Pages: [1] 2  All   Go Down
  Print
Author Topic: Guide Rail T-Square  (Read 6269 times)
Richard/RMW
Retailer
Offline Offline
WWW
« on: May 21, 2012, 08:45 PM »
This idea is not original but I got motivated to make it a few days ago while reading the thread on Woodpecker's framing square and seeing how Seth used it for cross-cutting plywood.
Today I stopped work right at 5:00, walked out to the work-shed and had it completed by 6:30. Granted, I am set up for simple metalworking and had everything I needed on hand.
The 2 legs are each 600mm long. Total materials needed are 4' of 1/4" by 2" aluminum flat bar, a dozen M6 cap screws, leftover rail clips from my Rip-Dogs adventure (the secret ingredient...) and a couple t-nuts. I drilled the through holes to 1/4" (6.35mm) to give the M6 screw a tiny bit of wiggle room so I could tweak the alignment to square the "T" and snug the leg against the guide rail.
It wouldn't be too hard to replace the the guide rail clips with something shop made, but that might take nearly as much time to make as the rest of the parts together.
Have not tested it but I can't see any reason it would not be dead-on square with a bit of tweaking.
Thanks for looking.
RMW
Add-on products for Festool @ www.ripdogs.com
Johncarlo
Offline Offline
« Reply #1 on: May 21, 2012, 09:17 PM »
Looks good, why buy when you can build it yourself.
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #2 on: May 21, 2012, 09:52 PM »
Well, I do still need to buy the big, precise square to make sure this is perfectly square...  Scratching Chin Doh!
RMW
Jerome
Offline Offline
WWW
« Reply #3 on: May 21, 2012, 10:14 PM »
RMW
Won't simple geometry be faster?  Eek! I assume you have accurate measuring tools.
Jerome
TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone.
Wish list WoodRat, Workshop supplies drum sander
http://www.flickr.com/photos/nui-jerome/
andvari
Offline Offline
« Reply #4 on: May 21, 2012, 11:38 PM »
The gear used to check the square will cost more than the Woodpecker square. However once you have the surface block, angle block, micrometer, dial gauge etc. you'll be set up to make precision jigs plus be able to set up any machines you have accurately.
SRSemenza
Global Moderator
Offline Offline
« Reply #5 on: May 21, 2012, 11:51 PM »
Just for the record it was Gpowers not me that showed the square clamped across the plywood.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
jmbfestool
Offline Offline
« Reply #6 on: May 22, 2012, 01:50 AM »
It's why I want the wood pecker square for my guide rail
An idea I was thinking about of making is like yours but wood  Smile cus da is wa I work with see how it goes and hope the guy down the road can make me a metal one.
If you come up with something good and well priced I would be interested.
I have always had the idea of a tape measure attached to the square.    So the tape measure is built onto the square with a metal piece on the end which is permantly over hanging on the end but does lift up out the way if needed.   The tape is calibrated to the splinter guard cut so the tape would need cutting in length at least the width of the rail.       You have a metal arrow which indicates the length from the end of the board to the splinter guard on the rail. This arrow(marker ) can be adjust to calibrate it.      So I can simply pick up the rail with the square attached bring it to the end of the board the tape with the lip hooks the board and I just drag the rail along till it measure what I want!
For site work this would save a lot of time!    It saves getting your tape out and pencil all the time to hook over your board then mark where your cut going to be to then place the tape back and pick up your saw and rail.   A square eliminates one for the tape measure markings cus you just tick the length and your square cuts it square but a tape measure attached eliminates any markings.
Jmb
« Last Edit: May 22, 2012, 01:41 PM by jmbfestool » Logged
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #7 on: May 22, 2012, 07:51 AM »
I like the idea of the tape on the square, the adjustable marker would not be too hard to add either. When I have time I may add that to this one and then post another photo.
Thanks for the idea.
RMW
An idea I was thinking about of making is like yours but wood  Smile cus da is aa I work with see how it goes and hope the guy down the road can make me a metal one.
I have always had the idea of a tape measure attached to the square.    So the tape measure is built onto the square with a metal piece on the end which is permantly over hanging on the end but does lift up out the way if needed.   The tape is calibrated to the splinter guard cut so the tape would need cutting in length at least the width of the rail.       You have a metal arrow which indicates the length from the end of the board to the splinter guard on the rail. This arrow(marker ) can be adjust to calibrate it.      So I can si ply pick up the rail with the square attached bring it to the end of the board the tape with the lip hooks the board and I just drag the rail along till it measure what I want!
Jmb
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #8 on: May 22, 2012, 07:55 AM »
Yea, I NEED those too, in addition to the Woodpecker square...
