging from the left. I also plan to use a heat gun or something to heat up the plastic enough so that I can bend the sides out a little. A flare out may also help when the hose is coming from the extreme left or right.  Not sure yet how much difference this makes but it is  easy to do.  I marked out the section to remove with an exacto knife and small saddle square. Went to a utility knife to get a good line / cut part way through. Then finished off with a hack saw.  I am sure a band saw would make quick work of this.
srs
« Last Edit: May 08, 2008, 02:10 AM by semenza » Logged
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Timmy C
Festool Dealer
Offline Offline
WWW
« Reply #1 on: September 15, 2007, 11:34 AM »
Hey S, what problems / issues were you having that prompted this modification?
Timmy C
SRSemenza
Global Moderator
Offline Offline
« Reply #2 on: September 15, 2007, 03:11 PM »
   No real problem. I just like to try improving things whenever I see a possibility. If the deflector is over closer to the left side when the hose is coming from that direction , then it should be a little smoother.  Also see my post on this in the Wish List.
Seth R. Semenza
Pages: [1]   Go Up
  Print
Jump to:
