Author Topic: Edge routing clamping fixture  (Read 7441 times)
Offline Richard/RMW
« on: September 22, 2013, 11:24 PM »
I needed a jig/fixture to clamp stock that left the top totally clear and to let me route the edge without any obstructions, & I wanted the edge of the stock needed to overhang the fixture. After fiddling around a bit I came up with a simple jig using a piece of 80/20 (what else?) and a couple 1.5" squares of 1/4" plate. The key to the whole thing is that everything is below the top of the stock so nothing obstructs the router.
93065-0
93067-1
The 2 small squares of AL attach the the 80/20 with tee nuts/cap screws. At the right end there is a block of AL that is threaded and a handle to put pressure on the AL square. Both squares are beveled to give them a little bite into the end of the stock. The left square is adjusted by sliding it to fit the stock length.
93069-2
The right square is left slightly loose on the 80/20, the handle is tightened to press it against the stock, and then the cap screw is snugged down to lock it in place.
93071-3
93073-4
Shown here I can route the edge of narrow stock with a slot cutter & nothing gets in the way. It takes less than a minute to swap out pieces of stock.
93075-5
93077-6
More fun with 80/20...  [big grin]
RMW
Offline Roseland
Re: Edge routing clamping fixture
« Reply #1 on: September 23, 2013, 05:39 AM »
Nice idea.
I've several of the clamp guides sold by Axminster here in the UK (http://www.axminster.co.uk/progrip-progrip-back-to-back-clamping-adaptors-prod802860/) which can be used back to back.  They are also sold by Peachtree in the USA (http://www.ptreeusa.com/edge_clamps.htm).
Given I already have the clamps the back-to-back adapters seem an inexpensive way to achieve the same result.
Thanks for the idea.
Andrew
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline Richard/RMW
« Reply #2 on: September 23, 2013, 09:05 AM »
Andrew,
Seeing the Peachtree stuff was kind of a "duh" moment for me, I used to have one of the those clamps and totally forgot that they were available. Back when I had it (no idea where it got to...) I never had a use for it so it just hung on the wall.
Thanks for pointing them out.
RMW
Offline ScotF
« Reply #3 on: September 23, 2013, 09:20 AM »
Love seeing your jigs, Richard.  Very ingenious.  Thanks for posting this type of thing.  I think your design has used for jigsaws too.
Scot
Offline Slappy
« Reply #4 on: September 23, 2013, 12:38 PM »
 I gotta get more 8020  [doh]
Mike
Offline Richard/RMW
« Reply #5 on: September 23, 2013, 12:56 PM »
Yup - it's like an erector set for old guys, fun stuff, and you can never have too much.
RMW