Now if I can just figure out how to get the UPS man to hide it in the bushes to avoid "troubling" my wife with details she does not need to know.  Scratching Chin Scratching Chin Scratching Chin
greg mann
Offline Offline
« Reply #9 on: May 22, 2012, 11:30 AM »
I work with some of the most precise measuring tools in the metalcutting industry but I question the need for a precision square to check your unit out. What really matters is the RESULTS you get. Take a representative sample of MDF and create a pristine edge to reference your square off. Make a square cut to that one, flip it over so that you are referencing off the same edge but with the part upside down to the first cut and make another cut. Measure the length of the reference edge and the one opposite. They should be the same length. If not, correct out 1/2 the error and try again. It is virtually without cost and has the advantage of reflecting what you really are getting as opposed to what you think you will get by setting your square against a master. Roger Savatteri calls this 'good setup hygiene', i.e., checking what you get versus checking the setup only.
Greg Mann
Oakland, Michigan
jmbfestool
Offline Offline
« Reply #10 on: May 22, 2012, 02:26 PM »
JUST incase I might not of made my self very clear to what I was thinking of! Here are some sketch up drawings!
I believe this would be a very handy tool! Or in my HEAD it seems like it would be very handy! Maybe in practice it might not work as well I dont know!  I would like to think it will!
The tape even has a parking bay to protect it!
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #11 on: May 22, 2012, 04:41 PM »
Greg,
I guess tongue-in-cheek humor does not translate when typed out. My NEED for many tools is mostly driven by the fact I just like nice tools, hence I convince myself I NEED them for some reason.  Embarassed This is evidenced by drawers full of red Starrett boxes, tools often in pristine condition.
I am familiar with the "1/2 the error method" & have used it from time to time. I like the "good setup hygiene" concept & will have to Google Mr. Savatteri as I am unfamiliar with him/his wisdom.
Thanks,
RMW
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #12 on: May 22, 2012, 05:01 PM »
Got it, I did not understand at first.
What I was thinking was mounting a self-adhesive scale/rule to the "T" and then using a block with a lip as a stop. The block would slide in a groove cut parallel to the scale,with a t-nut and knob to lock it in place.
The scale/rule is show in yellow.
The downside to my method is it is limited to the length of the "T". Your idea does not have that limitation.
RMW
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
jmbfestool
Offline Offline
« Reply #13 on: May 22, 2012, 05:11 PM »
RMW
Well your idea works with the shorter lengths and my idea does NOT       My idea works with longer lengths but your idea does NOT!    Adding both together will allow it to bridge the gap!
I had already thought of this and already thought of something similar to what you have drawn but my dilemma was I had a blind spot ( a area where neither would cover) because unlike your square I drew a triangle so at the point at the far end your idea and my idea wouldnt cover!   I didnt want to  redesign it to how your doing it which is a L-shape  unless its made out of a solid piece  because I dont like the fact it has a joint which can get knocked out of square  a traingle made out of solid piece OR with joints will be far more substantial and hold up better against knocks!
you see im trying to think SITE work not work shop where you can be more carefull!
JMB
jmbfestool
Offline Offline
« Reply #14 on: May 22, 2012, 05:15 PM »
I had anther idea which is more ''SOLID''  appose to the tape measure idea  so you can still get longer lengths but not as long as a tape measure.   You know like the UG-arm extensions you have this piece which slides out and you flip this bit of metal which acts like a stop you can add that but a smaller scale to your square which will allow an extended stop.
JMB
« Last Edit: May 22, 2012, 05:18 PM by jmbfestool » Logged
jmbfestool
Offline Offline
« Reply #15 on: May 22, 2012, 05:28 PM »
Just thought I post it in action lol! well kinda in action lol with rail attached
Alan m
Offline Offline
« Reply #16 on: May 22, 2012, 06:40 PM »
i am thinking of trying this with my fold up layout square.
that thing is massive . like the one posted in a different thread a while back .
it would be a lot easier to use on site  and to transport.
might have to come up with a way to create a lip and to join onto the rail.
now
wish list
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #17 on: May 22, 2012, 07:01 PM »
Alan, You can use the clips from your rip dogs to mount to the rail, just drill them and tap your layout square.
Alan m
Offline Offline
« Reply #18 on: May 22, 2012, 07:06 PM »
i dont think i would drill them because i would rather have a seperate system so that the brackets are ready for use on the mft . having to un screw the would really anoy me and i wouldnt end up using them.
if you were able to have a pin on the square so that your brackets worked the same as on the mft it would be great. that way swaping set ups would be seamless.
i might have to buy another set
now
wish list
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #19 on: May 22, 2012, 07:22 PM »
Dang - I never thought of that, great idea. I will play with that next time I am tinkering.
RMW
fshanno
Offline Offline
« Reply #20 on: May 22, 2012, 08:37 PM »
My need is to do production crosscutting of sheet goods for entire large kitchens.  Dozens of crosscuts one after the other as fast as possible.  Minimal material handling.  Slide full sheets onto the 4x8 cutting platform and lift components cut to size off.  Then over to the MFT for holes and edgebanding and whatever.
I keep thinking that the real answer for crosscutting is a dedicated implement.  A solid 1/4" aluminum square with a bar screwed to the top to guide the saw.  You'd lose cutting depth but I'm focusing on sheet goods.
No friction tape.  One strip of splinter guard tape on the cutting edge just like a normal guide and a strip of teflon tape to level the square.  The square is held in place by hand pressure on the square itself.  Maybe a handle would be required to get more leverage.  The point is that the thing needs to be slippery enough so that it slides easily to the mark with no resistance from the far side.  This is drop dead crucial if you are going to incorporate a stop.
Here's a sketch of what I'm talking about.
Seems like Woodpeckers could knock these out with no problem.
greg mann
Offline Offline
« Reply #21 on: May 22, 2012, 11:06 PM »
I must admit to missing the tongue in cheek. Oh well. Roger posts here occasionally but very often on Talkfestool. He is a fine craftsman and his posts are always of value. I am certainly not immune to carrying the notion of precision to stupid levels. Just last week I needed to account for an 8 inch differential in a length setting. As I pondered what I could use to account for that length I remembered a set of gauge blocks I had picked up at an estate sale. So here I was, racking up a four, a three, and a one to make up an eight inch spacer, to cut wood for crying out loud. Roll Eyes
Greg,
Thanks,
RMW
Greg Mann
Oakland, Michigan
jmbfestool
Offline Offline
« Reply #22 on: May 23, 2012, 02:02 AM »
That would be perfect!  If festool or woodpecker or any one could machine up a one piece rail and square!   Down side to it if you wanted a 800 version and/or. 1400  or longer it could end up costing you alot of money.
Alan the sketch up drawin I did was just rough not to scale hence why it might look massive!
Jmb
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #23 on: May 23, 2012, 08:02 AM »
Greg,
I understand the affliction, which is why I limit myself to hobby pursuits. I could never make a living with my hands, everything I touch takes 4-times as long as is should "to get it right". Oh well.
I did Google Roger and found some links to him but his own site seems to be down. I have to admire anyone who managed to justify 3 BCTW JMP's.
RMW
Greg,
Thanks,
RMW
greg mann
Offline Offline
« Reply #24 on: May 23, 2012, 09:08 AM »
Greg,
RMW
We are in the same boat. If I needed to make a living in woodworking I would starve. But then, if I had started out in it as I did as a toolmaker/machinist/manufacturing engineer/etc., I have little doubt I could have been successful at some level. But no regrets. I make enough in those fields to support my woodworking addiction.  Roll Eyes
Three JMPs. Blink Between you, him, and me we prove my Grandmother's old saying, "Each man is crazy in his own way."  Embarassed
Greg Mann
Oakland, Michigan
Richard/RMW
Retailer
Offline Offline
WWW
« Reply #25 on: May 23, 2012, 09:34 AM »
Seems like reinventing the wheel to make an entire new guide rail rather than use the existing Festool guide rail???
Here is a bit simpler version. So long as the 2 faces are precisely perpendicular to something like +/- 0.0002" I can't see why it would not work to just attach/remove as needed and get double duty from your existing guide rails.
Making a one-piece t-square would require a heck of a chunk of aluminum and a lot of machining, very costly. The attachment could probably be done for +/- $100 - $150 if they were made in quantity.
Just my  2 Cents
RMW
Jmb
Michael Kellough
Offline Offline
Southern New York
« Reply #26 on: May 23, 2012, 11:25 AM »
Here's a rough idea...
How about start with a commercial drywall T-square for $20.
You'd have to use it on the far end because of the asymmetrical fit of the head
to the leg but that shouldn't make any difference.
Figure out a bracket (need a pair) to attach the leg to the outboard slot of the guide rail.
Cut the leg down to about 24" and use the offcut to make a triangle to stiffen the thing
and provide a way to tweak the angle.
Alan m
Offline Offline
« Reply #27 on: May 23, 2012, 06:37 PM »
hi there
i came up with idea a few posts back and did it tonight.
i used my big fold out square and taped on 2 bolts (not threaded the whole way)
and used rmw s rail attacments
now
wish list
Alan m
Offline Offline
« Reply #28 on: May 23, 2012, 06:39 PM »
now
wish list
Alan m
Offline Offline
« Reply #29 on: May 23, 2012, 06:45 PM »
now
wish list
Pages: [1] 2  All   Go Up
  Print
Jump to:
